声学楼论坛 → 技术交流区 → 基础理论室 → Consumer Gear是什么意思?
  共有5466人关注过本帖树形打印复制链接
主题:Consumer Gear是什么意思?
foliyo
等级:新手上路 帖子:5 积分:119 威望:0 精华:0 注册:2011-12-16 10:16:04
Consumer Gear是什么意思?  发帖心情 Post By:2012-5-7 14:52:36 [只看该作者]
如题,在外文资料中有个词汇不太认识,查也查不到。。。
“A side trip -- "Professional" vs. "Consumer" Levels
There has always been a lot of confusion about the whole issue of the nominal operating level of "professional" gear versus the nominal operating level of so-called "consumer" gear.
You may have heard that professional gear is "+ 4 dBu" and consumer gear is "- 10 dBV." Because only professionals used this stuff back when it was new (and expensive!) technology, and the older dBu designation was all they had to work with, the original designation of operating level (expressed in dBu) has stuck. By the time consumer audio products were introduced in a big way, the dBV has been invented, and so dBV was used for consumer gear. (Remember, they are
 both simply ways of comparing voltage levels -- nothing more. That + 4dBu is somehow inherently "better" than -10 dBV is a big, fat myth, kept alive by the somewhat arbitrary labels of "professional" and "consumer" attached to them.)”
