标题:特等奖不会用啊。。
zhsunby110 发表于:2013-10-30 18:11:36
请问一下各位,ARTISON STUDIO 46 SOUNDBAR该怎么接电视或者放大器啊?
上次交流会的特等奖抱回家之后不知道怎么插啊。。。
后面之后三对“+”.“—”接口 ...我想接个放大器不知道买哪个型号?
请麻烦懂的专家指点一下。。。。
zhsunby110 发表于:2013-10-30 18:54:43
就是这个东东 看看
水仙 发表于:2013-10-30 20:29:05
水仙 发表于:2013-10-30 20:30:15
Artison Studio46-SBSoundbar Speaker Overview
Sonic Purity
Whether it be a solo violin floating over a symphonic passage or the impact of a high-speed car chase that ends in a
fiery crash, Artison is dedicated to reproducing every nuance of the experience with dynamics and clarity.
Easily Attachable
The Television Mounting Brackets (TMB) alow each of the Studio Series SoundBars to attach to virtually any flat
panel display. In a tabletop installation, simply screw the brackets into the standard VESA mounting points and adjust
it to match the bezel either above or below the TV. When using a fixed, tilt, or articulating wall mount, the TMB are
sandwiched between the mount and the TV. Either way, the soundbar is perfectly poised to provide an accurate and
impressive sound field.
Advancing Technology
This latest offering from the legendary engineering heritage at Artison is an impressive trio of soundbars that are more
than just a minor upgrade. These three models represent new technology and the kind of attention to detail that
makes them the perfect center point of any audio system. Featuring extruded aluminum enclosures and proprietary,
woven carbon fiber woofers, the Studio Series marks a new standard for sonic performance in a compact soundbar.
Eliminating Boundaries
To expand the soundstage beyond the limits of the SoundBar itself, the Studio Series features a pair of Stage Tweeters
on the outside ends of the enclosure. These tweeters aim toward the rear wall at a 45-degree angle. The sound
reflects off the wall and dramatically widens the sonic image.
Aesthetic Elements
Creating a loudspeaker that offers incredible sonic performance while remaining visually discreet is no easy task.
Throughout our history Artison has blended science, technology, and artistic design to create some of the finest loudspeakers
available. The Studio Series carries forth this tradition by blending into the television through our unique
custom grilles. Artison offers the ability to specify the exact model of the video display and have a grille exactly
match the width dimension. Since the grille is the only element of the speaker that is visible after the installation, it
appears to be an integral part of the TV.
A Simple Choice
Whether you are looking for an L-C-R solution for the bedroom or a large surround-sound system for the main media
room, the Studio Series is an excellent option. Available in three sizes to address a wide variety of video displays.
Artison’s SoundBars will provide a Total Involvement Experience ? for even the most discriminating listeners
水仙 发表于:2013-10-30 20:34:36
Artison Studio46-SBSoundbar Speaker Specifications
Dimensions:
4.1”H x 44.7”W x 2.2”D
Minimum Grille Dimensions:
4.7”H x 45.2”W x 2.7”D
Driver Complement:
Six 3.5” Long Throw Carbon Fiber Midrange / Woofers
Three 25mm Vifa DX Super Audio Tweeters
Two 19mm Stage Tweeters
Cabinet/Finish:Black Anodized Aluminum
Frequency Response:
80 Hz - 40 kHz ± 3 dB
Nominal Impedance:6 Ohms
Sensitivity:
89 dB @ 2.83 Volts, 1 Mete
Enclosure Type:Bass Reflex
 Recommended power:
75 - 150 watts
水仙 发表于:2013-10-30 20:35:24
市场价一万多元,楼主真幸运!
liuzhouqun 发表于:2013-10-31 8:21:35
75 - 150 watts
是夸张吗?
farmer 发表于:2013-10-31 14:18:01
你叫我们会用想用,而没有的人情何以堪。
zhsunby110 发表于:2013-10-31 14:41:12
当时一直坚持听课到最后。。。正准备收拾一下散场的。。电脑抽到我的号码了。。。当时就懵了一下。。。
这个音箱我回去看后面有LCR三个声道的接口啊。。普通的输出不都是LR两个声道吗?中间那个CENTER声道咋办?
我不接电视接放大器可以吗?那个放大器支持三声道输出的啊?求指导。。。
我是搞耳机的。。音箱这块不是很懂。。。
zhsunby110 发表于:2013-10-31 14:44:07
连放大器可以用吗?什么型号的?
求指点。。。。
话说。。要不要便宜卖给你?呵呵
liuzhouqun 发表于:2013-10-31 17:47:34
 不需要放大器, 有内置的,你要不要的话,打1折卖给我,我考虑收了他图片点击可在新窗口打开查看
zhsunby110 发表于:2013-10-31 22:54:25
一折啊。。太不厚道了吧。。怎么说也要个半价什么的吧。。。
话说  那我怎么连接电脑?
farmer 发表于:2013-11-1 8:40:03
我二折 收了它。
jasonlyh 发表于:2013-11-1 17:21:30
去年声学楼一等奖是摩声音响, 6寸喇叭配高音,可以摇控控制,有IPHONE4接口低频音质很过劲,听DJ很有质感.一直很喜欢.
shenhuilw 发表于:2013-11-1 22:16:28
我等到五点多,安慰奖都没有,哈哈
大黑漆包线一级代理:15899798075
zhsunby110 发表于:2013-11-1 23:42:17
没有人能告诉我这个能连手机或者电脑吗?
小平头 发表于:2013-11-3 12:34:16
以下是引用zhsunby110在2013-11-01 23:42:17的发言:
没有人能告诉我这个能连手机或者电脑吗?
虽然我没见过是什么样子的,但肯定是可以的.
小平头 发表于:2013-11-3 12:36:37
以下是引用zhsunby110在2013-10-31 14:44:07的发言:
连放大器可以用吗?什么型号的?
求指点。。。。
话说。。要不要便宜卖给你?呵呵
这么好的东西,还是留给自己用吧,中奖了来之不易,我坐了两天,什么都没有中到.
小平头 发表于:2013-11-3 12:44:43
以下是引用jasonlyh在2013-11-01 17:21:30的发言:
都是幸运的人啊,多回一下贴,自己也将是幸运的了.图片点击可在新窗口打开查看
zhsunby110 发表于:2013-11-3 21:25:41
哈哈 明年就是你啦!
