共13 条记录, 每页显示 20 条, 页签: [1]
标题:新品线性阵列音箱!
玛田音箱 发表于:2007-2-28 16:56:44
本公司今年在北京展之前将弄一宽线性阵列音箱!
参数如下
TYPEThree-way line array element
FREQUENCY RESPONSE (5)60Hz-18kHz ± 3dB
DRIVERS12" (300mm)/3" (75mm) voice coil,
Hybrid™ bass horn loaded
2 x 6.5" (165mm)/1.5" (38mm) coil drivers,
horn loaded
3 x 1" (25mm) exit HF compression drivers,
horn loaded
RATED POWER (2)LF: 400W AES, 1600W peak
MF: 200W AES, 800W peak
HF: 100W AES, 400W peak
SENSITIVITY (6) LF: 103dB
MF: 106dB
HF: 109dB
MAXIMUM SPL
(calculated @ Im)
LF: 129dB continuous, 135dB peak
MF: 129dB continuous, 135dB peak
HF: 129dB continuous, 135dB peak
NOMINAL IMPEDANCE LF: 8 ohms
MF: 8 ohms
HF: 8 ohms
DISPERSION (-6dB)90º horizontal, 7.5º vertical
120º horizontal @ -10dB
CROSSOVER300Hz, 3kHz active
ENCLOSUREVertical trapezoid with 3.75º wall angle, multi-laminate birch ply construction
FINISHTextured black paint
PROTECTIVE GRILL Black perforated steel
CONNECTORS2 x Neutrik NL8
FITTINGSProprietary rigging system
DIMENSIONS (inc. wheelboard)(W) 1000mm x (H) 367mm x (D) 550mm (656mm)
(W) 39.4ins x (H) 14.5ins x (D) 21.7ins (27.8ins)
[此贴子已经被作者于2007-02-28 17:14:23编辑过]
玛田音箱 发表于:2007-2-28 17:08:04
 下载信息  [文件大小:   下载次数: ]
图片点击可在新窗口打开查看点击浏览该文件:
玛田音箱 发表于:2007-2-28 17:10:49
玛田音箱 发表于:2007-2-28 17:18:16
[此贴子已经被作者于2009-09-13 10:01:10编辑过]
卜凡 发表于:2007-3-1 18:23:41
以下是引用玛田音箱在2007-02-28 17:18:16的发言:
有没有那家公司今年会去北京展!到时候一定要来搞我!
爲什麽要“到时候一定要来搞我!”你這個箱子有測試的曲線嗎?也端上來看看嗎?
lmc139 发表于:2007-3-2 19:14:15
怎么搞?
zcnsailing 发表于:2007-3-13 22:05:38
把指向性曲线拿出来
就知道是不是线阵了
你做到柱状波了吗?
cameleers 发表于:2007-3-15 12:53:06
ding
mobin-spk 发表于:2007-3-28 15:58:26
这个箱子早就有了!
鱼缸 发表于:2007-4-11 16:28:12
有机会搞搞
bcq 发表于:2007-10-19 22:33:38
玛田啊
不远处 发表于:2009-7-29 10:56:02
呵呵,先顶一下
最近正在做线阵,多收集一些资料
jefferson 发表于:2009-7-30 16:09:48
外型真不錯,我想聲音也不賴, 老鄉,  頂你
Processed in .04688 s, 3 queries.
