共7 条记录, 每页显示 20 条, 页签: [1]
标题:寻音膜组件
lwg1983 发表于:2008-11-21 9:50:39
请问各位兄弟,那家此两种组件和后盖
lwg1983 发表于:2008-11-21 9:51:35
新绿 发表于:2008-11-21 10:47:02
General specifications
Power Rating (AES, W rms) 75
Nominal impedance (?) 8
Frequency range (Hz) 1200-20000
Sensitivity (dB) 110
Minimum crossover (Hz) 2200*
Voice coil diameter (mm/in) 44.5/1.75
Diaphragm material PETP film
Magnet material Neodymium
Mounting Information
Width (mm/in) 90/3.5
Depth (mm/in) 58/2.3
Weight (kg/lb) 0.75/1.7
Fitting Screw (35mm, 1.38in diameter)
Throat exit / diameter (mm/in) 25.4/1
Packed Dimensions and Weight
Single pack size W x D x H (mm/in) 90 x 90 x 60/3.5 x 3.5 x 2.4
Single pack weight (kg/lb) 1/2.2
新绿 发表于:2008-11-21 10:48:15
http://professional.celestion.com/pro/products/cdx/detail_specs.asp?ID=7
celestion公司有!可以直接跟他们购买成品.
lwg1983 发表于:2008-11-21 11:30:20
celestion公司有,是的,我不要成品,我要的是音膜组件和后盖
谢谢楼上的美女
lwg1983 发表于:2008-11-24 10:21:55
难道没有那位兄弟有啊
我急用啊!!!
有的请速与我联系:0574-83072501  李
lwg1983 发表于:2008-12-2 7:57:13
唉。
竟然没有哪位有啊?
郁闷啊!!!!!!
