共47 条记录, 每页显示 20 条, 页签: [1] [2][3]
标题:关于蓝牙类桌面、便携小音响的调试
WAMM 发表于:2014-5-21 8:32:15
各位好,最近接到一个案子,是需要提升一个蓝牙音箱的音响效果。再论坛里找了一下,暂时没有找到太多的信息,所以发贴求助一下,看看各位大侠们有没有什么经验可以分享一下的,谢过先了。
先说说我的一些想法,欢迎指点。
一,设计指标排序(目标成本已定):1.最大声压级 ;2.合适的频响范围和响应曲线;3.小的失真
    其它的指标,欢迎补充。对于这三个指标的具体值,也非常感谢能提供的人。
二,对于三个指标的设计思路
   合适的的扬声器,合适的箱体设计 ,尽量大功率一点的功放,DSP处理技太的运用。
   对设计思路的展开求助中
   1.什么样的扬声器最合适:两种情况,a,扬声器口径尺寸已定,b,箱尺寸已定,扬声器尺寸自行确定。
   2.功放:常用的功放芯片有哪一些,各自有些什么优缺点。
   3.DSP芯片:常用有哪些?各自的功能,优缺点及调试技巧。
    暂时只想到这些,大力欢迎回贴,回贴也许有惊喜哦!
聲學樓一等兵 发表于:2014-5-21 8:57:23
標題與內容不符啊!
cy9663 发表于:2014-5-21 9:12:38
I get some problems with my computer IME, I will give you response in English.
I would like to know what is your reference sample? don't tell me it is Bose Soundlink Mini.
1. The Max. SPL: I think it can be 90dB at 1Meter
2. Frequency response: it can be 90Hz to 20K Hz depend on your design and requirement, if you can make the low frequency go down around 60Hz with reasonable SPL, then you can compare with Bose Soundlink Mini.
3. Distortion: I have not test it, if you talk about the distortion only at 1K Hz, maybe I can provide the parameter to you, but if you talk about the full range, because we don't have the anechoic room, so I can't give you the data.
Further discussion:
1. Driver: I guess you will only get a chance to use 2pcs fullrange drivers for the stereo effect. in that case, I think the 40mm fullrange is reasonable to use, if you want to know more, you can refer to Soundlink Mini, JBL FLIP (? I can't remember the model name right now). if you get a chance to use bigger drivers, it will improve the sound a lot, because the effective area of driver.
2. Amplifier: Some company they would like to use Ti, but I don't have more experience about it, I think you no need to do any turning for the amplifier. you should pay more attention about the power and distortion.
3. DSP: it also very depend on what kind of sound effect you want to have it. because it is BT speaker, you will use CSR B3 or B5? it should has the EQ can be turned inside. otherwise, if you don't enough budget with it, you can check if it can do in the Digital amplifier. if you do have enough money, then you can use any DSP you want. but it seems Bose do the DSP with CSR with their arithmetic, that I don't think we can do it right now.
all above is just my personal idea, it is very good that everybody can put your idea together with us. thank you!
[此贴子已经被作者于2014-05-21 09:26:52编辑过]
jasonlyh 发表于:2014-5-21 14:36:27
這是本人設計的一款40*40藍牙音箱的單體,供大家參考.
此音箱的特點是採用了一個振動器,配兩個40*40單體,
只要音箱放在桌面上或是玻璃上就會有大音箱樣的低音
震憾效果.很適合舞曲.暫時不能提供音箱外觀圖.
[此贴子已经被作者于2014-05-21 14:49:17编辑过]
新绿 发表于:2014-5-21 14:36:32
几年不见,CY英语大有长进!系统设计观念也大有进步!祝贺!
楼主公司也打算做蓝牙音箱?不会类似小米RMB199一台吧?
jasonlyh 发表于:2014-5-21 14:39:51
上傳附件圖片
新绿 发表于:2014-5-21 14:47:49
1.最大声压级:最大功率取多少?——建议取3W*2以上,JBL FLIP是5W*2,BOSE SOUNLINK功率更大(8W*2,虽然最大声压级不大)
2.合适的频响范围和响应曲线:80-20kHz, 低频做提升,FLIP仅提升了3dB, Soundlink提升了超过8dB
3.小的失真: 电失真小于1%(THD+N)在额定最大输出功率时
4.容积:主要看你选取的扬声器口径,建议使用40mm-45mm, 净容积大于300ml
5.成本: 自行控制
蓝牙自带的EQ和DSP不是很理想,成本估计也不低,自己写算法,有点难。方便的是使用TI的数字功放带DSP的,调试很方便,成本也低。比较而言,较难达到BOSE的效果。
新绿 发表于:2014-5-21 14:51:29
楼主若需要扬声器,有朋友公司可以做跟Bose Soundlink Mini性能一样的,只是成本较高;也可以做类似JBL Flip性能的扬声器,价格公道。
SPL100 发表于:2014-5-21 16:11:04
感觉象考试?
