标题:扬声器音压分析
db 发表于:2007-6-18 21:05:06
db 发表于:2007-6-18 21:06:48
db 发表于:2007-6-18 21:08:24
db 发表于:2007-6-18 21:22:52
转到设计室更合适.
lin 发表于:2007-6-18 22:28:32
不错!
ldb202020 发表于:2007-6-19 10:59:55
很多都看不清楚,不过内容还是不错的!
YANDONG7383 发表于:2007-6-19 16:38:27
謝謝!
Acoustics 发表于:2007-6-19 17:26:22
好好学习!
yufengyin 发表于:2007-6-19 17:52:23
顶一下
松香味 发表于:2007-6-20 9:17:19
非常好的讨论内容,就是看的不清楚,是否可以怎么处理下让大家看清楚些就好了。
由于看不清楚,不知道是否涉及声功率压缩、分割振动等方面的问题吗?比较关心这些问题。
luhuiweihui 发表于:2007-6-20 19:43:55
谢谢提供!
luhuiweihui 发表于:2007-6-20 19:45:32
以下是引用松香味在2007-06-20 09:17:19的发言:
把图片放大些!很清楚!
音响初哥 发表于:2007-8-17 23:29:01
台湾人编的某软件教程?
liuqing 发表于:2007-12-15 19:57:32
bu cuo!
真的不错!要是文字部分再清晰些就完美啦!
不过,还是要力顶!
qp 发表于:2008-1-12 10:28:28
谢谢DB兄的资料提供!顶一个
jma 发表于:2008-1-12 11:19:19
强人!
偶是达不到这个水平了!
Acoustics 发表于:2008-1-12 17:13:12
JMAG-Studio 9.0
MODULELatest versionUpdated
JMAG-Studio Service Pack9.011012007-11-30
JMAG-Studio Installer9.011012007-11-30
Manual 2007-08-06
Tutorial 2007-08-06
JMAG-Studio RemoteSystem2.1.72007-08-06
JMAG-CATIAv5R17sp02007-08-06
JMAG-Studio x64(64bit Windows)
Installer
9.01101_x642007-11-30
JMAG LINUX Installer9.011012007-11-30
Acoustics 发表于:2008-1-12 17:17:16
Sound Pressure Analysis of a Loudspeaker
Overview
A loudspeaker produces sound when current flowing through the voice coil interacts with the magnetic field generated by the magnet, causing the paper cone connected to the coil to vibrate.
The general requirement for better quality is to produce uniform sound over a wide range of frequencies.
JMAG can obtain the sound pressure distribution using the electromagnetic force and eigenfrequency calculated by the magnetic field analysis and structural analysis.
This note presents the case study of the frequency characteristics of sound pressure.
图片点击可在新窗口打开查看 Sound Pressure Level
Sound pressure level at the front center of the loudspeaker is compared for the different frequencies.
Sound pressure level is found to be low at the frequency below 200(Hz).
Sound pressure is determined by the eigenfrequency since the Lorentz force is constant regardless of frequency.
图片点击可在新窗口打开查看 Eigenvalue Analysis
As a result of an eigenvalue analysis, 210(Hz) is obtained for the first eigenfrequency.
To increase the sound pressure level at the frequency below 200(Hz), the first eigenfrequency needs to be decreased.
The eigenfrequency may be lowered by increasing the mass or using a damper.
图片点击可在新窗口打开查看 Vibration Analysis
JMAG enables the simulation of vibrations that produce sound.
As the frequency increases, the vibration increases similarly to the frequency characteristic of the sound pressure level.
