共183 条记录, 每页显示 20 条, 页签: [1] [2][3][4][5][6][7][8] ...[10]
标题:音圈线材性能一览
Acoustics 发表于:2006-10-10 8:57:40
音圈线材性能一览:
IEC European Wire Types
ELEKTRISOLA - Product-NamePolysol 155Polysol 180Estersol 180Amidester 200Amidester210ML240
ELEKTRISOLA - Product-CodeP155P180E180A200AI210
General
Descriptionmod. Polyurethanemod. PolyurethanePolyesterimideTheic-mod. PolyesterimideA200 + Polyamidimidearomatic
Polyimide
Standards:
IEC (including the following norms)IEC 60317-20, IEC 60317-4IEC 60317-51, IEC 60317-20IEC 60317-23, IEC 60317-3/8IEC 60317-8IEC 60317-13 IEC 60317-46, 60317-7
NEMA (including the following norms)MW 79, MW 2, MW 75MW 82, MW79, MW75MW 77, MW 5, MW 26MW 74, MW 5, MW 30MW35, MW73MW 16
UL-approvalyesyesyesyesyesno, JW 1177
Diameters available0.010 - 0.50 mm0.010 - 0.50 mm0.010 - 0.50 mm0.010 - 0.50 mm0.015 - 0.50 mm0.02 - 0.11 mm, ex USA
PropertiesVery good solderability and high thermal properties.Good solderability at 370ºC and elevated thermal valuesSolderable at high temperatures, very good thermal and good chemical resistance.High thermal properties and good chemical resistance.Very high thermal properties and high mechanical resistanceExcellent thermal properties, excellent chemical and high radiation resistance.
ApplicationsUsed in small transformers, linear motors, relays, solenoids, small motors, clock coils, watch coils, fly-back transformers, magnetic heads, instruments.Used for automotive coils as relais and ignition coils, in transformers and in solenoidsUsed in small motors, small transformers, automotive coils.Used in motors, small motors, transformers.Used in motorsUsed in military and space applications.
TECHNICAL VALUES
1. Thermal Values
Temperature index 20,000 h acc. to IEC 60172158ºC192ºC195ºC210ºC212ºC245ºC
Cut through temperature min ºC acc. to IEC 60851.6.4>/= 200ºC>/= 230ºC>/= 265ºC>/= 300ºC>/= 320ºC>/= 400ºC
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1225/230ºC260/265ºC315/325ºC350/360ºC365/380ºC450ºC/n.a.
Heat Shock min ºC acc. to IEC 60851.6.3>/= 175ºC>/= 200ºC>/= 200ºC>/= 200ºC>/= 220ºC>/= 240ºC
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1190/180ºC210/200ºC260/250ºC230/220ºC250/240ºC300ºC/n.a.
2. Electrical values
Low voltage continuity max. acc. to IEC  60 851.5.1 for 0.05mm/0.25mm</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25
Elektrisola typical values for 0.05mm/0.25mm, Grade 10/00/00/00/00/00/n.a.
High voltage continuity max. acc. to IEC 60851.5.2 for 0.05mm/0.25mm</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1>=2/1 >=2/1 >=2/1 >=2/1 >=2/1 >=2/n.a.
Breakdown voltage (at 20o C, 35% humidity)/Elektrisola typical values to cylindrical test 0.05mm/0.25mm, Grade 1240/180 V/micron m240/180 V/micron m240/180 V/micron m240/180 V/micron m230/170 V/micron m240/n.a. V/micron m
Decrease of breakdown voltage in % at elevated temperature                                            Elektrisola typical value for 0.05 mm, Grade 1, in % at ºC                               Elektrisola typical value for 0.25 mm, Grade 1, in % at ºC25% at 155ºC20% at 180ºC20% at 180ºC20% at 200ºC20% at 205ºC15% at 220ºC
3. Mechanical values
Elongation min. acc. to IEC 60851.3.3 for 0.05 mm/0.25 mm, Grade 1>/= 10% / 22%>/= 10% / 22%>/= 10% / 22%>/= 10% / 22%>/= 10% / 22%>/= 10% / 22%
Elektrisola typical values for23% / 40%23% / 40%23% / 40%23% / 40%23% / 40%23% / 40%
Tensile strength min
Elektrisola typical values for57/1370 cN57/1370 cN57/1370 cN57/1370 cN57/1370 cN57/1370 cN
4. Chemical
Standard solution acc. to IEC 60851.4.3
Pencil Hardness with/without treatment4H/4H4H/4H4H/4H4H/4H4H/4H6H/6H
Decrease of breakdown voltage in % after treatment5%0%0%5%0%0%
General statements about chemical compatibility are not possible due to the high number of influencing factors such as winding, impregnation molding and cleaning materials etc.
