声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 软件应用及仿真室 → BASSBOX问题
  共有11447人关注过本帖树形打印复制链接
主题:BASSBOX问题
aleoky
BASSBOX问题  发帖心情 Post By:2006-4-6 13:04:52 [只看该作者]
请教各位BASSBOX高手,单体参数中的Le值是选LMS测试值还是用DC测出来的静态值?
模拟网络中的(第二张图)Rx与Rg如何输入数值?以及类比线路中各代号的含义。
拜谢啦~~~~~~~~~
扰人自扰,自扰扰人
tree
等级:论坛游侠 帖子:35 积分:462 威望:0 精华:0 注册:2006-4-4 11:24:55
  发帖心情 Post By:2006-4-6 13:37:55 [只看该作者]
Include Ext. Resistance External resistance can have a dramatic effect on the response of a speaker design. This option allows you to include these effects in the design. When they are included, a “net” value for Qes, BL and Qts will be displayed in the Parameters tab. They show how the external resistance affects these parameters. Note: The “Include Ext. Resistance” checkbox will be disabled when Rx and Rg are zero.
Rx The series resistance of the speaker cables and terminals. It does not include the resistance of the crossover network.
Rg The source resistance of the amplifier. This is usually very low with most modern amplifiers. If the driver’s impedance (Z) is known, DF is calculated when Rg is entered.
DF The damping factor of the amplifier. If the driver’s impedance (Z) is known, Rg is calculated when DF is entered.
Include Ext. Network The effects of an external passive network can be included in the design. This enables the graphs to show the total system response with a passive crossover network, impedance equalization circuit and/or L-pad. The inclusion of the external network response in the graphs can also be controlled with a checkbox in the Graph Properties window and directly from the graph window by right-clicking on the graph and using the popup menu.
The circuit diagram above shows the position of each component in the circuit. The crossover network section can accommodate a 1st-4th order high-pass, band-pass or low-pass filter.
Open X•over File BassBox Pro is not a circuit designer—values for the network components cannot be calculated for you. However, our companion program X•over Pro is a filter designer and the “Open X•over File” button allows you to import a filter or network design from it. Clicking this button will open a dialog box to prompt you to select an X•over Pro design file. These files end in the file name extension “xo3”. Note: If it is installed, X•over Pro can be launched from the Tools menu of the BassBox Pro main window.
Cs1, Cs2, Cp1, Cp2 These are the series and parallel capacitors in a passive crossover network or filter. Units: mF, µF and pF. (Click on the units label to change units.)
ESR The equivalent series resistance is required for all capacitors in the crossover network or filter. The ESR is not required for the impedance equalization circuit. Units: ohms.
Lp1, Lp2, Ls1, Ls2 These are the parallel and series inductors or coils in a passive crossover network or filter. Units: mH.
DCR The DC resistance is required for all inductors in the crossover network or filter. The DCR is not required for the impedance equalization circuit. Units: ohms.
Rp1, Rp2 The series (Rp1) and parallel (Rp2) resistors of an L-pad. Units: ohms.
Req, Ce, Rm, Lm, Cm, Ra, La, Ca The components of an impedance equalization circuit. Such circuits are used to make the impedance of the driver appear “flat” to the crossover network so it can function properly. The impedance equalization network included with BassBox Pro can accommodate a wide variety of designs and our X•over Pro program can design them. Req and Ce are used to help equalize the reactance of the voice coil. Rm, Lm and Cm are used to help equalize the mechanical resonance of the system. Ra, La and Ca are used to help equalize the acoustic resonance of the system.
aleoky
  发帖心情 Post By:2006-4-8 8:26:40 [只看该作者]
洋文,就在HELP里有,可俺看不太懂~~~~~~~~~~~~~
扰人自扰,自扰扰人
numen518
等级:业余侠客 帖子:56 积分:1846 威望:0 精华:0 注册:2007-7-14 13:42:57
  发帖心情 Post By:2007-8-16 15:02:57 [只看该作者]
此软件可否共享一下呀
ge
等级:论坛游侠 帖子:33 积分:301 威望:0 精华:0 注册:2007-8-24 12:26:56
  发帖心情 Post By:2007-8-24 14:44:15 [只看该作者]
我也要
Heroliu01
  发帖心情 Post By:2007-8-26 12:57:22 [只看该作者]
这个软件算得不怎么准吧!有些地方看不懂呀!
Heroliu01
  发帖心情 Post By:2007-8-26 12:58:31 [只看该作者]
有些地方看不懂呀!
  发帖心情 Post By:2007-9-15 9:56:41 [只看该作者]
以下是引用aleoky在2006-04-08 08:26:40的发言:
自己多摸摸就用一些简单的操作了.
lingyi
  发帖心情 Post By:2007-9-26 9:23:40 [只看该作者]
看图示就可以明白嘛!Rx应该是连接线的电阻;Rg应该是放大器(功放)的内阻嘛!下面是阻尼系数嘛。
aleoky
  发帖心情 Post By:2007-10-4 14:40:57 [只看该作者]
想不到沉浸多年的贴被顶出来了,谢楼上的~~~~~~
还有好多不太熟悉,可现在不做箱子了,有时间还是要多操练操练.
枪要常擦才亮不是~~~~~~
扰人自扰,自扰扰人
jxthyunfeng
等级:业余侠客 帖子:52 积分:733 威望:0 精华:1 注册:2008-2-29 20:31:50
  发帖心情 Post By:2008-5-16 21:32:38 [只看该作者]
为什么这些软件没人愿意放在网上呢
xiyue
等级:论坛游侠 帖子:39 积分:303 威望:0 精华:0 注册:2008-5-13 13:21:40
  发帖心情 Post By:2008-6-12 16:53:10 [只看该作者]
这个软件怎么用,哪为大虾能传授!
zgxlwy@163.com  再此谢过!
