共18 条记录, 每页显示 20 条, 页签: [1]
标题:拉普拉斯元件实现声阻运算(pspice)
liheng_rd 发表于:2013-5-7 0:02:17
如题,
拉普拉斯元件实现声阻运算,参数如何设置
nisa 发表于:2013-5-7 11:29:59
Modeling a frequency dependent inductor for AC sweep analysis
PROBLEM:
How do I model a frequency dependent inductor for AC sweep analysis?
SOLUTION:
The impedance of an inductor is:
Z = L * s
where
s = j * 2 * PI * Frequency
In a frequency dependent inductor, the "L" in the above formula changes with frequency.
If you know L as a math function of frequency, then:
  1. Use a GLAPLACE device.
  2. Connect the positive and negative inputs to the positive and negative outputs, respectively.
  3. Write the transform expression as 1/(<L>*s), where <L> is replaced by the desired math formula, with frequency replaced by abs(s)/6.283185.
For example, if L = 1 / sqrt(Frequency), then write the transform expression as:
1/(1 / sqrt(abs(s)/6.283185)*s) or sqrt(abs(s)/6.283185)/s
http://www.orcad.com/documents/community.faqs/pspice/020020.aspx
更详细的介绍查阅实例(要翻越和谐之墙): Google搜索"Modeling a frequency dependent inductor for AC sweep analysis"的第二个结果:
 http://acousticians.blogspot.com/2012/10/modeling-frequency-dependent-inductor.html
[此贴子已经被作者于2013-05-07 20:03:13编辑过]
jma 发表于:2013-5-7 20:09:03
1) 将GLAPLACE的输入端正负极与输出端正负极分别对接起来;
2) 改写转换函数为1/<R>形式, 其中<R>为计算后得到的频率f的函数;
3) 考虑到拉普拉斯变量s = jω = j·2πf, 故将上述转换函数中的频率改写成f = abs(s)/6.28 .
liheng_rd 发表于:2013-5-7 22:30:39
非常感谢楼上二位的帮助,谢谢
liheng_rd 发表于:2013-5-8 0:30:01
举个实例吧:
单孔的声阻:R=sqrt(2ηρw)*(l/a+2)/(π*a^2)
假设:η=1/2;ρ=1/2;l=1;a=1;
则计算的R=[sqrt(π*frequency)*3]/π
那么XFORM的参数是1/(([sqrt(π*abs(s)/6.28)*3]/π)*s)这个表达式吗?
jeno 发表于:2013-5-9 9:37:09
学习啦
nisa 发表于:2013-5-9 11:32:50
以下是引用liheng_rd在2013-05-08 00:30:01的发言:
举个实例吧:
要把分母最后的s去掉, 即XFORM= 1/Z =1/R= 1/([sqrt(pi*abs(s)/6.28)*3]/pi)
假设单孔的声质量表达式子L=sqrt(π*frequency)*3]/π ,
那么XFORM的参数才是XFORM= 1/Z =1/(L*s)=1/(([sqrt(π*abs(s)/6.28)*3]/π)*s)
1/Z中的Z表示阻抗
lhyjs_63 发表于:2013-6-28 15:33:50
小马哥,nisa您们好:
                     第3点中,3) 考虑到拉普拉斯变量s = jω = j·2πf, 故将上述转换函数中的频率改写成f = abs(s)/6.28
             有不明白请指教,s = jω = j·2πf,那么 f = s /  j·2π, 又因为 j = √-1  所以 f = s / (√-1 ·2π) = -s·√-1 / 2π, 如何得到 f = abs(s)/6.28 的呢,谢谢。
nisa 发表于:2013-6-29 7:54:44
以下是引用lhyjs_63在2013-06-28 15:33:50的发言:
小马哥,nisa您们好:
你想多了;   abs()是求模值,即abs(s)=abs(jω)=ω, ω=2πf → f=ω/2π;
mustang 发表于:2013-7-5 19:18:37
学习
jqr01 发表于:2013-7-8 2:41:17
阻抗Z= 单孔的声质量 L *S   这里的S是代表什么呢,为什么 要把分母最后的s去掉 , 即XFORM= 1/Z =1/R= 1/([sqrt(pi*abs(s)/6.28)*3]/pi)
jqr01 发表于:2013-7-8 2:42:29
为什么这里又会出现S:那么XFORM的参数才是XFORM= 1/Z =1/(L*s)=1/(([sqrt(π*abs(s)/6.28)*3]/π)*s)
1/Z中的Z表示阻抗
nisa 发表于:2013-7-8 20:29:24
 二、三楼的内容说得够详细了啊;自己多动脑子思考才好理解透。
katlin 发表于:2015-5-6 10:07:44
为什么我将参数XFORM设置成 1/([sqrt(pi*abs(s)/6.28)*3]/pi),提示出错呢,说是无效的传输函数??
