共19 条记录, 每页显示 20 条, 页签: [1]
标题:求助各位!等效电路的小问题
chengd 发表于:2007-12-18 17:12:27
这一阵子我看关于T/S参数测试的相关文章,其中一篇提到:一直流阻抗为6.2ohm的扬声器,画出导纳型电路图如下。但我不明白电和力之间也可以直接如图连接吗?为何图中没有声部分的等效电路?
(文章名字为:Measuring Loudspeaker Driver Parameters,在http://sound.westhost.com/中可以找到)
等效电路图:
Acoustics 发表于:2008-1-12 18:20:35
Measuring Thiele / Small Loudspeaker Parameters
There are several different ways to measure the Thiele/Small parameters of a loudspeaker driver. The method described here provides a way for the beginner and DIY enthusiast to measure the parameters without any expensive or specialised equipment.
Definitions:
ReElectrical resistance of voice coil
FsResonant frequency of loudspeaker moving mass (in free air)
QesElectrical Q of loudspeaker
QmsMechanical Q of loudspeaker
QtsTotal Q of loudspeaker
VasEquivalent air volume of moving mass suspension
Acoustics 发表于:2008-1-12 18:21:21
Measuring Re, Fs, Qes, Qms and Qts
To measure these parameters using the method outlined below, you'll need to have the following items:
Figure 1 shows a typical impedance curve for a loudspeaker (see Figure 5 for the equivalent circuit of this speaker, which was simulated for this article). Resonance causes a large increase in impedance, and at some higher frequency, the inductance (or semi-inductance) of the voice coil causes the impedance to rise again. The region for the initial measurements must be within the "linear" region of the impedance curve. In the example below, resonance is at 27Hz, and the linear region ranges from about 100Hz to 400Hz.
At resonance, the speaker impedance is pure resistance. As the frequency increases towards resonance, the impedance characteristic is inductive. Beyond resonance as impedance falls, the impedance characteristic is capacitive. Within the 'linear' region, the impedance is again (almost) resistive, but at slightly below the speaker's nominal impedance (nominal impedance is usually taken as an average value over the usable frequency range). At the frequency where the inductance of the voice coil becomes significant, impedance rises, and is progressively more inductive as the frequency rises. It is common to add a compensation network to maintain an overall resistive characteristic at these higher frequencies, so that the performance of the (passive) crossover network is not compromised. This is not necessary with an active crossover.
Although a 'pure' inductance is shown in the equivalent circuit, this component is often referred to as 'semi-inductance'. Because of losses (primarily eddy current losses within the pole pieces), the impedance typically rises at around 3-4dB/ octave, rather than the expected (and simulated) 6dB/ octave. This has little or no effect on resonance parameters, and can usually be ignored for these measurements.
Figure 1 - Loudspeaker Impedance Curve
The multimeter should be capable of measuring frequency, as well as AC voltage and resistance. If it cannot, a frequency counter is highly recommended, since the frequency measurements are critical. The amplifier must be capable of reproducing from 10 Hz to 2 kHz with no variation in output voltage. It is imperative that it is insensitive to any load above 4 ohms. The audio oscillator must also produce a signal with relatively low distortion, and the output voltage must not vary as the frequency is adjusted. If a PC signal generator is used, it will usually display the frequency fairly accurately, but you still need to verify that output level is constant with frequency. Many PC instruments are incapable of fractional frequencies, which may limit the accuracy of the final result.
The need for accuracy cannot be stressed too highly if accurate parameters are expected. It should also be understood that there are many variables and many opportunities for things to go awry - during measurement, construction and normal operation. Loudspeakers are variable beasties at best, and 'perfect' results will never be obtained in practice. The room will usually cause more and greater errors than a small measurement error here.
Measure the resistance across the speaker terminals to obtain Re
Measure the exact resistance of the 10 ohm source resistor, Rs
The loudspeaker driver should be suspended in free space, with no obstructions or interfering surfaces nearby. Any boundary closer than around 600mm (about 2ft) will affect the accuracy of the measurements
Connect the circuit as shown in Figure 2, and set the oscillator to approximately 100 to 200 Hz (or around 2-3 octaves above resonance) - it must be within the 'linear' range as shown on the graph above.
