标题:[求助]关于SpeaD上喇叭材料的几个问题
xian-gen 发表于:2006-4-25 15:54:25
谁用过SpeaD模拟喇叭?
Magnet Material, 磁铁等级有Ceramic 5/6/8, 与Y25/30/32/35等有没有对应关系, 或是两种不同的磁铁?
Metal Material, 上下板材质等级Low Carbon Steel 1018/1013/1008含义如何, 哪种更好?我们常用的是哪一种?
Acoustics 发表于:2006-4-25 16:00:59
Motor Parts
1. From the Menu item Motor Material, select the magnet material Y30 This is a standard Asian material that is roughly equivalent to Ceramic 5.
2. From the Menu item Metal Material, select the metal LCS1013. This is 1013 low carbon steel. It is the most common Asian steel used in loudspeakers.
3. We know from our vendor sheets that the standard magnet dimensions for a 40 Oz magnet are 140 OD x 20 TH x 75 ID. With these, we can estimate that our front and back plate OD should be roughly 10mm smaller in diameter if we are going to use a 10mm Frontplate. This means a Plate OD of 130 mm.
4. From the Frontplate Outside Dia. drop down box select 130.
5. From the Frontplate thickness drop down box select 10. (Notice that there are two parts with a 130mm OD because the thickness box shows both 8 and 10mm available.)
6. Click on the Voice Coil Active Label Information by running the mouse over the label and clicking when you see a highlight box appear. If you hold the mouse down you will see additional information about the voice coil design including a Recommended Front Plate Inside Diameter. The ID that it recommends is 54.4mm.
7. In Frontplate Inside Diameter type 54.4 (Or select it from the drop down box) <Enter>
8. Enter the dimensions that we already know for a 40 Oz magnet in the appropriate boxes under magnet (140 OD, 20 Thickness, 75 ID)
9. We already know that the OD of the metal parts will be 130 so from the Backplate Outside Dia. drop down box select 130 <Enter>
10. It is common to match the plate thickness so select 10mm for the Backplate thickness. <Enter>
11. The gap between Pole OD and Voice Coil ID is typically set by the manufacturer to allow clearance for production and a small amount of yaw at high levels. The Standard amount usually runs about .3mm on this size coil so the Pole OD should be .6mm smaller then the Voice Coil ID. This would be 48.95mm. Enter this value for Pole Diameter. <Enter>
12. For now we will leave the pole extension at the default of 0.
13. Using the drop down box on Vent hole diameter select 25mm <Enter>
14. The motor design should now be complete and you can go to the Motor Parts Active Label for more information including Bg. You can also see the percentage saturation for the metal parts by pressing the colored bars under each part.
Acoustics 发表于:2006-4-25 16:22:13
Manufacturers Databases
The following are databases from major manufacturers of magnets and motor materials.
To enter these into your SpeaD preferences folder download the files to c\program files\redrock\spead\partsDB.
download Hiticahi magnets
download DMEGC magnets
download General Magnetics magnets
download Alpha Products front plates
download Alpha Products back plates
Acoustics 发表于:2006-4-25 16:23:06
软件价格:
SpeaD/Reverse SpeaD Pricing
We accept Visa/Mastercard, American Express, checks (please make payable to SpeaD and use the address below) and wire transfers (please include an additional $25 for bank fees when wiring funds).
Redrock is the sole distributor of the software so all orders are processed through us (click here to email).
Below is the pricing structure for the software. All packages are shipped via Fed Ex 2 day.
SpeaD $1730 USD buy now
Reverse SpeaD $ 530 USD buy now
SpeaD/Reverse $2030 USD buy now
No demo Version is available. We do offer a 30 day money back guarantee.
Discounts are available for purchasing multiple copies on the same PO. Please contact us for details
Acoustics 发表于:2006-4-25 16:23:57
SpeaD
Update Instructions
This update only replaces the SpeaD.EXE file.
Download the file to the SpeaD folder ( C\program files\redrock\spead if you used the default path) Unzip SpeaDUpdate103.exe by double clicking on the file. It will prompt you that the files already exists and ask if you want to overwrite the file. Answer yes.
download version 1.0.3
Reverse SpeaD
To install: Download the file. Double click and follow instructions.
download Reverse SpeaD NT version 1.0.1
download Reverse SpeaD Win 95/98 Version 1.0.1
xian-gen 发表于:2006-4-25 16:42:20
鬼佬老板才给了我一套SpeaD/Reverse,我就试用一下, 我是搞不清楚Magnet Material和Metal Material的等级与实际中用的怎么去对应.
平时只知道Y25/30....;那Ceramic 5/6/8又是怎么一回事; 平时用的T铁和华司,各位有向供应商要 1018/ 1013/ 1008这样等级证明吗?
