标题:声达何在?
xiushuicunren 发表于:2010-7-15 15:25:35
这两天在翻一般高保真音箱的书,看到书里介绍到广州声达音响公司的产品(新威音箱)。
据说该公司是南京大学声学系(应是电声专业?)的两个学生办的,也做得有声有色,产品还得了什么奖的。
于是,上网查一些,想看看他们的近况。
可惜,已是渺无踪影了!
是不是我没有查到?
还是真的到别的地方发财了?
有知情者,请说说如何?
[此贴子已经被作者于2010-07-16 15:26:01编辑过]
水仙 发表于:2010-7-15 15:40:08
广州声达还在啊,发展不错的.
老板是我两个同班同学.
现在改名:广州笙达电器有限公司
1.Company Name : Sonicstar (Guangzhou) Electronics Co., Ltd
2.*Nature of Business : OEM/ODM Speaker System
3. *Industry :Manufacturer
4. *Year Established : 1993
5. *Background :
   A professional speakers system manufacturer, Sonicstar was established in1993, with two founders graduates of the Acoustics Department of Nanjing University, China. The garden-like factory covers an area of more than 20,000 sq. m., boasting 18 advanced product lines and a staff of about 500. With self-sufficient Electricity power equipment, production capacity reaches 300 k sets per year, focusing on providing OEM&ODM services to customers worldwide .
6. *Office Address : Sonicstar industrial zone, Shima, Junhe, Baiyun District, Guangzhou 510440 China.
7. *Province: Guang Dong
8. *Telephone: (86) 20 36091005
9. *Fax : (86) 20 36090061
10. *e-mail: sonicstar@gzsonicstar.com
11. *Web Site : www.gzsonicstar.com
12. *Contact Person : Mr Xie
13. *Position : General Manager
14. *Product / Service Range: OEM/ODM Speaker System
15. *Annual Turnover : USD 5,000,000 –10,000,000
16. * Major Exporting Market: Australia, Japan, North America, Europe
17. *OEM Services Provided:Yes
18. *No of Staff : about 500
19. *No of Engineers : 35
20. *Brand Names : AVISPK
21. *Certification & Awards : ISO9001:2000
22. *Factory Size in Square Metres/Feet : 20,000 sq.m.
<!--DWLayoutTable-->
General Enquires: sonicstar@gzsonicstar.com
Hotline: (86)020- 36091005 Fax: (86) 020-36090061
Address: Sonicstar industrial zone, Shima, Junhe, Baiyun District, Guangzhou ,Guangdong,China
[此贴子已经被作者于2010-07-15 16:42:10编辑过]
水仙 发表于:2010-7-15 15:40:49
现在改名:广州笙达电器有限公司
http://www.gzsonicstar.com/profile/profile.htm
水仙 发表于:2010-7-15 16:46:06
标题:“水晶一号”音箱设计剖析
【作者】牛薇
【关键词】水晶一号音箱 设计 音响
【刊名】高保真音响 2000--4
【ISSN】1006-0839
水仙 发表于:2010-7-15 16:46:22
【标题】我所了解的新威水晶一号SS—01音箱
【作者】魏辛
【关键词】新威水晶一号 SS-01 音箱
【刊名】现代音响技术 2000--6
【ISSN】1007-4651
水仙 发表于:2010-7-15 16:47:34
新威的水晶一号在国产音响大展中获HIFI音箱的第三名,当时的第一是惠威D3.2,第二名是金琅782,后来,新威就转入了AV音箱的生产,并有新威、极牌和美诗等品牌,其中新威是它的最高级品牌,或多或少还有一些HIFI的影子。