Acoustics 发表于:2008-1-12 17:24:55
JMAG
      JMAG是由株式会社日本総研(JRI Solutions, Limited)开发出来用于电磁场计算的新一代分析设计软件工具。十几年来,JMAG被日本众多企业、高校、研究机构选用,其无以伦比的技术优势取得了良好的应用效果。JMAG完善、改进的设计界面可确保设计人员顺利完成分析任务。它的自动网格剖分功能不仅能使一般用户在分析过程中无需考虑网格问题,更能极大限度地满足专家的分析要求。利用JMAG,初级用户也能得到高精度的分析结果。
主要特点
  • 分析数据检验功能DXF、Universal、SAT、IGES(3D)、CATIA(ver.4, 5)等CAD文件的直接读入使得JMAG-Studio即可进行自动网格剖分;
  • 齐全的材料物性数据,包括磁化特性和损耗数据等;
  • 强大的网格自适应生成技术;
  • 方便灵活设置与收集各种磁化曲线;
  • 可获得磁滞损耗和涡流损耗共同作用产生的磁损耗数据;
  • 可与流体传热、结构应力耦合分析;
  • 可输出多达几十种物理量,包括磁通量、磁通量密度、电磁力、扭矩、转矩、能量、磁场强度、涡流电流密度、损耗、电流、阻抗、电感及电压等;
  • 能够进行优化计算,电感计算, 与MATLAB/Simulink耦合计算;
电磁转子CAD转子网格
磁场可视图
其他功能
    分析数据检验功能,分析结果输出报告 矢量、云图、曲线、表格显示,动画,任意造型功能,参数化分析工具,支持Script脚本,2D和3D自动网格剖分,最优化网格生成(自适应网格);模拟运动时的自动“贴片”(patch mesh)网格生成,用于旋转机械的“滑动”网格,用于旋转机械的“气隙”网格(支持斜槽式电机),灵活的FlexLm网络license管理,UNIX求解器的远程调用功能,PC机间的远程调用。
强有力的CAE技术支持
    西迪阿特公司利用自己的丰富经验还为客户提供完整的的技术支持服务,为客户解决设计制造过程中碰到的问题。针对初级用户,我们会组织专家举办各类不同技术层次的技术研讨会,利用日本综合研究所具有的研发能力为用户提供专业的技术支持服务,确保用户成功应用仿真工具。此外,通过email、传真、电话等方式,由富有经验的技术人员直接提供技术支持服务;通过年会、研讨会或者采用咨询、外包等方式为用户提供全面的技术支持。
Acoustics 发表于:2008-1-12 17:33:15
磁场分析
应用领域
    直流有刷电机,直流无刷电机,感应电机,同步电机,直线电机,永磁电机,步进电机,变压器,起动器,螺线管阀,磁记录设备,磁头,传感器,涡流缺陷检测,扬声器等等
PM 步进电机斜槽电机盘式电机
功能
   2D 静态分析,2D 谐波分析,2D 瞬态分析
   3D 静态分析,3D 谐波分析,3D 瞬态分析
磁场分析结果
    磁通,磁通密度,电磁力,力矩,磁场,电流密度,损耗,电流,电感,电压等
分析结果网格划分CAD 模型
特点
  • 易用的材料数据库
    通过和日本的主要材料厂商合作,程序中自带知名厂商的材料的磁化B-H曲线和铁耗数据,方便您的使用。进行磁场分析,您可以选用相类似的材料类型就可以计算了。如果您想自己计算,也很容易创建自己的数据库,满足您的运算需求。
材料库
  • 铁耗分析工具
    通过磁场分析结果,可以分别计算出磁滞损耗,涡流损耗和铁耗。可考虑压力因素。
铁耗磁滞损耗涡流损耗
  • 电感计算
      通过使用简单的工具可以从复杂的电机模型中计算电感。
  • 强大的电路生成器
    JMAG提供了电路生成器,提供了多种电路元件,包括电阻,开关,电容,二极管,电刷等,配合主程序进行磁场分析,也可以使用宏组件功能。
  • 自动网格生成功能
自动2D & 3D 网格划分
自动优化网格功能 (adaptive mesh)
运算中自动网格生成 (patch mesh)
旋转机械(电机)中创建滑移网格
旋转机械(电机)中创建气隙网格(skew compatible)
方便灵活设置磁化曲线
用户通过GUI就可以方便设定各种磁化曲线,包括各向异性磁化曲线。同时,也提供了在不同模型间映射磁化方向的功能。
  • 自适应网格功能
    使用自动网格功能,JMAG可以自动创建分析所需的优化网格,即使初学者也能够得到高精度的分析结果。 尤其对那些复杂模型,如齿轮扭矩计算中难以处理的网格,这一功能尤为重要。
  • 杰出的耦合分析功能
      JMAG-Studio能够解决复杂的耦合问题。磁场分析能够与热、结构,噪声分析同时进行。此外还能进行不同网格类型间的耦合分析,例如2D磁场分析/3D热分析,2D磁场分析/3D结构分析。
  • 耦合热分析
    热力分析,包括稳态和瞬态,可以很容易的和磁场耦合。在计算中,温度与材料的磁属性和热属性相关。
  • 耦合结构分析
    采用磁场分析结果,可以进行压力分析,振动分析,离心力分析,接触力分析。也可以在磁场分析的时候根据压力分析结果考虑变形问题。
   IPM电机上的简单接触分析(离心力)
使用mapping 功能进行2D 磁场/ 3D 振动耦合分析
