声学楼论坛 → 信息发布区 → 自由交流室 → Bose 251 音箱的参数或照片
  共有9288人关注过本帖树形打印复制链接
主题:Bose 251 音箱的参数或照片
ake2011
等级:论坛游民 帖子:13 积分:198 威望:0 精华:0 注册:2011-3-15 13:29:27
Bose 251 音箱的参数或照片  发帖心情 Post By:2011-8-10 16:55:44 [只看该作者]
各位大侠,有谁有 bose 251 音箱里的喇叭匹配参数啊?或者有外观照片更好。
比如喇叭的: 阻抗,鼓纸的类型(是橡胶边纸盆?还是布边纸盆。。。)
越多越好。
在这里先谢谢了!
  发帖心情 Post By:2011-8-10 19:10:03 [只看该作者]
Award-winning 251 environmental speakers let you enjoy rich, balanced stereo sound over a much wider area than most conventional outdoor speakers. And 251 environmental speakers are tough enough to beat the weather. These speakers connect to your stereo components or Lifestyle system and mount to your exterior walls.With conventional outdoor speakers, sound can only be heard with impact in a few "sweet spots" instead of the broader range of your patio, pool or yard. But Bose 251 environmental speakers produce remarkably rich sound across a much wider listening area.Vital to that performance is Articulated Array speaker design, which houses two speakers set at precise angles in each enclosure. This produces an extremely wide sound field so that you experience consistent stereo effects as you move around outdoors.The small cabinets of conventional outdoor speakers often can't produce the low notes that provide impact. The 251 speakers blend with your outdoor surroundings, yet their technology and design eliminate the audible distortion often heard in other speakers. You can enjoy full, rich music without the need for large, bulky speakers.
General
Product Type Speaker
Width 5.7 in
Depth 8 in
Height 13.5 in
Weight 7.9 lbs
Enclosure Color Black
Enclosure Material Polypropylene
Back to top
Speaker System
System Components 2 speakers
Speaker Type Passive
Nominal (RMS) Output Power 100 Watt
Input Impedance 4/8 Ohm
Recommended Amplifier Power 10 - 200 Watt
Output Features Bass Reflex
Connectivity Technology Wired
Recommended Placing Outdoor
Recommended Placing wall-mountable
Additional Features Weather resistant
Back to top
Speaker System Details
Speakers Included 2 x speaker - 2-way - 100 Watt - 4/8 Ohm - outdoor - wired
Driver Details Speaker : 1 x woofer driver - 5.25" - polymer composite | Speaker : 2 x full-range driver - 2.5"
Back to top
Miscellaneous
Included Accessories Mounting hardware
ake2011
  发帖心情 Post By:2011-8-11 8:03:55 [只看该作者]
谢谢版主。呵呵