5. Solderability
acc. to IEC 60851.4.5, max. seconds at ºC for 0.05/0.25mm2s/390ºC / 3s/390ºC2s/390ºC / 3s/390ºC2s/470ºC / 3s/470ºC------
Elektrisola typical values acc. to IEC 60851.4.5.1.1 + -4.5.1.30,3s/370ºC / 0,2s/390ºC1.8s/370ºC / 0.7s/390ºC1.8s/470ºC------
for 0.05 mm, Grade 1, seconds at ºC for 0.25 mm, Grade 1, seconds at ºC0,7s/370ºC / 0,5s/390ºC2.8s/370ºC / 1.1s/390ºC2.8s/470ºC------
Acoustics 发表于:2006-10-10 8:59:03
Elektrisola Selfbonding Wire
ELEKTRISOLA - Produkt-NameButybondButybond alcohol 155Solabond 155Solabond Poly 180Solabond 180Solabond 200
ELEKTRISOLA - Produkt-CodeB155Ba155S155SP180S180S200
General
Description          Base coat
                          Bondcoat
mod. Polyurethane
Polyvinylbutyral
mod. Polyurethane
Polyvinylbutyral
mod. Polyurethane
Polyamide
mod. Polyurethane
Polyamide
Polyesterimide
Polyamide
Polyamide
Standards:
IEC (including the following norms)IEC 60317-35, IEC 60317-2IEC 60317-35, IEC 60317-2IEC 60317-35,
IEC 60317-2
IEC 60317-35,
IEC 60317-2
IEC 60317-36IEC 60317-37
Diameters available0.010 - 0.50 mm0.010 - 0.20 mm0.010 - 0.50 mm0.010 - 0.50 mm0.010 - 0.50 mm0.020 - 0.50 mm
TECHNICAL VALUES
1. Thermal Values of base coat
Temperature index 20.000 h acc. to IEC 60172158ºC158ºC158ºC192ºC195ºC210ºC
Cut through temperature min. °C acc. to IEC 60851.6.4>/= 200ºC>/= 200ºC>/= 200ºC>/= 200ºC>/= 265ºC>/= 300ºC
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1B
225/230ºC225/230ºC225/230ºC260/265ºC315/325ºC350/360ºC
Heat shock min. °C acc. to IEC 60851.6.3 >/= 175ºC>/= 175ºC>/= 175ºC>/= 175ºC>/= 200ºC>/= 200ºC
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1B190/180ºC190/180ºC190/180ºC210/200ºC260/250ºC230/220ºC
2. Electrical Values
Low voltage continuity max. acc. to IEC 60851.5.1 for 0.05 mm/0.25 mm</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1B0/00/00/00/00/00/0
High voltage continuity max. acc. to IEC 60851.5.2 for 0.05 mm/0.25 mm</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25</= 60/25
Elektrisola typical values for 0.05 mm/0.25 mm, Grade 1B2/12/12/12/12/12/1
Pinholes acc. to JIS C 3003.6, with 0% / 3% elongationnot applicablenot applicablenot applicablepasspasspass
Breakdown voltage acc. to IEC 60851.5.4 (at 20°C, 35% humidity)
Elektrisola typical values acc. to cylinder test for 0.05 mm/0.25 mm, Grade 1B
170/130 V/micron m170/130 V/micron m170/130 V/micron m170/130 V/micron m170/130 V/micron m170/130 V/micron m
3. Mechanical Values
Elongation min. acc. to IEC 60851.3.3 for 0.05 mm/0.25 mm, Grade 1B>/= 14% / 25%>/= 14% / 25%>/= 14% / 25%>/= 14% / 25%>/= 14% / 25%>/= 14% / 25%
Tensile strength
4. Bonding
Method
Hot air bonding0.010 - 0.14 mm0.010 - 0.14 mm0.010 - 0.14 mm0.010 - 0.14 mm0.010 - 0.14 mm0.020 - 0.14 mm
Oven bonding 0.10 - 0.50 mm0.10 - 0.20 mm0.10 - 0.50 mm0.10 - 0.50 mm0.10 - 0.50 mm0.10 - 0.50 mm
Resistance bonding0.10 - 0.50 mm0.10 - 0.20 mm0.10 - 0.50 mm0.10 - 0.50 mm0.10 - 0.50 mm0.10 - 0.50 mm
Solvent bonding
Recommended solvent
limited
Methanol/Ethanol
suitable
Methanol/Ethanol
suitable
