声学楼论坛 → 技术交流区 → 材料与工艺设备 → 材料配件室 → 寻音膜组件
  共有11756人关注过本帖树形打印复制链接
主题:寻音膜组件
lwg1983
等级:职业侠客 帖子:127 积分:1975 威望:0 精华:0 注册:2006-8-26 15:29:42
寻音膜组件  发帖心情 Post By:2008-11-21 9:50:39 [只看该作者]
请问各位兄弟,那家此两种组件和后盖
lwg1983
  发帖心情 Post By:2008-11-21 9:51:35 [只看该作者]
新绿
  发帖心情 Post By:2008-11-21 10:47:02 [只看该作者]
General specifications
Power Rating (AES, W rms) 75
Nominal impedance (?) 8
Frequency range (Hz) 1200-20000
Sensitivity (dB) 110
Minimum crossover (Hz) 2200*
Voice coil diameter (mm/in) 44.5/1.75
Diaphragm material PETP film
Magnet material Neodymium
Mounting Information
Width (mm/in) 90/3.5
Depth (mm/in) 58/2.3
Weight (kg/lb) 0.75/1.7
Fitting Screw (35mm, 1.38in diameter)
Throat exit / diameter (mm/in) 25.4/1
Packed Dimensions and Weight
Single pack size W x D x H (mm/in) 90 x 90 x 60/3.5 x 3.5 x 2.4
Single pack weight (kg/lb) 1/2.2
赠人玫瑰,留手余香!
新绿
  发帖心情 Post By:2008-11-21 10:48:15 [只看该作者]
http://professional.celestion.com/pro/products/cdx/detail_specs.asp?ID=7
celestion公司有!可以直接跟他们购买成品.
赠人玫瑰,留手余香!
lwg1983
  发帖心情 Post By:2008-11-21 11:30:20 [只看该作者]
celestion公司有,是的,我不要成品,我要的是音膜组件和后盖
谢谢楼上的美女
lwg1983
  发帖心情 Post By:2008-11-24 10:21:55 [只看该作者]
难道没有那位兄弟有啊
我急用啊!!!
有的请速与我联系:0574-83072501  李
lwg1983
  发帖心情 Post By:2008-12-2 7:57:13 [只看该作者]
唉。
竟然没有哪位有啊?
郁闷啊!!!!!!