Acoustics 发表于:2006-4-25 17:07:35
横店东磁是一家集生产、经营、科研、技术开发及信息服务为一体的科技先导型国家大型一档企业。公司现辖有60余家磁性电子器材企业,有职工一万四千多人,拥有国际先进的全自动磁性材料检测装置和国内最先进的示范化生产线。公司主要生产永磁、软磁、塑磁、稀土永磁、扬声器、微电机、硬质合金、金刚石砂轮、电容器、真空镀膜、电池、门业、铝箔、亲水箔等十四大类3000余种规格和品种的产品。
  东磁现已具备年产10万吨永磁预烧料和年产8.5万吨永磁铁氧体、3万吨软磁铁氧体的生产能力,是世界第一永磁预烧料和永磁铁氧体生产基地,是全国最大的软磁铁氧体生产基地。公司自1993年开始自营办理出口业务,有80%的产品出口到日本、美国、韩国、东南亚等四十多个国家和地区,仅2004年公司实现销售收入27.53亿元,全年完成出口交货值19.5亿元,其中自营出口创汇突破7100万美元,创利税3.8亿元。名列2004年第十七届中国电子元件百强企业第5名,第十八届全国电子信息百强企业第51名。
  东磁从1987年开始全面推行TQC工作,建立健全了质量管理体系。是全国磁性行业中首家通过ISO9002质量体系认证和QS9000质量体系认证的企业。2000年12月被国家农业部授予“国家乡镇企业质量管理先进单位”称号。99年12月,经国家人事部批准建立了全国磁性行业第一座国家级博士后科研工作站,为东磁高科技项目的开拓打下了坚实的基础。2000年,东磁被国家农业部评为全国乡镇企业创名牌重点企业。并被省人民政府命名为首批排头兵企业和管理示范企业。2004年东磁公司近年来加大了科研开发的力度,不惜代价引进国内外技术权威人士、博士后、高级工程师等高品位工程技术人员从事磁性材料等新技术、新工艺的研究。目前,由我公司开发成功的抗干扰磁芯、高性能电机磁瓦、微波炉磁体等产品已形成大批量生产,其中微波炉磁体是国内唯一能生产的厂家,产量已超过世界总量的60%。
  “永无止境追求质量完美,一丝不苟满足顾客需求”是东磁人坚持不懈的奋斗目标和行动指南。东磁人将永远遵循“团结、求实、开拓、奋进”的企业精神,励精图治,勇攀高峰,与国内外朋友一道共同发展。
  电话:0579—6588888 传真:0579—6551157 邮编:322118
  电子信箱:DMOFFICE@public.dy.jhptt.zj.cn
  网址:http://www.chinadmegc.com
DEEGC即东磁!
HITACHI是日立!
Acoustics 发表于:2006-4-25 17:09:17
一是东磁牌号(Y30)
另一是日立牌号(Ceramic 5)
Acoustics 发表于:2006-4-25 17:16:46
国内常用低碳钢(估计类似A3钢)
Metal Material
The Metal used in the Frontplate, Backplate, and Pole piece can have a substantial effect on the overall performance of a speaker. SpeaD can model virtually any material by way of its Metal libraries. Typically speakers in the US are built with 1018 Low carbon steel. (Asian parts use 1013 steel). The carbon content in the steel determines the magnetic characteristics. Generally, lower levels of carbon yield higher Magnet strength. SpeaD has models for many common materials. The SpeaD website will be constantly updating the material libraries which can be placed in the Material Library folder.
Typically speakers in the US are built with 1018 Low carbon steel.美国常用1018低碳钢
ALPHA不知是哪家公司?
Acoustics 发表于:2006-4-25 17:18:17
这里可以直接下载材料数据!
CY 发表于:2006-4-25 20:59:56
用SPEAD加上词霸全部都可以搞定了,何必笨呢??????????
DAAS 发表于:2006-4-26 13:01:11
以下是引用CY在2006-04-25 20:59:56的发言:
哎,兄弟偶就这样笨过, 笨,早知道抛个几k出来,请个翻译伺候了.....
水仙 发表于:2006-4-26 14:28:49
词霸翻译不出DMEGC
卜凡 发表于:2006-6-14 19:24:34
以下是引用水仙在2006-04-26 14:28:49的发言:
词霸翻译不出DMEGC
还有很多都翻译不出来的!!!
原声 发表于:2006-6-16 14:02:17
是啊,很多专业词汇都翻译不准!
电声爱好者 发表于:2006-8-1 13:00:59
以下是引用xian-gen在2006-04-25 15:54:25的发言:
谁用过SpeaD模拟喇叭?
FEMM里面的材料库要少些,名称类似.
谁有材料库的TXT文档?如磁性材料和导磁材料的?
电声爱好者 发表于:2006-8-1 13:35:50
Cone Fo
The cone Fo is the standard compliance measurements for cones and edges. It is available from cone suppliers or can be measured using a standard Fo analyzer. It is important this measurement be taken under the same conditions that the speaker will be tested. Temperature and humidity can cause dramatic changes in this test because of the relative instability of rubber and foam typically used for edge material and moisture retaining cone materials such as untreated paper. This measurement is difficult to make accurately for very high compliance materials such as butyl or santoprene edge. Unsecured clamping around the entire edge, sag, and conflicting resonance of the driving speaker can all contribute to errors in this test
电声爱好者 发表于:2006-8-1 13:49:35
Sd
The cone area of the speaker. This is defined by measuring from the diameter from the inside 1/3 of the edge roll, and then calculating area.
WANGFUYU 发表于:2006-8-7 19:18:30
Acoustics说得完全正确,我查了一下FEMM软件库中关于CERAMIC 5的参数是:
Br=0。394T,Hcb=191KA/m,再对照东磁关于DM30的定义:Br》0。38T,Hcb》184KA/m,就很明白了,
WANGFUYU 发表于:2006-8-7 19:20:49
至于1008,1013等称号是指含碳量 8/1000,13/1000,都是低碳钢