Methanol/Ethanol
suitable
Methanol/Ethanol
limited
Methanol/Ethanol
limited
Methanol/Ethanol
Recommended bonding temperature
110 - 140°C110 - 140°C140 - 170°C150 - 190°C160 - 190°C200 - 230°C
Resoftening temperature acc. to IEC 60851.3.3.7.1.2.3 for 0.25 mm
>/- 100°C>/- 100°C>/- 155°C>/- 170°C>/- 180°C>/- 200°C
Stockability at 25°C/60% relative humidity in months</-6</-6</-3</-5</-5</-5
5. Solderability
acc. to IEC 60851.4.5 max. seconds at °C for 0.05 mm/0.25 mm, Grade 1B
2s/390ºC / 2s/390ºC2s/390ºC / 2s/390ºC2s/390ºC / 3s/390ºC2s/390ºC / 3s/390ºC2s/470ºC / 3s/470ºC--
Elektrisola typical values acc. to IEC 60851.4.5.1.3
B, seconds at °C
for 0.25 mm, Grade 1B, seconds at °C
1.3s/370ºC / 0.8s/390ºC
2.8s/370ºC / 1.4s/390ºC
0.5s/370ºC / 0.4s/390ºC
1.2s/370ºC / 0.7s/390ºC
1.0s/370ºC / 0.7s/390ºC
2.8s/370ºC / 1.6s/390ºC
1.9s/470ºC
3.4s/470ºC
PropertiesEasy bonding, low sensititvity
against humidity, low resoftening
temperature.
Easy bonding, low sensitivity
temperature, especially for
solvent bonding.
Higher resoftening temperature,
hygroscopic, alcohol bonding
possible.
not hygroscopic, alcohol bonding
possible.
Very good thermal properties of
base coat, high resoftening temperature,
slightly hygroscopic.
Good thermal properties of
temperature, slightly hagroscopic.
Application For stepper motors for quartz watches,
instruments, voice coils,
sensors, transponders.
sensors.
For instrument coils, voice coils,
loudspeakers, small motors,
sensors.
For small motors, loudspeakers.For small motors, loudspeakers.
Acoustics 发表于:2006-10-10 9:02:01
Nom.Bare WireResistanceOuter DiameterApprox. LengthMax.
DiameterTolerance             per meter at 20 ° C  of 1 kg of WireWindingNom.
   Grade 1Grade 2Grade 3 TensionDiameter
  nom.min.max.min.max.min.max.min.max.Grade1Grade 2Grade 3
mmmm   W / m   W / m   W / mmmmmmmmmmmmmkmkmkmcNmm
0.012False False Center 图片点击可在新窗口打开查看
151.14136.03166.260.0140.0160.0170.0180.0190.021913.6847.9782.92.00.012
0.014 111.0499.94122.150.0160.0180.0190.0200.0210.023679.4638.1596.82.50.014
0.016 85.0276.5293.520.0180.0200.0210.0220.0230.025524.9497.3469.53.20.016
0.018 67.1860.4673.890.0200.0220.0230.0240.0250.027417.6398.3378.83.90.018
0.019 60.2954.2666.320.0210.0230.0240.0260.0270.029375.9356.2336.34.30.019
0.020 54.4148.9759.850.0220.0240.0250.0270.0280.030340.1323.2306.24.70.020
0.021 49.3544.4254.290.0230.0260.0270.0280.0290.031306.8292.2279.95.10.021
0.022 44.9740.4749.470.0240.0270.0280.0300.0310.033280.2265.4252.66.00.022
0.023 41.1437.0345.260.0250.0280.0290.0310.0320.035257.0244.0231.06.20.023
0.024 37.7934.0141.570.0260.0290.0300.0320.0330.036236.5225.1213.66.50.024
0.025 34.8231.3438.310.0280.0310.0320.0340.0350.038215.5205.4195.27.00.025
0.027 29.8626.8732.840.0300.0330.0340.0360.0370.041185.6177.6168.38.00.027
0.028 27.7624.9930.540.0310.0340.0350.0380.0390.043172.9164.7155.48.50.028
0.030 24.1821.7726.600.0330.0370.0380.0410.0420.046150.3142.8135.29.60.030
0.032 21.2519.1323.380.0350.0390.0400.0430.0440.048132.6126.4120.210.80.032