Set the output of the amplifier to between 0.5V and 1.0V (this is Vs). Check that the speaker is nowhere near resonance, by changing the oscillator frequency by 50Hz or so in either direction, and measure the voltage across the resistor. It should not change by any appreciable amount.
You may need to try different voltages, depending on the accuracy of your readings (or calculations). Do not be tempted to use a voltage any higher than around 1V RMS , as the speaker may be driven outside its linear range, which ruins the validity of the measurements. The parameters being measured are 'small signal', and it essential that a small signal is actually used. With an 8 Ohm driver, 10 Ohm resistor and 1V signal, you will typically have a nominal current of around 55mA.
Figure 2 - Measuring Speaker Parameters
The traditional way to measure Q is to measure the bandwidth between the -3dB frequencies, then divide the resonant frequency by the bandwidth. For example, if resonance is at 29.6Hz and -3dB frequencies are at 25Hz and 35Hz, then Q is 2.96. This would be Qms in the calculations. This method may be suitable for low-Q drivers, but you can easily make a tiny error (causing a large final calculation error) with high-Q drivers.
Most of the methods described elsewhere rely on a more complex formula that uses -6dB or even -9dB as the reference point to determine Q. This makes the measurement accuracy slightly less critical. The method below describes the -6dB method, which gives a reasonable compromise between ease of measurement and accuracy.
Acoustics 发表于:2008-1-12 18:22:26
First, measure the resonant frequency. Adjust the frequency until the voltage across the resistor reaches a null (minimum level). Without changing anything, carefully measure the frequency and voltage across the resistor ...
FrequencyFs
Voltage across the resistorVm
Calculate the following ...
Speaker currentIm = Vm / Rs
Resonance impedanceRm = (Vs - Vm) / Im
r0 (reference value)r0 = Is / Im
-6dB currentIr = √(Im * Is)
-6dB voltageVr = Ir * Rs
Complete the measurements for Fl and Fh, for which the voltage across the source resistor is equal to Vr, and as a sanity check (to ensure that your calculations and measurements are accurate), calculate the resonant frequency based on these last two measurements. Note that these measurements are critical, and even a small error will cause large deviations in the driver parameters.
Check that ...√(Fl * Fh) = Fs
If the above checks out (within 1Hz or less), then Qes, Qms and Qts can be calculated as follows ...
Mechanical QQms = Fs * √r0 / (Fh - Fl)
Electrical QQes = (Qms / (r0 - 1)) * (Re / (Rs + Re))
Total QQts = Qms * Qes / (Qms + Qes)
You can use the spreadsheet to perform the calculations automatically for you: ls-param.zip
Acoustics 发表于:2008-1-12 18:23:06
Measuring Vas (equivalent air compliance), Method 1
There are two methods for determining Vas. The first is a known box, and the procedure is as follows ...
To measure Vas, use a good solid enclosure of known volume that is approximately a cube of the nominal speaker size. For example, a 300mm driver (12") needs a box of about 28 litres (1 cu ft). For reference, a cubic foot is 28.3168 litres, and one litre is contained by a cube of 100mm (10cm) to each side.
HINT:   If you make all measurements in centimetres, the result will be in millilitres (cubic centimetres, or cc). This makes it very easy to convert to litres ... simply divide by 1,000. If you work in millimetres (mm), the result is less intuitive, although you can still get to litres by dividing by 1,000,000.   (For those who insist on using outmoded measurement systems, I can provide a spreadsheet that uses cubits as the base linear measurement, and firkins for volume. I will part with this upon receipt of a kilderkin of Australian $1 notes or its equivalent <grin>).
Figure 3 - Setup for Measuring Vas
Determine the total volume, including the speaker cut-out and that trapped by the cone with the speaker mounted on the outside of the box for easy access. Measure the resonant frequency in this situation, and use the free air space resonant frequency determined as shown above. Determining the volume trapped by the speaker cone is slightly tricky.
Use one of the following methods ...
  1. Place the driver in a plastic bag, ensuring it is completely sealed. The bag should be loose enough so that it can be pushed easily into the cone area. Place the wrapped speaker on a flat surface, with the cone facing upwards. The cone may now safely be filled with grain (such as rice, wheat, etc), and the grain carefully poured out into a measuring jug. The resulting measurement will be a little greater than the actual volume because the cone will be depressed by the mass of the grain. The area of the speaker cutout in the cabinet must still be added. Don't omit the plastic bag, as fine dust may penetrate the speaker without it.