水仙 发表于:2010-7-15 16:49:38
"水晶一号"音箱设计剖析
    新 威 水 晶 一 号
    九九年中国影音器材大展专家组评比HiFi音箱 最佳奖
    极品质素的碳纤维混合纸盒低音单元
    "天仙配"组合的高低音单元
    先进的箱体和分频设计制造技术
    灵敏度 阻抗 频率响应 RMS功率 尺寸mm 重量(Kg/对)
     89dB 5ohm 48Hz-20KHz 120W 1045高240宽320深 50公斤
    第五届国产音响大展在上海举行,使我们有幸饱赏耳福。走进展厅,一对书架式音箱正在放音。丰润明亮的中高音和温暖如春的低音使我驻足细听,听过几曲后,心里琢磨,难道旁边那对落地箱还会比这更好听吗?于是应本人要求,主人把插头换到了那对落地箱。从外观看,他们是兄弟,经主人介绍长者为水晶一号,弟弟自然要排行二号了。这对哑铃式后相落地箱比书架箱多装了一个6.5英寸单元,声场、动态特别是中低音的表现明显见好,这应该是意料中的事。
    主人看我是“有心”的听者,不同于拿了资料就走的匆匆过往客,便从抽屉里拿出两本不同的资料递给我。粗读几页后便对水晶一号有了简单的认识,加之细察和主人的介绍,认识逐步加深,初步明白了为什么扬声器如此的丑,而声音却如此的好听。
     水晶一号采用的中低音振盆是皱皮盆,虽然好听,但价格较高。
     皱皮盆用碳纤维混合特殊纸浆制成不规则的凹凸不平的皱折形,使其密度、刚度和内阻尼都达到比较理想的状态,低频下潜得可以更低,动态也更大。悬边采用了特殊的抛物线橡皮边,厚度呈渐变式。实测结果证明了此单元有比较理想的参数:谐振频率fo=33Hz,品质因数Qts=.28,等效容积Veg=221。在同直径的中低音单元中,如此之低的谐振频率可与SCAN—SPEAK的极品7英寸单元18W/8545相媲美。经过该厂技术人员的努力,终于实现了低fo值、低Qts值,适当的等效容积和平直频响曲线的设计目的。
     水晶一号所用高音扬声器也是该厂自制品,振膜为高档蚕丝所制,表面喷涂特殊阻尼胶,磁隙间加注美国FERROFLUID磁液,声音明亮而柔和。
     生产厂有独立开发优秀扬声器单元的能力,这就为音箱的目标设计奠定了基础,同时也是大幅度降低成本所必须。箱体和分频器的设计、制造,采用了先进的手段。厂家有美国WS、意大利CIJl0、德国DAAS3L+和南京大学的音箱CAD等著名的“硬软”件,加之科学的态度和严谨的敬业精神,使箱体设计得合理、分频器精确。值得指出的是为了减小箱体振动,音箱底部特别 设计了一个风琴式皱折底座的谐振抑制体。设计定型后,实际生产中,采用DAAS3L+进行在线检测。确保产品质量,分频线路见图1。
     分频器所用元件是非常考究,特别定制的金属膜聚丙烯电容,无感大功率陶瓷电阻,大空气芯1.2mm无氧铜电感,线路板则是超厚铜箔板。
     箱体的造型尽管是传统的,但高档原木皮纹理的显露,深、浅色的和谐对比,障板底座及各边角的圆弧面的修饰,磨砂聚脂喷漆工艺的应用,使得造型别致又具新意,厚达18-30mm MDF板的应用,内部多处“日”字形框架的支撑,优质吸音材料的应用,对改善低频重放特性起到了明显的作用。
     现在我们从技术指标上分析一下新威音箱好听的原因。首先看看它的频响曲线和相位曲线(图2)。由图可见,水晶一号的频响曲线度好的基本原因,重放交响乐和大合比较平直,这就是音色平衡
    唱时,各乐器和各声部表现会比较真实,现场感强。音箱的有效频率范围为40-20000Hz,比较宽,能真实地重现出交响乐从低音声部到高音声部的宽阔的声部范围,表现出交响乐的宏大气势。
     相位曲线也较好,无明显的台阶和峰、谷,整体相位分布合理,表明音乐的声场、空间表现力非凡。
     图3所示的水晶一号的阻抗曲线,低频双驼峰对称性好,双峰之间的谷点对应的频率约为40Hz,比较低,中高频端的曲线比较平直。这表明该音箱有理想的倒相调谐状态,听感上表现为低频量感充沛、力度大;音箱的低频下限较低,低频重放能力强,音色丰满而富有层次,气势磅碍。音箱阻抗一致性好,在各个频段上,音箱与功放均有良好的功率匹配。
     从谐波失真图(图4)可见该音箱的总谐波失真,二次及三次谐波失真都在0.5%以下。这样的优秀指标,将使音色更加接近真实,更自然动听。尽管5%以内的谐波失真不易被人耳察觉,但谐波失真大的音箱音色生硬,易使人疲倦,而谐波失真低的音箱则音色甜润柔美,久听不厌。
     从以上各项技术指标分析中不难看出.水晶一号是一款很优秀的音箱,实际的听音评价也证实了这些。水晶系列音箱设计的目的是为了听音乐用的,亦可兼任家庭影院主音箱或家庭卡拉0K用。
    水晶一号音箱的几个技术参数如下:
     结构:双6.5英寸中低音三单元两分频后倒相落地式
    标称阻抗:5欧姆
    特性灵敏度:89dB/1W1m
    有效频率范围:40Hz—20kHz( 2dB)
    最大连续功率:120W
    推荐放大器功率:30—200W
    质量:50Kg/对
    外形尺寸:1045mm×240mm×332mm
    (高)(宽×深) 口
水仙 发表于:2010-7-15 16:51:24
产品转型, 现在回头来看是成功的.