0.034 18.8317.0020.650.0370.0410.0420.0460.0470.051117.8112.1106.312.00.034
0.036 16.7915.1718.420.0400.0440.0450.0490.0500.054104.499.5794.6913.20.036
0.038 15.0713.6116.540.0420.0460.0470.0510.0520.05693.9789.8785.7214.50.038
0.040 13.6012.2814.920.0440.0490.0500.0540.0550.05984.6880.8177.2515.90.040
0.043 11.7710.6312.910.0470.0520.0530.0580.0590.06373.5570.1567.0118.00.043
0.045 10.759.7111.790.0500.0550.0560.0610.0620.06766.8263.8560.8519.40.045
0.048 9.4478.59610.2970.0530.0590.0600.0650.0660.07058.7356.0853.8121.70.048
0.050 8.7067.9229.4890.0550.0600.0610.0660.0670.07254.4252.2650.0823.20.050
0.053 7.7487.0518.4460.0580.0640.0650.0700.0710.07648.4246.4544.6225.30.053
0.056 6.9406.3167.5650.0620.0670.0680.0740.0750.08043.3641.6940.0128.00.056
Acoustics 发表于:2006-10-10 9:03:16
0.060 6.0465.5626.5290.0660.0720.0730.0790.0800.08537.7936.3334.9731.70.060
0.063 5.4845.0455.9220.0690.0760.0770.0830.0840.08934.2732.9231.7434.60.063
0.067± 0.0034.8494.4045.3600.0740.0800.0810.0880.0890.09330.3129.1928.21370.067
0.070± 0.0034.4424.0504.8900.0770.0830.0840.0900.0910.09627.8326.9126.06410.070
0.071± 0.0034.3183.9414.7480.0780.0840.0850.0910.0920.09727.0726.1925.37440.071
0.075± 0.0033.8693.5474.2350.0820.0890.0900.0950.0960.10224.2623.5222.82460.075
0.080± 0.0033.4013.1333.7030.0870.0940.0950.1010.1020.10821.3920.7320.11520.080
0.085± 0.0033.0122.7873.2650.0930.1000.1010.1070.1080.11418.9218.3717.86570.085
0.090± 0.0032.6872.4952.9000.0980.1050.1060.1130.1140.12016.9216.4315.96630.090
0.095± 0.0032.4122.2472.5940.1030.1110.1120.1190.1200.12615.1914.7514.35690.095
0.100± 0.0032.1772.0342.3330.1080.1170.1180.1250.1260.13213.7213.3112.97750.100
0.106± 0.0031.9371.8162.0690.1150.1230.1240.1320.1330.14012.2211.8811.56810.106
0.110± 0.0031.7991.6901.9170.1190.1280.1290.1370.1380.14511.3411.0310.74880.110
0.112± 0.0031.7351.6321.8480.1210.1300.1310.1390.1400.14710.9510.6510.37940.112
0.118± 0.0031.5631.4741.6600.1280.1360.1370.1450.1460.1549.8709.6269.379970.118
0.120± 0.0031.5111.4261.6040.1300.1380.1390.1480.1490.1579.5509.3059.0571020.120
0.125± 0.0031.3931.3171.4750.1350.1440.1450.1540.1550.1638.8038.5758.3561100.125
0.130± 0.0031.2881.2201.3610.1410.1500.1510.1600.1610.1698.1317.9287.7331180.130
0.132± 0.0031.2491.1841.3190.1430.1520.1530.1620.1630.1717.8917.6977.5111250.132
0.140± 0.0031.1101.0551.1700.1510.1600.1610.1710.1720.1817.0306.8606.6871330.140
0.150± 0.0030.96730.92191.01590.1620.1710.1720.1820.1830.1936.1255.9875.8401500.150
0.160± 0.0030.85020.81220.89060.1720.1820.1830.1940.1950.2055.3905.2655.1391690.160
0.170± 0.0030.75310.72110.78710.1830.1940.1950.2050.2060.2174.7714.6674.5611860.170
0.180± 0.0030.67180.64440.70070.1930.2040.2050.2170.2180.2294.2634.1684.0722060.180
0.190± 0.0030.60290.57940.62780.2040.2160.2170.2280.2290.2403.8233.7433.6642260.190
0.200± 0.0030.54410.52370.56570.2140.2260.2270.2390.2400.2523.4563.3843.3122470.200
0.212± 0.0030.48430.46690.50260.2270.2400.2410.2540.2550.2683.0753.0102.9442500.212
0.224± 0.0030.43380.41880.44950.2390.2520.2530.2660.2670.2802.7592.7042.6482560.224
