共7 条记录, 每页显示 20 条, 页签: [1]
标题:连接器
一个老兵 发表于:2006-7-25 1:53:13
连接器 电声设备采用不同类型的连接器 YANGDJ编译
•RCA连接器
•通常用在消费性电子产品和某些专业档设备的不平衡轴型连接器,俗称唱机插头
•XLR 三针连接器,通常用在专业档电声设备.大多是平衡传输线方式的连接, 俗称卡侬插头
•1/4" TRS
•1.立体声连接器,由芯(T),环(R)和套(S)组成,用成T=左,R=右和S=地/屏蔽.
•2.平衡连接器,正负信号线分别连在T和R端,S只是用于全屏蔽.
•3.插入回路连接器,T=送出,R=回接, S=地/屏蔽.
•1/4" TS 单声道连接器, 不平衡传输线方式,T=信号线,S=地/屏蔽.
wayne 发表于:2007-4-22 20:28:31
谢谢老兵前辈!!
我以前只知道连花插头 3.5Φ 6.35Φ几种连接器 还不知道TRS的具体意思!
一个老兵 发表于:2007-4-23 0:46:13
以下是引用wayne在2007-04-22 20:28:31的发言:
谢谢老兵前辈!!
详情可参看
http://www.rane.com/par-c.html#connectors
Acoustics 发表于:2007-4-23 8:34:23
connectors Audio equipment uses many types of connectors as follows:
banana jack or banana plug A single conductor electrical connector with a banana-shaped spring-metal tip图片点击可在新窗口打开查看 most often used on audio power amplifiers for the loudspeaker wiring. Usually configured as a color-coded molded pair (red = hot & black = return) on 3/4" spacing. Also used for test leads and as terminals for plug-in components. The British still refer to these as a GR plug, after General Radio Corporation, the inventor (according to The Audio Dictionary by Glenn D. White).
binding posts Alternate name for banana jacks above, derived from the capability to loosen (unscrew) the body and insert a wire through a hole provided in the electrical terminal and tighten the plastic housing down over the wire insulation, holding the wire in place.
图片点击可在新窗口打开查看BNC A miniature bayonet locking connector for coaxial cable. Used to interconnect S/PDIF digital audio. See BNC for development and name history.
Cannon connector or Cannon plug Alternate reference for XLR.
Elco connector or Elco plug AVX manufactures several connectors used for interconnecting multiple audio channels at once, most often found in recording studios on analog and digital audio tape machines. One of these, a 90-pin version (Vari*con Series 8016), carries 28 shielded pairs of audio channels, allowing 3-wires per channel (positive, negative & shield) for a true balanced system interconnect.
图片点击可在新窗口打开查看Euroblocks Shortened form of European style terminal blocks, a specialized disconnectable, or plugable terminal block consisting of two pieces. The receptacle is permanently mounted on the equipment and the plug is used to terminate both balanced and unbalanced audio connections using screw terminals. Differs from regular terminal strips in its plugability, allowing removal of the equipment by disconnecting the plug section rather than having to unscrew each wire terminal.
图片点击可在新窗口打开查看RCA (aka phono jack or pin jack) The Radio Corporation of America (RCA) originally developed this type of unbalanced pin connector for internal chassis connections in radios and televisions during the '30s. It became popular for use in the cables that connected phonograph cartridges to preamplifiers because it was inexpensive and easily fitted to the rather small diameter shielded cables used for the cartridge leads (then they were mono cartridges so single conductor shielded cables were adequate -- now you know). The standard connector used in line-level consumer and project studio sound equipment, and most recently to interconnect composite video signals. (excerpted from Yamaha Sound Reinforcement Handbook, pp. 297-298).
图片点击可在新窗口打开查看Speakon® A registered trademark of Neutrik for their original design loudspeaker connector, now considered an industry de facto standard.
terminal strips or terminal blocks Also called barrier strips, a type of wiring connector provided with screwdown posts separated by insulating barrier strips. Used for balanced and unbalanced wiring connections, where each wire is usually terminated with a crimped-on spade- or ring-connector and screwed in place; not disconnectable, or plugable. Has become known as the U.S. style terminal blocks. Contrast with Euroblocks.
图片点击可在新窗口打开查看1/4"; TRS (tip-ring-sleeve) 1. Stereo 1/4" connector consisting of tip (T), ring (R), and sleeve (S) sections, with T = left, R = right, and S = ground/shield. 2. Balanced interconnect with the positive & negative signal lines tied to T and R respectively and S acting as an overall shield. 3. Insert loop interconnect with T = send, R = return, and S = ground/shield. [Think: ring, right, return]
1/4" TS (tip-sleeve) Mono 1/4" connector consisting of tip (T) [signal] and sleeve (S) [ground & shield] for unbalanced wiring.
图片点击可在新窗口打开查看XLR 1. Originally a registered trademark of ITT-Cannon. The original model number series for Cannon's 3-pin circular connectors - invented by them - now an industry generic term. [Ray A. Rayburn tells the whole story: "At one time Cannon made a large circular connector series that was popular for microphones called the P series (now known as the EP series). Mics used the 3-pin P3 version. Some loudspeakers use the P4 or P8 versions of this connector to this day (Neutrik Speakon NL4MPR 4-pole chassis mount and all Speakon 8-pole chassis mount connectors are made to fit the same mounting holes as the Cannon EP series). In an attempt to make a smaller connector for the microphone market, Cannon came out with the UA series. These were 'D' shaped instead of circular and were used on such mics as the Electro-Voice 666 and 654. There was a desire for a smaller yet connector. Someone pointed out the small circular Cannon X series. The problem with this was it had no latch. Cannon rearranged the pins and added a latch, and the XL (X series with Latch) was born. This is the connector others have copied. Later Cannon modified the female end only to put the contacts in a resilient rubber compound. They called this new version the XLR series. No other company has copied this feature."] 2. The standard connector for digital and analog balanced line interconnect between audio equipment.
Acoustics 发表于:2007-4-23 8:37:50
BNC插座在仪器中使用较多
SPEAKON插座在专业音箱中常用
Acoustics 发表于:2007-4-23 8:40:45
香蕉插头使用场合就更多了,一般用于仪器仪表。
欧阳风 发表于:2007-4-25 10:05:08
记得以前吴启学老师有提过这方面的东西,很实用的。
谢谢楼上的各位。