**** INCLUDING ceshi1-SCHEMATIC1.net ****
* source CESHI1
C_Cmd         N16341 N11893  4.5m
E_pSd         N03344 0 V2 N06338 3.8969e-5
L_Ma1f         OUT 0  163
X_vSd    N11893 N03344 N06338 V2 SCHEMATIC1_vSd
R_Rmd         V1 N16144  4.0m
C_C2         N06242 0  0.094p
R_Re         N02561 N02595  31.2
C_C1         N03778 0  0.093p
X_BLi    N16272 N03050 V1 N03236 SCHEMATIC1_BLi
R_Ra11         OUT N04192  10
X_BLv    0 N03236 N03050 0 SCHEMATIC1_BLv
L_Le         N02595 N16272  80uH
R_Ra1f         0 OUT  190M
L_Mmd         N16144 N16341  19uH
R_Ra1r         N06242 N06138  246M
G_G1         N03778 N03852 LAPLACE { V(N03778, N03852) } {
+  1/[sqrt(abs(s)/6.28)*0.09] }
ERROR -- Invalid transfer function
L_Maf         V2 N03778  38.6
R_Ra31         N06138 N05374  10
L_Mar         N06338 N06242  38.6
G_G2         0 N05072 LAPLACE { V(0, N05072) } { 1/[sqrt(abs(s)/6.28)*0.09] }
R_R20         N03778 0  100G
L_Ma1         N03852 N04192  210
R_R21         N06242 0  100G
L_Ma1r         N06138 N06242  186
V_Eg         N02561 0 DC 0Vdc AC 1.79
L_Ma3         N05072 N05374  455
Acoustics 发表于:2015-5-6 15:25:57
* Example Schematics Netlist *
R_R2         $N_0002 $N_0001 0.001
V_V3         $N_0002 0 DC 0V AC 1v
R_R3         $N_0002 0 10meg
R_Rsim     0 $N_0003 10meg
G_Rvar2    $N_0001 0 LAPLACE { V($N_0001, 0) } {
+ 1/(k2*sqrt(S/(2*3.14159265))) }
R_R1          $N_0004 0 16000
G_Lvar       $N_0003 0 LAPLACE { V($N_0003, 0) } {
+ 1/(S*1e-6*(k3-(k4*LOG(k5*(S/(2*3.14159265)))))) }
G_Rvar1     $N_0001 $N_0003 LAPLACE { V($N_0001, $N_0003) } {
+ 1/(k1*sqrt(S/(2*3.14159265))) }
C_C            $N_0001 $N_0004 .64pF
To view the specific effective simulation results
Include the following Macros in your Probe trace analysis to see frequency vs. inductance, impedance, phase angle (in degrees), and Q factor:
PI = 3.14159265
L=(IMG(V(R3:1)/I(R2))/(2*pi*FREQUENCY)
Z = V(R3:1)/I(R2)
ANG = (180/PI)*ARCTAN((IMG(V(R3:1)/I(R2)))/(R(V(R3:1)/I(R2))))
QFACT = ABS((IMG(V(R3:1)/I(R2)))/(R(V(R3:1)/I(R2))))
vickyzhang1981 发表于:2017-1-20 16:48:52
我的权限也不够,也来狂顶楼主一通图片点击可在新窗口打开查看
XYO104249 发表于:2017-12-25 14:56:47
太深奥了~~收藏学习
eie05031 发表于:2023-5-17 13:12:40
么的深奥啊,闷啦