0.236± 0.0040.39080.37470.40790.2530.2670.2680.2830.2840.2982.4812.4292.3762600.236
0.250± 0.0040.34820.33450.36280.2670.2810.2820.2970.2980.3122.2152.1712.1273660.250
0.265± 0.0040.30990.29820.32230.2830.2970.2980.3140.3150.3301.9721.9341.8953920.265
0.280± 0.0040.27760.26760.28820.2980.3120.3130.3290.3300.3451.7691.7371.7044480.280
0.300± 0.0040.24180.23350.25060.3190.3340.3350.3520.3530.3691.5421.5141.4855070.300
0.315± 0.0040.21930.21210.22700.3340.3490.3500.3670.3680.3841.4001.3761.3515620.315
0.335± 0.0040.19390.18780.20040.3550.3720.3730.3910.3920.4081.2381.2161.1956330.335
0.355± 0.0040.17270.16740.17820.3750.3920.3930.4110.4120.4281.1041.0861.0687200.355
0.375± 0.0050.15480.14940.16040.3960.4140.4150.4340.4350.4530.9890.9730.9577910.375
0.400± 0.0050.13600.13160.14070.4210.4390.4400.4590.4600.4780.8710.8580.8448540.400
Acoustics 发表于:2006-10-10 9:06:20
ConductorMin.Film Thickness (mm)Max.O.D. (MM)CopperCopper-clad Aluminum
Dia (mm)Tolerance (mm)Max. Conductor Resistance (Ω/km,20℃)Approx. Weight (kg/km)Std.Conductor Resistance (Ω/km,20℃)Approx. Weight (kg/km)
0.02±0.0020.0030.03698500.0028
0.025""0.037427800.0049
0.03""0.044288700.007
0.04""0.056156700.012
0.05±0.0030.0040.069102400.02
0.06""0.08169660.02790400.013
0.07""0.09149900.03666300.017
0.08"0.0050.10337780.04850800.022
0.09""0.11329590.0640200.028
0.1""0.12523810.07432500.034
0.11""0.13519570.08926900.041
0.12"0.0060.14716360.1122600.049
0.13""0.15713890.1219200.057
0.14""0.16711930.1416600.066
0.15""0.17710370.1614400.075
0.16"0.0070.189908.80.1912700.086
0.17""0.199803.20.2111200.096
0.18"0.0080.2117150.2410000.1
0.19""0.221640.60.269000.12
0.2""0.231577.20.298120.13
0.21""0.241522.80.327370.15
0.22±0.004"0.252480.10.356720.16
0.23"0.0090.264438.60.386130.17
0.24""0.274402.20.425640.19
0.25""0.284370.20.455200.2
0.26""0.294341.80.494820.22
0.27""0.304316.60.524460.24
0.28""0.314294.10.574150.25
0.29""0.324273.90.63870.27
0.3±0.0050.010.3372540.653610.29
0.32""0.357222.80.733180.33
0.35""0.387185.70.882650.39
0.37""0.407165.90.982380.44
0.4"0.0110.439141.71.14
0.45±0.006"0.49112.11.44
0.5"0.0120.54289.951.78
0.55""0.59274.182.15
0.6±0.008"0.64462.642.56
0.65""0.69453.263
0.7"0.0130.74645.843.47
0.75"0.0140.79839.873.99
0.8±0.0100.0150.85235.174.54
0.85""0.90431.115.12
0.9"0.0160.95627.715.74
Acoustics 发表于:2006-10-10 9:17:47
标称线径电阻系数  实际值概算重量
mmohm/KmmmKg / Km
0.025 386000.0350.0049
0.030 268000.0410.0070
0.035 196900.0460.0089
0.040 150800.0520.0124
0.045 119100.0580.0157
0.050 96500.0640.0191
0.055 79700.070.0230
0.060 67000.0750.0275
0.065 57100.0810.0310
0.070 49200.0860.0372
SDHT 2DS-FH(5)DAIKOKU
Acoustics 发表于:2006-10-10 11:39:41
标称线径电阻系数  平均值概算重量
mmohm/KmmmKg / Km
0.025 348200.032 0.0049
0.030 241800.039 0.0070
0.036 167900.047 0.0089
0.040 136000.052 0.0124
0.045 107500.058 0.0157
0.050 87060.063 0.0191
0.053 77480.068 0.0215
0.056 69400.071 0.0240
0.060 60460.076 0.0275
0.063 54840.080 0.0304
0.067 48490.085 0.0343
0.070 44420.087 0.0372
ELEKTRISOLASP180
Jurry 发表于:2006-10-10 15:42:31
支持!支持!!!!!
