共33 条记录, 每页显示 20 条, 页签: [1] [2]
标题:欣赏!
玛田音箱 发表于:2006-11-22 16:56:27
imxp 发表于:2006-11-22 17:35:08
呵呵,玻璃,喜欢
他家还有开放障板的设计,不赖
DAAS 发表于:2006-11-22 22:54:15
他家?哪家啊?
XP老大,透露一二吧?
spl 发表于:2006-11-22 23:03:06
有趣的设计,用的钢化玻璃吗?
不知道有没有测试过指向性?
知春 发表于:2006-11-22 23:25:31
可以用眼睛欣赏(漂亮),可以用耳朵欣赏吗?
美猴王 发表于:2006-11-23 19:27:01
视觉享受!
耳朵受罪!
寒山 发表于:2006-11-23 22:51:48
暴露狂?满足人原始的窥探欲望!!
高音的负担也太重了吧!!
darry 发表于:2006-11-25 22:00:51
高音和低音装在不同的平面,声音效果有什么特别?
心动 发表于:2006-11-27 10:45:42
21HIFI上面出过图
心动 发表于:2006-11-27 10:46:07
21hifi上面出过图
久味十足 发表于:2006-11-27 11:03:35
外观比较漂亮,但可能听起来就不好了,相位变了
imxp 发表于:2006-11-27 16:02:35
以下是引用DAAS在2006-11-22 22:54:15的发言:
他家?哪家啊?
XP老大,透露一二吧?
忘记网址了,找半天才找出来:
http://www.perfect8.com/content/pressrelease/press-premiere-eng.htm
Specifications
The Cube is an amazing little speaker and the specifications reflect its superb performance.
Sensitivity (2.83V): 86dB SPL @ 1m
Impedance: 4 ohms
Frequency response: 90–30kHz +/- 1dB from target response (12dB/octave L/R high pass, -6dB at 90Hz anechoic 4 pi)
Frequency response (active bass control): 50–30kHz +/-1dB from target response (24dB/octave L/R high pass, -3dB at 70Hz anechoic 4 pi,-6dB at 50Hz anechoic 4 pi)
Typical THD: < typically 0.3% throughout midrange at 96dB SPL
Recommended power: Long term maximum power: 140W, Short term maximum power: 400W, Maximum Impulse Power: 1000W
Treble: Long throw 28mm ultra high quality silk dome with large coupled volume ensuring low resonant frequency. Heavily modified and rebuild in-house to eliminate structural and cavity resonances.
Bass / Mid: 2 (per channel) in-house modified and rebuild extremely stiff 5¼” Mg-Cones with ultra linear magnetic drive. Resonances and energy storage way outside pass band
Recommended room size: 10 – 200m²
Size (approx.): w=140mm x h=180mm x d=190mm
Mass (approx.): 6Kg / channel
[此贴子已经被作者于2006-11-27 16:15:24编辑过]
allen-hu 发表于:2006-12-13 13:34:45
顶一下
lybjim 发表于:2006-12-21 20:00:11
视觉创意,如果振膜,面板也来个透明的,不知效果如何?
心动 发表于:2006-12-22 15:34:26
不过如果真做好了的话还真可以成为现代家装中的一道风景
音响初哥 发表于:2006-12-23 5:37:37
这个指标如何理解?
CNYANG 发表于:2006-12-25 17:20:17
视觉满足了,听觉如何有待确认
szwangjianhua 发表于:2007-1-23 14:38:01
外观较漂亮!
edwinge 发表于:2007-1-27 23:13:12
以下是引用美猴王在2006-11-23 19:27:01的发言:
视觉享受!
耳朵受罪!
对于这种的音箱只能是这种感觉,不过,如果如果这种音箱销售到南美,那里的人喜欢把音箱放在户外,一群人围着音箱跳舞, 可能是个不错的选择图片点击可在新窗口打开查看
饼干 发表于:2007-1-29 21:22:24
以下是引用spl在2006-11-22 23:03:06的发言:
有趣的设计,用的钢化玻璃吗?
不知道有没有测试过指向性?
不用测了吧,满足一下人们的偷窥欲而已,想问一下,用在什么环境的?
Processed in .14063 s, 2 queries.
