声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 各类扬声器设计室 → [讨论]如何将45芯超重低音喇叭做到750W
  共有37038人关注过本帖树形打印复制链接
主题:[讨论]如何将45芯超重低音喇叭做到750W
hhxiu-zfb
加好友 发短信 学习者!
[讨论]如何将45芯超重低音喇叭做到750W  发帖心情 Post By:2008-4-7 21:56:19 [只看该作者]
 Name  Value  Unit  Comment
 Electrical Parameters
 Re  3.34  Ohm  electrical voice coil resistance at DC
 Le  3.779  mH  frequency independent part of voice coil inductance
 L2  5.526  mH  para-inductance of voice coil
 R2  23.19  Ohm  electrical resistance due to eddy current losses
 Cmes  1386.30  µF  electrical capacitance representing moving mass
 Lces  26.66  mH  electrical inductance representing driver compliance
 Res  50.01  Ohm  resistance due to mechanical losses
 fs  26.2  Hz  driver resonance frequency
 Mechanical Parameters
 (using laser)
 Mms  300.105  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  289.58  g  mechanical mass of voice coil and diaphragm without air load
 Rms  4.329  kg/s  mechanical resistance of total-driver losses
 Cms  0.12  mm/N  mechanical compliance of driver suspension
 Kms  8.12  N/mm  mechanical stiffness of driver suspension
 Bl  14.71  N/A  force factor (Bl product)
 Lambda s  0.130     suspension creep factor
 Loss factors
 Qtp  0.72     total Q-factor considering all losses
 Qms  11.40     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.76     electrical Q-factor of driver in free air considering Re only
 Qts  0.71     total Q-factor considering Re and Rms only
 Vas  85.9548  l  equivalent air volume of suspension
 n0  0.194  %  reference efficiency (2 pi-radiation using Re)
 Lm  85.09  dB  characteristic sound pressure level
 rmse Z  11.80  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  5.06  %  root-mean-square fitting error of transfer function Hx (f)
 Series resistor  0.00  Ohm  resistance of series resistor
 Sd  702.25  cm  diaphragm area
 HINT :        Reduce Fmax to 20* fs to improve impedance fitting
 U pp  0.77  V  peak to peak value of voltage at terminals
 U ac  0.10  V rms  AC part of voltage signal
 U head  56.1  dB  digital headroom of voltage signal
 U SNR+D  41.1  dB  ratio of signal to noise+distortion in voltage signal
 fu noise  5.9  Hz  frequency of noise maximum in voltage signal
 I pp  0.08  A  peak to peak value of current at terminals
 I ac  0.01  A rms  AC part of current signal
 I head  63.1  dB  digital headroom of current signal
 I SNR+D  21.9  dB  ratio of signal to noise+distortion in current signal
 fi noise  1631.8  Hz  frequency of noise maximum in current signal
 X pp  0.12  mm  peak to peak value of displacement signal
 X ac  0.02  mm rms  AC part of displacement signal
 X head  64.5  dB  digital headroom of displacement signal
 fx cutoff  90.8  Hz  frequency of highest valid line in displacement signal
 p pp     mV  peak to peak value of microphone signal
 p ac     mV rms  AC part of microphone signal
 p head     dB  digital headroom of microphone signal
 p SNR+D     dB  ratio of signal to noise+distortion in microphone signal
 fp noise     Hz  frequency of noise maximum in microphone signal
 f sample  6000  Hz  sample frequency
 N stim  8192  number of samples  stimulus length
百闻不如一见!
hhxiu-zfb
加好友 发短信 学习者!
  发帖心情 Post By:2008-4-7 22:01:42 [只看该作者]
如上,请各位兄才讨论一下,在主体结构不变的情况下,怎么将额定功率做到最大---能达到750W。
百闻不如一见!
hhxiu-zfb
加好友 发短信 学习者!
  发帖心情 Post By:2008-4-7 22:10:23 [只看该作者]
喇叭为12寸和10寸,外磁,45芯音圈,华司/T铁板厚10mm,磁铁高69mm。
百闻不如一见!
  发帖心情 Post By:2008-4-7 22:26:23 [只看该作者]
45芯做750W,一个字:难。
客人(116.24.*.*)
小大  5楼
  发帖心情 Post By:2008-4-7 22:39:16 [只看该作者]
用印章盖上“750W”,就可以了。
WAMM
加好友 发短信 消防队员1号
  发帖心情 Post By:2008-4-8 8:14:24 [只看该作者]
PMPO嘛,没问题的.
ZY
  发帖心情 Post By:2008-4-8 8:34:44 [只看该作者]
不知LZ是用什么软件测出来的TS?
自以为是
hhxiu-zfb
加好友 发短信 学习者!
  发帖心情 Post By:2008-4-8 19:47:45 [只看该作者]
Klippel测试的
百闻不如一见!
hhxiu-zfb
加好友 发短信 学习者!
  发帖心情 Post By:2008-4-8 19:56:20 [只看该作者]
额定功率实验要通过750W,22小时,问题点主要有:1.音圈断线或散圈2.铝胴体和橡胶边开胶。
待改善:散热,耐温等,还请高手给些经验之谈。
百闻不如一见!
  发帖心情 Post By:2008-4-8 21:26:02 [只看该作者]
针对1.音圈断线或散圈:
750W至少用75以上心音圈了。
针对2.铝胴体和橡胶边开胶:
胴體和編最好有先縫合。
总数 42 1 2 3 4 5 下一页
