共7 条记录, 每页显示 20 条, 页签: [1]
标题:Rohacell foam夹心的三明治音膜
jordanlin 发表于:2010-1-17 21:54:38
请问各位DX,那一家股纸厂有做以Rohacell foam为夹心的碳纤三明治音盆?
谢谢.
爱拼才会赢 发表于:2010-1-19 8:33:43
ROHACELL?? The Core for Sandwich Solutions
The ROHACELL?? name is recognized in the worldwide composites structures market for it's outstanding thermal and mechanical properties, in addition to offering the highest strength-to-weight ratio when compared to all other cellular plastic foam cores. All ROHACELL?? foam core grades are based on polymethacrylimide (PMI) chemistry
爱拼才会赢 发表于:2010-1-19 8:38:00
对铝面板聚甲基丙烯酰亚胺(PMI)泡沫芯夹层材料进行了弯曲、平拉、压缩、剪切、侧压等试验,得到了弯曲、平拉、压缩、剪切、侧压等性能数据,为采用铝面板PMI泡沫芯夹层 ...
看来这种材料做NXT平板扬声器不错, 若比较薄的话,也可以用在NXP 1115或0812上.
爱拼才会赢 发表于:2010-1-19 8:41:25
The Structural Foam that Has that Certain Something
The principle of increasing the rigidity of components by means of sandwich structures is now well established. ROHACELL?, a PMI-based structural foam, has been used for this purpose in fiber-composite technology for more than 30 years. And it's no accident that ROHACELL? still predominates in the area of high-grade lightweight construction. The product owes its success to such outstanding features as:
  • excellent mechanical properties over a wide temperature range, even at low densities;
  • high temperature resistance up to 220°C;
  • unique compressive creep behavior for processing up to 180°C and 0.7 mPa;
  • excellent dynamic strength;
  • and cell sizes that can be adapted for each processing method (autoclave, resin injection, press molding, Quickstep?, etc.).
The 100 percent-closed-cell foam absorbs resins only in the truncated cells at the surface. This prevents excess resin from infiltrating further into the foam, which would add unnecessary weight, and also helps during vacuum fixation during mechanical processing. ROHACELL? can be processed by shaping or turning, among other methods, and can be excellently thermoformed at low cost, too.
爱拼才会赢 发表于:2010-1-19 8:44:49
Sales range for ROHACELL? A
ROHACELL? Size [mm] Standard sheet thickness [mm] Possible sheet thickness [mm]
31 A 2500 x 1250 4 to 90 1 to 140
51 A 2500 x 1250 4 to 80 1 to 120
71 A 2500 x 1250 4 to 65 1 to 100
110 A 2160 x 1100 4 to 55 1 to 90
Thickness tolerance +/- 0.2 mm, other tolerances available on request
爱拼才会赢 发表于:2010-1-19 8:58:38
图片点击可在新窗口打开查看此主题相关图片如下:properties of rohacell a.jpg
yun 发表于:2012-5-3 18:07:15
看不懂,
PMI能做到0.3-0.5MM的厚度吗?
