声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 各类扬声器设计室 → 指导一下
  共有19352人关注过本帖树形打印复制链接
主题:指导一下
wsf912
等级:新手上路 帖子:216 积分:3283 威望:0 精华:0 注册:2006-7-13 10:23:03
指导一下  发帖心情 Post By:2006-11-5 13:11:03 [只看该作者]
6寸半HiFi扬声器,请高手指点一下
客户
 Name  Value  Unit  Comment
 Electrical Parameters
 Re  6.89  Ohm  electrical voice coil resistance at DC
 Le  1.100  mH  frequency independent part of voice coil inductance
 L2  1.469  mH  para-inductance of voice coil
 R2  5.59  Ohm  electrical resistance due to eddy current losses
 Cmes  252.20  µF  electrical capacitance representing moving mass
 Lces  64.74  mH  electrical inductance representing driver compliance
 Res  45.14  Ohm  resistance due to mechanical losses
 fs  39.4  Hz  driver resonance frequency
 Mechanical Parameters
 (using laser)
 Mms  16.381  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  15.54  g  mechanical mass of voice coil and diaphragm without air load
 Rms  1.439  kg/s  mechanical resistance of total-driver losses
 Cms  1.00  mm/N  mechanical compliance of driver suspension
 Kms  1.00  N/mm  mechanical stiffness of driver suspension
 Bl  8.06  N/A  force factor (Bl product)
 Lambda s  0.066     suspension creep factor
 Loss factors
 Qtp  0.37     total Q-factor considering all losses
 Qms  2.82     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.43     electrical Q-factor of driver in free air considering Re only
 Qts  0.37     total Q-factor considering Re and Rms only
 Vas  24.0958  l  equivalent air volume of suspension
 n0  0.329  %  reference efficiency (2 pi-radiation using Re)
 Lm  87.37  dB  characteristic sound pressure level
 rmse Z  3.76  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  2.30  %  root-mean-square fitting error of transfer function Hx (f)
 Series resistor  0.00  Ohm  resistance of series resistor
 Sd  130.70  cm  diaphragm area
我的
 Re  6.94  Ohm  electrical voice coil resistance at DC
 Le  0.708  mH  frequency independent part of voice coil inductance
 L2  0.546  mH  para-inductance of voice coil
 R2  1.53  Ohm  electrical resistance due to eddy current losses
 Cmes  266.95  µF  electrical capacitance representing moving mass
 Lces  70.44  mH  electrical inductance representing driver compliance
 Res  91.38  Ohm  resistance due to mechanical losses
 fs  36.7  Hz  driver resonance frequency
 (using laser)
 Mms  11.256  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  10.371  g  mechanical mass of voice coil and diaphragm without air load
 Rms  0.461  kg/s  mechanical resistance of total-driver losses
 Cms  1.670  mm/N  mechanical compliance of driver suspension
 Kms  0.60  N/mm  mechanical stiffness of driver suspension
 Bl  6.49  N/A  force factor (Bl product)
 Lambda s  0.039     suspension creep factor
 Loss factors
 Qtp  0.398     total Q-factor considering all losses
 Qms  5.626     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.427     electrical Q-factor of driver in free air considering Re only
 Qts  0.397     total Q-factor considering Re and Rms only
 Vas  42.9442  l  equivalent air volume of suspension
 n0  0.478  %  reference efficiency (2 pi-radiation using Re)
 Lm  88.99  dB  characteristic sound pressure level (SPL at 1m for 1W @ Re)
 Lnom  89.61  dB  nominal sensitivity (SPL at 1m for 1W @ Zn)
 rmse Z  5.49  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  2.17  %  root-mean-square fitting error of transfer function Hx (f)
 Sd  134.78  cm  diaphragm area
  发帖心情 Post By:2006-11-6 9:12:21 [只看该作者]
比较羡慕测试的仪器!图片点击可在新窗口打开查看图片点击可在新窗口打开查看
spk888
加好友 发短信 电声工作者
  发帖心情 Post By:2006-11-6 9:52:12 [只看该作者]
Qms相差较大,是否音圈用的材料不一样?
理论是来研究的,经验是要积累的...18666420943
wsf912
  发帖心情 Post By:2006-11-6 17:35:03 [只看该作者]
客户只给了一个样品,随时可能拿回去,我没拆样品,我用的是铜线0.19
我用的是Klippel测的
 下载信息  [文件大小:   下载次数: ]
图片点击可在新窗口打开查看点击浏览该文件:
 下载信息  [文件大小:   下载次数: ]
[此贴子已经被作者于2006-11-06 18:35:41编辑过]
  发帖心情 Post By:2006-11-7 11:34:22 [只看该作者]
能测量这么多参数,好啊!
潜水艇
加好友 发短信 1S2SYYSTJSWW
  发帖心情 Post By:2006-11-7 14:24:10 [只看该作者]
参数和客样区别太大,客户如何要求的?copy?有没有要求阿?
野兔帮K歌第一高手
We Do Sound Right!
老军医
  发帖心情 Post By:2006-11-8 9:17:02 [只看该作者]
相信LZ不是COPY吧?连SD都有相差,是不是连喇叭的尺寸都可以有相差?
wsf912
  发帖心情 Post By:2006-11-8 19:00:06 [只看该作者]
客户只给我一个样品,还不能拆,我从现有的部件中找,只能找相近的了.我的是两层排线,我估计样品是四层排线的.谁能告诉我为何L1,L2,R2,Rms 相差那么大?
  发帖心情 Post By:2006-11-14 20:29:27 [只看该作者]
完全不相同的两只喇叭!!!
共同点是啥?
快乐的
加好友 发短信 野兔帮--混混
  发帖心情 Post By:2006-11-14 21:20:30 [只看该作者]
BL 值都差那么远的,如果磁路接近的话,音圈的层数都不对吧
积累边思考着
总数 16 1 2 下一页
