共10 条记录, 每页显示 20 条, 页签: [1]
标题:求助:BASSBOX 和lspcad
xiushuicunren 发表于:2010-10-24 15:36:52
各位,对于音箱设计软件的BASSBOX和LSPCAD:
请各位给一个性能或功能比较和目前的大致的价格。
如果一个小的音箱厂,选用哪一个好?
水仙 发表于:2010-10-24 22:16:08
http://www.nju520.com/bbs/dispbbs.asp?boardid=2&id=2613&authorid=0&page=0&star=1
水仙 发表于:2010-10-24 22:16:59
图片点击可在新窗口打开查看  BASSBOX pro version 6   $149.00
[此贴子已经被作者于2010-10-24 22:17:43编辑过]
水仙 发表于:2010-10-24 22:18:25
http://www.ht-audio.com/pages/BassBoxPro.html
水仙 发表于:2010-10-24 22:21:35
LspCAD 6 pro, no upgrade (EUR800)
水仙 发表于:2010-10-24 22:21:51
http://www.ijdata.com/LspCAD_buy.html
水仙 发表于:2010-10-24 22:24:10
Build history
LspCAD 6.37 (2010-08-07)
+ Small LspCAD logo added to graphs
+ Highest node number was not possible to measure (voltage)
LspCAD 6.37 (2010-06-20)
+ Optimizer: Phase optimizer did not compute actual phase
+ TS driver: Praxis import not working properly
+ DXC2496
+ Bypass and Invert checkbox did not have any effect
+ Step up/down of parametric EQ Q-value
+ Main window. Component list made scrollable
LspCAD 6.37 (2010-05-15)
+ Polar map did not work with TS driver components
+ G(s)/G(z) component, 1st and 2nd order
  allpass added to BiQuad filter
+ TS import (Praxis, Klippel, Clio) did not always work
+ Diffraction analysis speed improved considerably especially
  when used with polar plots
+ Accuracy of loss model in horn component improved,
  works well with concatenated transmission line segments
+ Optimization of advanced boxes did not always work
+ Open component ialog boxes now update properly when optimizer runs
+ Emulator, ASIO input channel range increased
LspCAD 6.36 (2009-08-23)
+ Possible to optimize impedance with phase target
+ List of missing files presented when projects are opened
+ RichEdit controls replaced to solve issue with non-western character sets.
LspCAD 6.35 (2009-05-09)
+ Use of recall buttons could result in loss of imported data
+ Sqrt domain error related to off axis simulations fixed
+ Delay value in driver component not correctly applied if "As drv 1" checked
LspCAD 6.35 (2009-04-04)
+ Optimizer, modeling of Q-value wrong by a factor 2.0
+ Off axis power response, possible to select RMS sum instead of complex sum
LspCAD 6.34 (2009-03-08)
+ Behringer DCX2496 and XTA. Change of EQ did not update EQ slope in dialog.
LspCAD 6.34 (2009-02-14)
+ Valentines day version !
+ Min value for Vas changed to 0.001l
LspCAD 6.34 (2008-12-14)
+ Occasional atan2 error fixed
+ Optimize checkbox did not work properly for advanced box mode
+ Recall sets could cause loss of reference to SPL/impedance data
  if files was located in different folders
+ Baffle diffraction simulations did not always update properly
+ Problems with relative paths fixed
+ Optional to use off axis phase lag modeling
LspCAD 6.34 (2008-08-17)
+ Simulated SPL for speaker boxes, changed to true 4pi radiation
  -->  -6dB difference difference from previous versions.>
LspCAD 6.34 (2008-08-13)
+ Horn component, bugfix for conical horns
+ Locations of imported data stored as relative paths with project file location
  as referense, this makes it more simple to distribute project files.
+ Behringer DCX2496, number of EQ elements increased to 9
LspCAD 6.33 (2007-10-21
+ Ke (semiself inductance), max value set to 10sH
+ Parametric EQ using BuQuad filters
   (Behringer, DBX pro, XTA and G(s)/G(z) component).
  Erroneous implementation caused wrong implementation of Q factor setting.
  The resulting Q was wrong by a factor 2.0.
+ Bandpass box (advanved box), rear box properties did not cause an update of the
  screen
+ Recall button did not update screen correctly if working/display range updated.
LspCAD 6.33 (2007-06-30)
  New stuff
+ Driver component
+ Extended SPL data format
+ Larger loss factors allowed in ports.
+ Possible to optimize Ke in TS driver component
+ Digital BiQuad filter, Pole-shifter added
+ Complex impedance component, limitation to 200ohm removed.
+ Off axis simulation to +/-180 deg possible (also for polar plot)
  Bug fixes
+ File close was missing in TS driver component, casued
  problem when Store/Recall buttons used.
+ Extra check for window placement when program started.
+ Switch component, unstable simulation condition fixed.
+ Passive radiator box template
+ Optimize main switch did not work properly in advanced mode.
LspCAD 6.32 (2006-10-17)
+ justMLS
+ Possible to set buffer size.
+ Initial dry run time increased to 200ms
LspCAD 6.32 (2006-10-13)
+ justMLS
+ Measurements more stable
+ Behringer DCX2496, XTA and dbXPro component
+ Bessel filter at low frequencies had wrong response due to
   fix build 2006-10-09
+ Node analysis
+ Designs using horn component created close to unstable simulations
   due to fix in build 2006-10-09
LspCAD 6.32 (2006-10-09)
+ Save button in main window
+ dbXPro component
+ XO frequencies was not possible to modify
+ Berhringer DCX2496 and dbXPro component
+ Corner frequencies was not correct for odd order and
   bessel filters at high frequencies
+ XTA component
+ Crossover emulator
+ Support for ASIO cards with up to 18 output channels
+ Input channel pairs 1&2-15&16 adressable (ASIO)
+ Optimizer
+ Position of legend is kept during session
+ justMLS
+ Possible to select DirectSound or ASIO soundcard access.