cy9663 发表于:2014-5-21 18:05:01
以下是引用新绿在2014-05-21 14:51:29的发言:
和Bose Soundlink Mini性能一样的喇叭是哪家公司做的啊,有联系方式吗?这个喇叭做的怪好的!
漂泊寻梦 发表于:2014-5-21 23:15:09
Bose这款用的是两寸全频啦,国光有做,外面很多小喇叭厂抄。
farmer 发表于:2014-5-21 23:57:30
以下是引用新绿在2014-05-21 14:47:49的发言:
5.成本: 自行控制
小的品牌成本很重要,建议就做3瓦x2 csr自带的eq和dsp,他有flat版软件都比较简单也便宜,因为此音响主要功能是蓝牙音响,如你选择ti的功放,你还需要配蓝牙的模块,而蓝牙模块使你同样成本有高了,如你在5瓦以上则建议你用ti的攻放了,因为csr的提供最大功率只有到3瓦,还有你是否配火牛,还是直接用usb充电等这些都与成本很有关系,电子的建议做到thd 百分之10,小音响声音响度很重要,容积与你的id很有关系,喇叭40能保持声音大小,功率,也能兼顾低中高,但这样3瓦的功率你声音要达到bose的效果是不可能的。用ti的软件会更复杂,mcu功能等都需要软件写和实现的。
[此贴子已经被作者于2014-05-22 00:22:57编辑过]
WAMM 发表于:2014-5-22 8:58:07
回声学楼一等兵:标题很大,所以应当不存在与内容不符的情况。
回CY9663:您的回复对我是有参考意义的,虽然不明白您用英文是为了设置门槛还是其它的什么原因。感谢金山快译感谢您!为了表示真诚的谢意,如果您任何时候来到我所居住所在地市内,本当愿略尽地主之宜,在您愿意赏脸的情况下,可以带您品尝海鲜美食以及感受其它当地特色服务。因为不知您何时会来,所以有效期为20年,联系方式我会私下提供给您!
回jasonlyh:感谢您的参考讨论,能否再多些您的产品介绍?
WAMM 发表于:2014-5-22 9:19:52
回新绿:关于公司的事情,不好说太多。可以确定目前的目标是做中低价位的东西,这个时候设计要求性价比的最大化,难度也不小。
        感谢您技术上的见解。 因为我与CY9663略有相识,所以觉得可以有机会招待他。但您,不太确定是哪一位,因此不好做太多的承诺。我有一款实用新型专利的小型桌面蓝牙音响,今年可能会有少量的样机出来,但质量怕不入您法眼,如果有兴趣,到时可以寄一个给您,联系方式我会在站内短信给您,可以吗?
WAMM 发表于:2014-5-22 9:30:59
回SPL100:没有考试,提出问题是为了整体项目方案的确定。
WAMM 发表于:2014-5-22 9:35:32
回FARMER:您应当做了不少此类产品,非常感谢您的经验!要怎样表示感谢才好呢?
Acoustics 发表于:2014-5-22 10:30:07
WAMM不在珠海了?还没去过珠海呢。声学楼应该很多人认识你呀,所以才热心提供建议。
CY不已经说了是输入法的问题,无法打中文。
Acoustics 发表于:2014-5-22 10:31:40
Email: y.chen@eurotec.com.cn
腾讯QQ: 344900603
CY联系方式都没修改,早不在欧科了吧?
cy9663 发表于:2014-5-22 10:42:20
以下是引用WAMM在2014-05-22 08:58:07的发言:
回MM: 昨天输入法坏了,见谅!你就将就着看看吧。正好去年一年花了不少的时间去研究过这类音箱,所以还能说上那么两句。还有你太客气了,期待有机会见上一面聊聊。你还搞了实用型专利,很强!比较好奇,期待你的产品上市。
cy9663 发表于:2014-5-22 10:43:27
以下是引用Acoustics在2014-05-22 10:31:40的发言:
腾讯QQ: 344900603
CY联系方式都没修改,早不在欧科了吧?
回复老师,是的,我改下!老师你马甲真多图片点击可在新窗口打开查看