  2. Take a series of measurements. The internal cone area is measured, then divided into sections whose volume may be calculated. For most speakers we will have two basic shapes to deal with, and although this method is not 100% accurate, it will probably give a more than acceptable result in the majority of cases.
Figure 4 - Determining the Volume of the Cone
There is a flat cylinder (disc) that is formed by the outer area of the basket and the cutout in the enclosure. While there is a small error by just assuming that the cone extends fully (rather than being truncated by the dust cap), the error will generally be small. Since loudspeaker parameters change with time anyway, the error will normally be sufficiently small as to not be an issue. Feel free to measure the cone volume using the alternate method if it makes you feel better.
The volume of the disc is given by the conventional formula ...
Vdisc = π * r² * h    (where r is the radius and h is height)
The cone's volume is given by ...
Vcone = (π * r² * h) / 3
Note that the disc volume may extend to the speaker surround, and the cone diameter may be smaller than the cutout. Make sure you measure both diameters and use the correct measurement for each calculation (as shown in the drawing above).
The total speaker volume is simply the sum of the two volumes calculated above. Box volume is calculated as one normally would, taking great care to ensure that the measurements are accurate. The box may be braced, but must have no fibreglass or other sound deadening material inside. Make sure that the volume occupied by any bracing is accounted for in your calculations. Even a simple box will be sufficiently rigid at the frequencies of interest, so a completely acoustically dead cabinet is not required (although it won't hurt). Do not use any speaker cabinet filling material for this test.
Vas = Vb((Fb / Fs)² - 1)
where Vb is the volume trapped by the speaker and box, and Fb is the resonance frequency of speaker and box combined. Fs is the free air resonance measured previously.
Acoustics 发表于:2008-1-12 18:24:10
An Example Calculation
A dummy test loudspeaker was used to demonstrate the process, and I have used a simulation of this speaker in the calculations shown. The equivalent circuit is shown in Figure 5. This circuit was also used to create the impedance graph shown in Figure 1.
Figure 5 - Dummy Test Loudspeaker
The following screen shot shows the values for the speaker, and the only contrived (i.e. invented) value is for the resonance in the sealed box. It was necessary to invent a number here, as it is not possible to simulate it. The final figure shown is fairly typical of many such drivers, so is not too far from the truth either.
Figure 6 - Test Box Calculation Example Using Spreadsheet
As you can see from the screen-shot, the spreadsheet will calculate everything for you, including the cone volume, Vas and the values shown in the schematic of the driver. Naturally, you will get figures quite different from those shown, but the principle is exactly the same.
Measuring Vas (equivalent air compliance), Method 2
The second method is to use an added mass, M1. Typically modelling clay or Blu-Tak is simply stuck to the cone close to the voicecoil, and the change of resonant frequency allows you to determine the moving mass of the cone. Armed with this, you can then calculate the Vas.
For speakers less than 200mm (8"), use 5 grams, for 200mm use 10g, and for 250mm (10") or larger, use 20g. You may need to add more if the mass chosen does not reduce resonance by at least 10%. The mass must be measured accurately! Even a small error can cause a large variation in the calculated Vas, so a precision scale (accurate to at least 0.1g) is essential.
You also need to measure the effective cone diameter. This is generally taken as a measurement that includes half the surround. Again, an inaccurate reading will make a big difference. Because of this, the test box method is probably more accurate. You don't need to worry about extremely accurate measurements that have a profound effect on the measurement result. Still, the added mass method is quick and convenient, so has been added. The Fs of the speaker in free air has been measured, so simply add a suitable mass to the cone and re-measure the resonant frequency. This becomes Fs¹.
Acoustics 发表于:2008-1-12 18:24:53
First, measure cone diameter so that effective cone area can be determined. Measure the diameter, including half the surround. The measurement must be in centimetres for this calculation. Divide by 2 to get the radius ...
A = π * r²
Calculate cone mass ...
M = M1 / (( Fs / Fs¹ )² -1 )
Next, determine Cms ...
Cms = 1 / ( 2 * π * fs )² * M
VAS = CMS * d * c² * A²
Assume the following ...
d = density of air = 0.00219 g / cm³
c = speed of sound = 3.45E4 cm/s (345m/s)
Let's do a sample calculation using the same driver as before. The spreadsheet has been updated to include both methods, enabling a direct comparison if you use the two different calculations. Everything stays the same, but we no longer have to have a reference box. We also don't need to determine the cone volume, only the area.
