声学楼论坛 → 技术交流区 → 电声器件与系统设计 → 各类扬声器设计室 → 指导指导
  共有12962人关注过本帖树形打印复制链接
主题:指导指导
wsf912
等级:新手上路 帖子:216 积分:3283 威望:0 精华:0 注册:2006-7-13 10:23:03
指导指导  发帖心情 Post By:2006-11-23 19:31:00 [只看该作者]
 Name  Value  Unit  Comment
 Electrical Parameters
 Re  7.44  Ohm  electrical voice coil resistance at DC
 Le  1.640  mH  frequency independent part of voice coil inductance
 L2  1.235  mH  para-inductance of voice coil
 R2  3.08  Ohm  electrical resistance due to eddy current losses
 Cmes  145.29  µF  electrical capacitance representing moving mass
 Lces  115.02  mH  electrical inductance representing driver compliance
 Res  117.34  Ohm  resistance due to mechanical losses
 fs  38.9  Hz  driver resonance frequency
 Mechanical Parameters
 (using laser)
 Mms  13.837  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  12.971  g  mechanical mass of voice coil and diaphragm without air load
 Rms  0.812  kg/s  mechanical resistance of total-driver losses
 Cms  1.208  mm/N  mechanical compliance of driver suspension
 Kms  0.83  N/mm  mechanical stiffness of driver suspension
 Bl  9.76  N/A  force factor (Bl product)
 Lambda s  0.061     suspension creep factor
 Loss factors
 Qtp  0.250     total Q-factor considering all losses
 Qms  4.170     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.265     electrical Q-factor of driver in free air considering Re only
 Qts  0.249     total Q-factor considering Re and Rms only
 Vas  30.1119  l  equivalent air volume of suspension
 n0  0.646  %  reference efficiency (2 pi-radiation using Re)
 Lm  90.30  dB  characteristic sound pressure level (SPL at 1m for 1W @ Re)
 Lnom  90.61  dB  nominal sensitivity (SPL at 1m for 1W @ Zn)
 rmse Z  5.58  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  1.80  %  root-mean-square fitting error of transfer function Hx (f)
 Series resistor  0.00  Ohm  resistance of series resistor
 Sd  132.73  cm  diaphragm area
以上是样品
我的
 (using laser)
 Loss factors
[此贴子已经被作者于2006-11-24 16:12:09编辑过]
美猴王
加好友 发短信 孙行者
  发帖心情 Post By:2006-11-23 20:00:28 [只看该作者]
这么是一样的!
真"神"!
我的如来佛祖啊!怎么现在世间的人,也会分身术拉!
俺老孙,闹天宫,斗如来,保唐僧,降妖魔,取真经!
szyql
等级:职业侠客 帖子:95 积分:2252 威望:0 精华:0 注册:2006-10-12 18:49:40
  发帖心情 Post By:2006-11-23 23:11:29 [只看该作者]
牛,但不怕羞,吹吧?!
wsf912
  发帖心情 Post By:2006-11-24 17:54:47 [只看该作者]
 Re  6.89  Ohm  electrical voice coil resistance at DC
 Le  1.100  mH  frequency independent part of voice coil inductance
 L2  1.469  mH  para-inductance of voice coil
 R2  5.59  Ohm  electrical resistance due to eddy current losses
 Cmes  252.20  µF  electrical capacitance representing moving mass
 Lces  64.74  mH  electrical inductance representing driver compliance
 Res  45.14  Ohm  resistance due to mechanical losses
 fs  39.4  Hz  driver resonance frequency
 (using laser)
 Mms  16.381  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  15.54  g  mechanical mass of voice coil and diaphragm without air load
 Rms  1.439  kg/s  mechanical resistance of total-driver losses
 Cms  1.00  mm/N  mechanical compliance of driver suspension
 Kms  1.00  N/mm  mechanical stiffness of driver suspension
 Bl  8.06  N/A  force factor (Bl product)
 Lambda s  0.066     suspension creep factor
 Loss factors
 Qtp  0.37     total Q-factor considering all losses
 Qms  2.82     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.43     electrical Q-factor of driver in free air considering Re only
 Qts  0.37     total Q-factor considering Re and Rms only
 Vas  24.0958  l  equivalent air volume of suspension
 n0  0.329  %  reference efficiency (2 pi-radiation using Re)
 Lm  87.37  dB  characteristic sound pressure level
 rmse Z  3.76  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  2.30  %  root-mean-square fitting error of transfer function Hx (f)
 Sd  130.70  cm  diaphragm area
Sorry,sorry. 这才是样品的
如过我把Kpton VC Bobbin换成AL的,再把BL值降一下,Le,R2,L2 会不会就合他的接近了?
hualong
  发帖心情 Post By:2006-11-27 10:37:56 [只看该作者]
所有的参数都做到一样是不可能的,要求给个公差
wsf912
  发帖心情 Post By:2006-11-27 17:17:54 [只看该作者]
那我的喇叭在客户那能过得去吗?
wsf912
  发帖心情 Post By:2006-11-27 17:21:46 [只看该作者]
那我的喇叭在客户那能过得去吗?
听起来中音有点吵,低音有点薄,什么该呢?把阻尼加大,同时把音圈加重?
  发帖心情 Post By:2006-11-30 21:49:39 [只看该作者]
将鼓纸的质量增加或许能起到一举两得效果!
呵呵!灌水!