图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看图片点击可在新窗口打开查看
db 发表于:2006-10-10 18:16:11
不错
欧阳风 发表于:2006-10-10 19:20:28
ding!!
flying 发表于:2006-10-19 18:50:14
ding!!
mfkxsan 发表于:2006-10-20 19:51:47
很不错,支持!图片点击可在新窗口打开查看
lsm9751 发表于:2006-10-27 21:34:42
好东西
博学善思 发表于:2006-10-28 8:44:40
LZ没写是铜还是铝线吗?
水仙 发表于:2006-11-3 12:43:50
Copper-clad Aluminum就是铜包铝线.
其他都是铜线!
Acoustics 发表于:2006-11-3 16:54:43
漆包线类型漆包线规格(mm)最大线材外径(mm)最大电阻率(Ω/km)重量(kg/km)
CCAW0.060.08290400.013
CCAW0.070.09266300.017
CCAW0.080.10850800.022
CCAW0.090.11840200.028
CCAW0.10.12832500.034
CCAW0.110.13826900.041
CCAW0.120.15222600.049
CCAW0.130.16219200.057
CCAW0.140.17216600.066
CCAW0.150.18214400.075
CCAW0.160.19412700.086
CCAW0.170.20411200.096
CCAW0.180.21610000.1
CCAW0.190.2289000.12
CCAW0.20.2388120.13
CCAW0.210.2487370.15
CCAW0.220.2586720.16
CCAW0.230.2726130.17
CCAW0.240.2825640.19
CCAW0.250.2925200.2
CCAW0.260.3054820.22
CCAW0.270.3154460.24
CCAW0.280.3254150.25
CCAW0.290.3353870.27
CCAW0.30.3453610.29
CCAW0.320.3693180.33
CCAW0.350.3992650.39
CCAW0.370.422380.44
Acoustics 发表于:2006-11-3 16:57:48
CW0.020.03698500.0028
CW0.0250.037427800.0049
CW0.030.044288700.007
CW0.040.056156700.012
CW0.050.069102400.02
CW0.060.08169660.027
CW0.070.09149900.036
CW0.080.10337780.048
CW0.090.11329590.06
CW0.10.12523810.074
CW0.110.13519570.089
CW0.120.14716360.11
CW0.130.15713890.12
CW0.140.16711930.14
CW0.150.17710370.16
CW0.160.189908.80.19
CW0.170.199803.20.21
CW0.180.2117150.24
CW0.190.221640.60.26
CW0.20.231577.20.29
CW0.210.241522.80.32
CW0.220.252480.10.35
CW0.230.264438.60.38
CW0.240.274402.20.42
CW0.250.284370.20.45
CW0.260.294341.80.49
CW0.270.304316.60.52
CW0.280.314294.10.57
CW0.290.324273.90.6
CW0.30.3372540.65
CW0.320.357222.80.73
CW0.350.387185.70.88
CW0.370.407165.90.98
CW0.40.439141.71.14
CW0.450.49112.11.44
CW0.50.54289.951.78
CW0.550.59274.182.15
CW0.60.64462.642.56
CW0.650.69453.263
CW0.70.74645.843.47
CW0.750.79839.873.99
CW0.80.85235.174.54
CW0.850.90431.115.12
CW0.90.95627.715.74
品位一生 发表于:2006-11-3 17:23:32
顶,这么好的东东要顶啊
bailey 发表于:2006-11-4 10:24:34
好东东!
谢谢大家!
AK74A 发表于:2006-11-4 12:45:30
好哇,除了感叹, 感激,我还能再说什么呢。
Processed in .43750 s, 2 queries.