For the sake of this exercise, we measure the cone diameter and obtain 200mm, including half the surround. Divide the diameter in millimetres by 20 to obtain the radius in centimetres ...
A = π * r²     = π * 10²     = 314.16 cm²
Next, we measure the driver's resonance with an added mass. The mass was carefully measured, and was 84.60 grams (note that it was indicated above that some drivers will need a lot more mass than may be indicated - this is just such a driver, because it has a heavy cone) ...
M = M1 / (( Fs / Fs¹ )² -1 )     = 84.6 / (( 27 / 23 )² -1)     = 84.6 / ( 1.174 - 1) = 84.6 / 0.174 = 224 grams
Now we can calculate CMS, using the values shown above ...
Cms = 1 / ( 2 * π * fs )² * M     = 1 / ( 2 * π * 27 )² * 224     = 1 / 169.64² * 224 = 1.55E-7
Now that we have everything needed, VAS can be calculated, using the default values for air density and sound velocity ...
VAS = CMS * d * c² * A²     = 1.55E-7 * 0.00219 * (3.45E4)² * 314.16²     = 398764 ml = 39.88 litres
Figure 7 - Added Mass Calculation Example Using Spreadsheet
The spreadsheet will give a slightly different answer (39.95 litres) because it calculates all values to the maximum number of decimal places. The values shown here are limited to two decimal places for clarity. Note that 3 cells (indicated by a small red triangle) have comments attached. The comment will show when your mouse pointer is over the cell. Please read before you go changing anything.
It must be pointed out that the (imaginary) driver used for the demonstration calculations is rather unlikely, so don't expect to get even remotely similar figures. A 250mm driver with a cone weighing in at almost 223 grams would certainly have a low resonance, but would also be pathetically inefficient. However, the important thing here is to show the principles involved and the methods of calculation. Even bass drivers will usually have a lighter cone, so the Vas will be much larger than these demonstration calculations might imply. It's a sad fact of life, but loudspeakers continue to be riddled with compromise. For high efficiency you need a light cone, and a light cone means a large Vas which in turn requires a large enclosure if you actually want to get bass from it.
Acoustics 发表于:2008-1-12 18:27:11
电路部分,是已经将力(和声)部分等效成电。
水仙 发表于:2008-6-23 12:58:00
学习英文资料,也不错!
水仙 发表于:2008-6-23 13:05:31
Cool Edit PRO (功能强大的多轨录音软件)非常出色的数字音乐编辑器和MP3制作软件。不少人把Cool Edit形容为音频“绘画”程序。你可以用声音来“绘”制:音调、歌曲的一部分、声音、弦乐、颤音、噪音或是调整静音。而且它还提供有多种特效为你的作品增色:放大、降低噪音、压缩、扩展、回声、失真、延迟等。你可以同时处理多个文件,轻松地在几个文件中进行剪切、粘贴、合并、重叠声音操作。使用它可以生成的声音有:噪音、低音、静音、电话信号等。该软件还包含有CD播放器。其他功能包括:支持可选的插件;崩溃恢复;支持多文件;自动静音检测和删除;自动节拍查找;录制等。另外,它还可以在AIF、AU、MP3、Raw PCM、SAM、VOC、VOX、WAV等文件格式之间进行转换,并且能够保存为RealAudio格式。
Cool Edit=
水仙 发表于:2008-6-23 13:13:07
http://h-51.15.52z.com//down/cr-cooledit.rar
technics 发表于:2008-6-24 11:22:47
学习
ZY 发表于:2008-6-27 9:15:56
正准备用“Cool Edit PRO”作信号源做连续负荷测试。
benny0130 发表于:2008-6-27 13:07:29
這個網站太好了,謝謝樓上,每次來都有新發現,果真是入寶山阿
Have a nice weekend
jqr01 发表于:2008-10-18 19:13:11
T/S参数是什么东西,学习!学习!
lch311 发表于:2008-10-27 21:04:11
英文的看着头发晕,哎
henley_z 发表于:2008-11-13 15:50:38
cooledit录音用过
gcc 发表于:2009-1-18 21:55:21
cooledit
用过
