共4 条记录, 每页显示 20 条, 页签: [1]
标题:L-PAD
helen0507 发表于:2008-8-22 21:09:30
請教各位DX, 哪裡有L-PAD銷售?
XLB 发表于:2008-8-23 10:02:12
L-PAD为何物
Acoustics 发表于:2008-8-24 18:23:05
? L Pad  calculator for loudspeakers ?
For attenuation A (damping) use here a positive dB value as convention.
L-Pad Pic=     L-Pad Formula=
For attenuation A use here a negative dB value as convention.
L-Pad Formula=
Calculate the resistor network
The calculator below needs a positive value for A in dB
Impedance Z: ohms
Attenuation A:  dB
L-pad Single resistor
R1 = Rserial:  ohms R:  ohms
R2 = Rparallel:  ohms
Ztotal:  ohms       Ztotal:  ohms
Calculate the attenuation
Impedance Z: ohms
R1 = Rserial:  ohms
Attenuation A:  dB
Ztotal:  ohms
dB Z R1 (ohms) R2 (ohms)
  -3 4 1.17 9.70
  -6 4 2.00 4.02
  -9 4 2.58 2.20
-12 4 3.00 1.34
-15 4 3.29 0.87
  -3 8 2.34 19.39
  -6 8 3.99 8.04
  -9 8 5.16 4.40
-12 8 5.99 2.68
-15 8 6.58 1.73
helen0507 发表于:2008-8-25 15:27:03
在哪裡可以買到?