   For ASIO access it is also possible to select input for ch1 and ch2
   (input ch 1-16)
+ screen size can be adjusted
+ soundcard setting saved in justmls.cfg
+ Store path for justmls.cfg and justmls.cal stable
LspCAD 6.31 (2006-08-29)
+ Digital input working (ASIO mode)
  + Int24, Int32 and Float32 support.
  + Security measure to avoid lockups under high CPU load conditions introduced.
+ Crash bugs related to store/recall and also project save/switch solved
+ Complexity of circular convolution reduced somewhat.
+ Excessive memory usage in digital filters fixed.
+ Emulator streaming temporarly stopped when Recall buttons pressed
+ Optimizer
+ Opt switch in groups not saved in project files
+ Store/Recall buttons disabled when optimizer running
+ Recall executed twice by mistake when recall button pressed.
+ Log10 sing error related to the use of GS, DCX, DBXpro and XTA components fixed.
LspCAD 6.30 (2006-06-07)
+ Optimizer
  + Setup of optimization simplified as "optimize with respect to .." setting is removed
  + XO point lock is improved with a lower risk of divergent behavior.
  + Grouped components has a main optimize checkbox option, this makes it
     possible to turn off optimization for entire filter sections with just
     one operation
  + ASIO support, possible to select input pair for multi channel input ASIO cards.
  + Emulator was not closed correctly in certain conditions.
  + Emulator is always on top.
  + Noise bursts when R1..R8 buttons used removed
+ Store/recall sets saved at correct locations, for instance if one click on S3 and
   save the project the set will be available at R3 when the project is opened again.
+ Possible to set orientation of T/S drivers, side mounted drivers now possible to model.
+ Snapshot, a few bugs fixed.
+ Schema, can be printed with option fit meaning that the schema printout fills the entire paper.
LspCAD 6.20 (2005-11-23)
+ Klippel TS import, Sd, Vas and Mmd was not imported properly
LspCAD 6.20 (2005-11-18)
+ R1..R8 button,
  + Large memory leak problem, partly fixed.
     Still some memory leak problem though.
  + Crash problem when used with crossover emulator fixed.
  + Noise problem when used with crossover emulator fixed.
+ T/S parameters, some parameters accidentially optimized even though they was not selected for optimization.
LspCAD 6.20 (2005-11-03)
+ Port resonance frequencies not updated correctly in certain cases.
+ Store/Recall sets, severe bug (program crash) fixed.
+ Buttons/menu picks makes it posible to bring Main form, graph and schema to front, very handy for low resolution monitors.
LspCAD 6.20 (2005-10-11)
+ G(s) G(z) component, Digital phase lineal FIR filter component added, possible to simulate and
   export filter coefficients for FIR filters with filter orders 129..4097 with various window options.
   Open examples/phase linear digital XO.lsp for an example how this can be used in a
   digital phase linear loudspeaker system.
+ Crossover emulator, Variable Causal filter margin, this feature is needed to avoid that crossover
   emulator impulse response is chopped off in beginning
LspCAD 6.20 (2005-10-09)
+ Store / Recall (S1...S8, R1..R8) sets saved when LspCAD closed,
   reloaded when LspCAD started.
+ Crossover emulator. Impulse response exported automatically to LspCAD folder
   when Circular convolution used. Filename of exported coefficients is
   LspCAD_6_xo_emulator_1.txt, LspCAD_6_xo_emulator_2.txt etc.
   Fileformat is ASCII text format with one coefficient per line.
   Impulse response can be used e.g by BruteFIR.
+ Near boundary reflections only case improved somewhat.
+ Horn component
  + Pens saved
  + Loss model improved, possible to use component when simulating transmission lines.
+ Non linear/thermal modeling, warning message displayed when main switch in
   settings dialog is not enabled
LspCAD 6.20 (2005-09-27)
+ Digital BiQuad filters (G(s)/G(z) component), Max sample rate increased to 200kHz,
   Possible to quantize filter coefficients
+ Bassreflex port, possible to set end correction multiplier to simulate eg port locations close to corners.
xiushuicunren 发表于:2010-10-25 8:51:48
谢谢水仙超版了!
看来,这些软件也是有学前班、初级班和高级班一样的差别的。
先从简易的开始,“等积累了利润”和知识后再升级了。
Thank you very much !
[此贴子已经被作者于2010-10-25 08:52:15编辑过]
DAAS 发表于:2010-10-25 17:37:21
准备自己上了?
多面手,牛人也。
xiushuicunren 发表于:2010-10-26 9:39:34
以下是引用DAAS在2010-10-25 17:37:21的发言:
准备自己上了?
多面手,牛人也。
哪里哪里!
只是先前没有机会(其实也不必要)去用这些软件去设计音箱,大不了就是手工计算或交给别人代工,慢一点也就是了。
那些前辈在没有这些软件前,也得设计的呀。
先手工,后计算机辅助,可能也是一个必然的路。
买了软件,会有人去用的。而且,总得有一点家底吧?
Processed in .04700 s, 2 queries.