kirin 发表于:2010-7-16 9:54:07
国内还有真的做音响的??
Acoustics 发表于:2010-7-16 10:26:15
没什么奇怪的, 虽然国内假 货多, 但还是有人做真 货的.
不是所有的音响公司都是香武仕或爱浪之类.
xiushuicunren 发表于:2010-7-16 15:43:14
原来还是超版的同学!
是不是改换门庭?自立门户了?
我是2000年,在《高保真放大器与音箱制作精选》一书,得知两位NJU的正统声学专业的人开的音箱厂的。
对其产品当是另眼相看,心里好生崇拜!
那个时候,还在被称为“电声部落”的一个山区电声专业镇里。当时也有一些学声学或电声专业的技术人员,
在做一些并没有多少技术含量的工作。因为产品的档次是很低的,量产的多数是价廉物不怎么美的产品。
在后来,南京来的xxx和天津来的xxx,也终于离开了。离开的原因不是差钱,是他们感到没有什么任务......
对于这样的技术人员,我是心存敬畏的。
也许,他们是真正在电声做事情的,不是混日子的。
超版说他们转型成功,转到哪里了?得空请说说。
xiushuicunren 发表于:2010-7-16 16:06:31
超版:
按照你提供的网址,看了一下笙达公司。原来是转行做home cinema 了。
不知道还做HI-FI 吗?量产,hi-fi肯定是吃不饱的了。
看公司的图片,研发中心在测量音箱的图,是在一般的房间里的。
是这样的吗?
公司是很漂亮的,garden-like!
水仙 发表于:2010-7-16 22:38:12
也有几年没去过他们工厂了,据说规模扩大了,现在主要是做出口,产品是家庭影院,也有乐器音箱.
他们早期是做HIFI的,内销为主,自己的品牌.
更早的话,一个在广东电台,一个在GGEC(跟俞一个部门)
kirin 发表于:2010-7-17 11:02:40
以下是引用水仙在2010-07-16 22:38:12的发言:
有钱的大老板,架子大了?
所以都只与大老板联系
水仙 发表于:2010-7-17 12:12:11
楼上的想偏了.
我同班同学中,现在还在从事电声行业的就只剩下我和他们两位了. 只有我还在从事技术工作(还在打工).
当年毕业时, 有两个同学分配到南京电声,后来其中一个南下去了惠州第一电声,再后来在广州音响市场租了一个摊位卖音响器材,据说很发达,就去了澳大利亚.其中的另一个就改行了,去了法国,现在某日资企业,做化工产品的. 有一个同学分配到杭州电声,后来跟老婆去了河北石家庄,从事扩声工程,现在美国. 有一个同学分配去了广州国光,后来跟另一同学合伙创办了自己的企业,就是上述的公司.
行行出状元,行行出老板.
xshslmm 发表于:2010-7-18 19:43:27
XIUSHUI-修水
见识了!
xiushuicunren 发表于:2010-7-19 16:17:43
从一而终的可能是有,但是,改行(电声改化工)也是有点。
这没什么,也说不上对错的。
需要是最大的动力。当需要的时候,你就“不是也是”了!
谢谢超版在这里“痛说革命家史”了。
爱拼才会赢 发表于:2010-7-19 16:21:28
被称为“电声部落”的一个山区电声专业镇里:
应该是中山小榄镇.
爱浪的厂房很漂亮, 但没听说他们有电声工程师, 有一台全自动贴片机似乎不错的.
爱拼才会赢 发表于:2010-7-19 16:22:51
HIVI好象也在山沟沟里.
秀水村?
秀水街的名气很大!
YSF 发表于:2010-8-1 20:32:24
以下是引用爱拼才会赢在2010-07-19 16:21:28的发言:
应该是中山小榄镇.
是吗?
好像不是的,真的不是。
