声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 软件应用及仿真室 → LEAP5
  共有9369人关注过本帖树形打印复制链接
主题:LEAP5
4950514ttz
等级:职业侠客 帖子:126 积分:2168 威望:0 精华:0 注册:2007-5-11 20:38:24
LEAP5  发帖心情 Post By:2007-11-30 16:35:01 [只看该作者]
在DAAS3L中测得的曲线要怎样才能转换成LEAP5所运用的格式。
  发帖心情 Post By:2007-11-30 17:08:03 [只看该作者]
导出为CALSOD格式就可以,不要打印格式.
  发帖心情 Post By:2007-11-30 17:10:05 [只看该作者]
导出为CALSOD格式(频响文件后缀为SPL,阻抗为IMP),可以直接导入到LEAP中。
CALSOD
Frequenzgang  NoName
2
0.0
0.0
1.0
0
   20.00   89.90    0.00
   20.27   89.70    0.00
   20.55   89.40    0.00
   20.83   89.10    0.00
   21.11   88.90    0.00
   21.40   88.60    0.00
   21.69   88.40    0.00
   21.98   88.20    0.00
   22.28   88.00    0.00
   22.59   87.80    0.00
这是SPL的内容
CALSOD
Impedanzgang  NoName
1
0.0
0.0
1.0
0
   20.00   23.10   23.60
   20.27   23.60   22.70
   20.55   24.00   21.70
   20.83   24.50   20.70
   21.11   24.90   19.60
   21.40   25.20   18.30
   21.69   25.60   17.00
   21.98   25.90   15.60
   22.28   26.10   14.10
   22.59   26.40   12.60
这是IMP档里面的内容
4950514ttz
  发帖心情 Post By:2007-12-1 9:15:32 [只看该作者]
多谢!但在DAAS3L是CALSOD格式,不知是不是本公司的仪器有问体。还是在DAAS3L中设置不对。那要在主菜单F10中怎样设置,测完曲线后是F3-F5-OK后F4保存对吗?
图片点击可在新窗口打开查看图片点击可在新窗口打开查看
  发帖心情 Post By:2007-12-1 9:56:49 [只看该作者]
Frequency and phase curves can be saved for future use by other user programs,speaker CAD programs etc. Available formats are AudioCad, CALSOD, Akabak® and the hifisound database (see section 9.1). The files can be read by any text editor (except the hifisound database).
Press [F5] to activate the export function.
  发帖心情 Post By:2007-12-1 10:02:38 [只看该作者]
DOS版截图不便.
先在主界面里按F10设置,再按F3设置输出格式(Export format)为Calsod(LEAP)
测试完成后,直接按F5输出(不是按F4保存,F4保存的格式还是DAAS的格式)
  发帖心情 Post By:2007-12-1 10:08:16 [只看该作者]
这是另一个版本的,在F12里选择输出格式.
Data format for export frequency response curves and impedance curves. Four formats
are available:
1. AudioCad: Frequency curves have the extension ".AMP",
Frequency phase curves have the extension ".PHA",
Impedance curves have the extension ".IMP",
Impedance phase curves have the extension ".PHE".
2. CALSOD: Frequency curves have the extension ".SPL",
Impedance curves have the extension ".IMP".
  发帖心情 Post By:2007-12-1 10:08:51 [只看该作者]
3. AkAbakâ: Frequency curves have the extension “.AKD“,
Impedance curves have the extension “.IMP“.
4. Database: hifisound database has the extensions “.DBF“ and “.FRQ“.
4950514ttz
  发帖心情 Post By:2007-12-5 20:26:22 [只看该作者]
问题是不保存怎样导入LEAP中。F5输出到那里,怎么找不到。
新绿
  发帖心情 Post By:2007-12-5 22:12:28 [只看该作者]
路径可以自己设,默认的是DAAS安装目录下.
赠人玫瑰,留手余香!
潜水艇
加好友 发短信 1S2SYYSTJSWW
  发帖心情 Post By:2007-12-8 19:00:05 [只看该作者]
frd格式好像也是可以的,比较通用
理论上所有这类测试结果都可以打开成文本的然后编辑到leap/lms的格式然后倒入
野兔帮K歌第一高手
We Do Sound Right!
潜水艇
  发帖心情 Post By:2007-12-8 19:00:06 [只看该作者]
frd格式好像也是可以的,比较通用
野兔帮K歌第一高手
We Do Sound Right!
