声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 各类扬声器设计室 → 看看一些全频单元
  共有18482人关注过本帖树形打印复制链接
主题:看看一些全频单元
钟灵
看看一些全频单元  发帖心情 Post By:2009-4-13 8:49:40 [只看该作者]
The Audience A3 is a breakthrough full range loudspeaker driver design comprised of the patented XBL motor, patent-pending suspension and patent pending basket. The A3 has an exceptionally flat response from 40Hz to 22Khz and -20 at 20Hz with very high power handling and dynamic range. The A3 is built like a high power sub woofer driver using a large neodymium motor structure, big voice coil and suspension venting. The A3 is ultra responsive at 2.5 grams total moving mass providing state of the art resolution and dynamic range. The A3 sports 12mm of usable excursion with less than 1 dB compression at levels up to 95 dB SPL.
The XBL A3 motor design generates an extremely uniform force over the excursion range, resulting in much less distortion and compression . The A3 motor design also allows for an extremely low voice coil inductance, insuring exceptional flat response to higher frequencies.
The A3 surround, patent-pending, is uniquely s shaped allowing for the surround to provide large excursions without shrouding the cone and with uniform resistance in both directions.
The A3 basket, patent-pending, supports the structure while free of typical design resonances, it is unobstructive and avoids trapped air volumes. The mechanical design was extensively refined using state of the art Finite Element Analysis to have no mechanical resonance problems.
The A3 spider was designed with special materials and design that provide for large linear excursions and is of a size usually associated only with much larger drivers.
The A3 pole piece venting is also unusual in that a vent of this size is usually only seen in much larger sub woofer type drivers. This large vent has radiuses on both ends to prevent turbulence. This large vent supports high volume air flow for cooling the voice coil for superior power handling.
The Cone is a curvilinear design executed with an anodized aluminum magnesium alloy making for an exceptionally rigid cone. The concave dust cap is made of a proprietary material providing constrained layer damping to control cone break up at high frequency and to provide high frequency desperation.
The above are some, not all, of the unique and special design features of the A3. Under development is an A3 driver version that will have dual 8 ohm voice coils providing for 4, 8, or 16 ohm connections.
钟灵
  发帖心情 Post By:2009-4-13 8:51:29 [只看该作者]
钟灵
  发帖心情 Post By:2009-4-13 8:55:51 [只看该作者]
钟灵
  发帖心情 Post By:2009-4-13 9:01:47 [只看该作者]
阿龙-翟
  发帖心情 Post By:2009-4-13 14:06:01 [只看该作者]
 怎么不把喇叭图片,参数,规格一起贴出来?
新绿
  发帖心情 Post By:2009-4-14 8:57:03 [只看该作者]
这些3" 4" 8"的全频,都比不上楼上的12"全频,灵敏度低了近10dB!
赠人玫瑰,留手余香!
阿龙-翟
  发帖心情 Post By:2009-4-14 20:07:50 [只看该作者]
以下是引用新绿在2009-04-14 08:57:03的发言:
3“.4”.8“.12”用场不同,不能一样看待
希望钟灵多发些相关图片和测试
[此贴子已经被作者于2009-04-14 20:09:04编辑过]
中山门
  发帖心情 Post By:2009-4-14 21:13:04 [只看该作者]
人家阿龙那个12“全频喇叭是上帝指点的,两个同尺寸规格的喇叭,竟然能做出不同的Sd来!
钟灵
  发帖心情 Post By:2009-4-14 21:13:50 [只看该作者]
Feature
图片点击可在新窗口打开查看 Extend frequency response
图片点击可在新窗口打开查看 Low distortion, long linear excursion
图片点击可在新窗口打开查看 Die cast chassis, aluminum cone
图片点击可在新窗口打开查看 25 mm voice coil
图片点击可在新窗口打开查看 Neodymium magnet
Specifications
Overall Dimensions 88.4X52.4mm
Net. Weight 0.58Kg
Nominal Power Handlng 15 W rms
Nominal Impedance 8 Ohms
Sensitivity 1W/1M 84.4dB
Frequency Response 95-32,000Hz
Resonant frequency 95Hz
Magnet System
Magnet system type Neodymium
Magnetic Gap Height 10mm
B Flux Density 0.88T
Bl Product 3.313Tm
Max Linear Excursion 3mm +/-
Voice Coil
Voice Coil Diameter 25mm
Voice Coil Height 4.0mm
Voice Coil Former aluminum
Voice Coil Wire Copper ribbon
Number of Layers 1
DC Resistance 6.0 Ohms
Levc @1KHz 45uh
T/S Parameter
Cms 1.212mm/N
Sd 27.34cm^2
Vas 1.286L
Mmd 2.182gm
Mms 2.264gm
Qms 2.346
Qes 0.722
Qts 0.552
钟灵
  发帖心情 Post By:2009-4-14 21:18:55 [只看该作者]
总数 15 1 2 下一页
