声学楼论坛 → 技术交流区 → 材料与工艺设备 → 材料配件室 → HERNON喇叭胶应用介绍
  共有12984人关注过本帖树形打印复制链接
主题:HERNON喇叭胶应用介绍
alayshi
等级:论坛游民 帖子:18 积分:245 威望:0 精华:0 注册:2011-11-10 13:22:54
HERNON喇叭胶应用介绍  发帖心情 Post By:2011-11-18 23:03:09 [只看该作者]
SPEAKER ASSEMBLY
HERNON ADHESIVES:Go From Parts&Pieces to Power Test in 10 Minutes!
POLE PIECE TO MAGNET - MAGNET TO TOP PLATE - TOP PLATE TO BASKET
  1. For gaps less than .005" use HASA 716 and EF Primer 50. For gaps greater than .005" use ReAct 727 and EF Primer 56.
  2. Apply Primer to one or both mating surface(s). Allow 60 seconds for evaporation.
  3. Apply 360° bead of Adhesive. Mate parts with a twisting motion to uniformly spread the adhesive.
VOICE COIL TO SPIDER
  1. For tight (friction) fitted parts use Quantum 135 Adhesive. For loose (slip) fitted parts use Quantum 134 Adhesive.
  2. Apply thin film of EF Accelerator 58 to bore of the spider.
  3. Shim and secure voice coil into final position.
  4. Apply 360° bead of Adhesive to the spider-voice coil junction.
VOICE COIL / SPIDER ASSEMBLY TO BASKET
  1. Apply EF Accelerator 58 to spider recess area on base of basket.
  2. Place spider in final position with the flange in full contact with the basket recess area.
  3. Apply 360° bead of Quantum 134 Adhesive to the spider flange lip. Allow adhesive to wick into spider fabric and penetrate to basket surface.
  4. Additional mist of Accelerator is recommended.
CONE TO BASKET
  1. Apply thin film of EF Accelerator 58 to flanged face of the basket (Note: on foam or paper cones apply Accelerator to flange on cone).
  2. Apply 360° bead of Quantum 134 Adhesive to flange face of basket. Mate parts and hold firm with ring fixture for 5-30 seconds.
Note: ring fixtures should be Teflon coated to assure proper removability.
VOICE COIL / SPIDER ASSEMBLY TO CONE
For Temperature requirements less than 200° F:
  1. Apply a thin film of EF Accelerator 58 to the bore of the cone and voice coil.
  2. Shim and secure voice coil into final position
  3. Apply 360° bead of Quantum 147 Adhesive to the voice coil-cone junction. Additional mist of Accelerator is recommended.
For temperature requirements greater than 200° F:
  1. Shim and secure voice coil into final position.
  2. Apply 360° bead of Conebonder 395 Adhesive to the voice coil-cone junction.
  3. Heat cure parts - @ 300°F for 1.5 minutes, @ 250°F for 2.5 minutes, or @ 212°F for 7 minutes.
SURROUND TO CONE
  1. Apply EF Accelerator 58 to contact area of surround
  2. Apply 360° bead of Quantum 134 Adhesive to cone. Mate parts and hold in place for 5-10 seconds.
DUST CAP TO CONE
For Standard Substrates:
  1. Apply a thin film of EF Accelerator 58 to either surface.
  2. Apply 360° bead of Quantum 134 Adhesive to other surface. Mate parts and hold in position for 5-10 seconds.
For polyolefin parts:
  1. Apply 360° bead of Supertacker 358 Adhesive to either surface, then mate parts. High viscosity of adhesive will retain dust cap in position while fixturing. Parts are tack free in 5 minutes.
 SPECIAL APPLICATIONS : KAPTON
Hernon Voice Coil Bonder 360 is a high performance, single component heat cure adhesive for bonding and coating of aluminum, copper-clad, or copper wire coils and form materials including DuPont Kapton. Static heat resistance to 600°F.
Kapton? is a registered trademark of DuPont.
Use Hernon adhesives to bond voice coil materials, including Kapton.
  1. For temperature requirements less than 200°F: Use Quantum 147 Adhesive with EF Accelerator 58. Fixtures in seconds.
  2. For temperature requirements greater than 200°F: Use Conebonder 394 Heat Cure Adhesive. Heat tolerance to 400°F.
POLYPROPYLENE / SANTOPRENE
Hernon has the solution for bonding of polyolefin (polyethelene, polypropylene) and santoprene speaker components! Prep surfaces with EF CA Primer 42 then bond with Hernon's high performance Quantum Cyanoacrylate adhesives.
WHIZZER TO VOICE COIL
1) Apply EF Accelerator 58 to bore of voice coil form.
2) Apply a 360° bead of Quantum 149 to whizzer neck bond surface. Mate parts and hold secure a few seconds.
DRESSING LEADS TO CONE
Apply a bead of Supertacker 358 to secure dressing lead to cone surface.
NOTE: Hernon Ultrabond 752, UV Cure Adhesive, provides alternate assembly choice.
LEAD STRIP RIVETS
1) Apply a drop of Quantum 135 to secure staking rivets.
2) Mist with EF Accelerator 58 to finish "rattle–proofing."
[此贴子已经被作者于2011-11-18 23:41:12编辑过]
赫能制造 美国工业胶粘剂专家 专注33年。。。
电话:13632917864
alayshi
  发帖心情 Post By:2011-11-22 13:30:08 [只看该作者]
相关型号分类:
厌氧胶:716
结构丙烯酸:727
氰基丙烯酸酯:134、135、147、149
单组份环氧:394、395
单组份人造橡胶:358
酚醛丁腈胶:360
UV胶:752
促进剂:EF50
激活剂:EF56
加速剂:EF58
电话:13632917864
xiaozhang
等级:职业侠客 帖子:89 积分:934 威望:0 精华:0 注册:2011-8-26 10:14:51
  发帖心情 Post By:2011-11-24 14:36:43 [只看该作者]
相对应的我这里有,13714109594张工
