共51 条记录, 每页显示 10 条, 页签: [1] [2][3][4][5][6]
标题:发一组参数表,有没有发现点什么?
numen 发表于:2014-12-10 8:16:20
Linear parameters
Name Value Unit Comment
Electrical Parameters
Re 3.86 Ohm electrical voice coil resistance at DC
Le 0.214 mH frequency independent part of voice coil inductance
L2 0.276 mH para-inductance of voice coil
R2 3.29 Ohm electrical resistance due to eddy current losses
Cmes 130.33 μF electrical capacitance representing moving mass
Lces 7.79 mH electrical inductance representing driver compliance
Res 11.16 Ohm resistance due to mechanical losses
fs 157.9 Hz driver resonance frequency
Mechanical Parameters
(using laser)
Mms 1.502 g mechanical mass of driver diaphragm assembly including air load and voice coil
Mmd (Sd) 1.481 g mechanical mass of voice coil and diaphragm without air load
Rms 1.032 kg/s mechanical resistance of total-driver losses
Cms 0.676 mm/N mechanical compliance of driver suspension
Kms 1.48 N/mm mechanical stiffness of driver suspension
Bl 3.394 N/A force factor (Bl product)
Lambda s 0.220 suspension creep factor
Loss factors
Qtp 0.373 total Q-factor considering all losses
Qms 1.444 mechanical Q-factor of driver in free air considering Rms only
Qes 0.499 electrical Q-factor of driver in free air considering Re only
Qts 0.371 total Q-factor considering Re and Rms only
Other Parameters
Vas 0.0478 l equivalent air volume of suspension
n0 0.036 % reference efficiency (2 pi-radiation using Re)
Lm 77.79 dB characteristic sound pressure level (SPL at 1m for 1W @ Re)
Lnom 77.95 dB nominal sensitivity (SPL at 1m for 1W @ Zn)
rmse Z 5.89 % root-mean-square fitting error of driver impedance Z(f)
rmse Hx 4.49 % root-mean-square fitting error of transfer function Hx (f)
Series resistor 0.00 Ohm resistance of series resistor
Sd 7.07 cm2 diaphragm area
cy9663 发表于:2014-12-10 8:51:40
40mm的小喇叭参数不错,很像Bose soundlink Mini的,楼主自己开发的?
KING6688 发表于:2014-12-10 9:47:09
好喇叭!高BL,低Qts,Fs160Hz,环形铷铁錋,向前辈学习了!
numen 发表于:2014-12-10 9:48:59
以下是引用cy9663在2014-12-10 08:51:40的发言:
是的,正是那个喇叭。
参数易调整。Q值做到0.4以下,费了点心。
鼓纸的特性一直不理想,到现在曲线还是有点差。
国产的鼓纸,哎……
KING6688 发表于:2014-12-10 10:27:30
请教下,看参数Mmd1.48g,估计VC不是CCAW?我算了下重量,没那么重.BL
不错,SPL应该有81dB以上比较好!学习学习!呵呵。。
numen 发表于:2014-12-10 10:51:18
以下是引用KING6688在2014-12-10 10:27:30的发言:
CCAW线是必须的,不然同样卷幅的重量惊人! 线径控制好很重要,这里一点点都影响蛮大。重量和L值掌握中间值。
SPL没有达到那么高,是一个橡皮边的,只有78dB.
KING6688 发表于:2014-12-10 12:27:28
我的40部分材料:
1.磁铁15.5*5 N42  13.5*2  N35  华司2.0厚,U铁厚2.0,铁盆架(没有塑胶的好?)
2.弹波:细绢或CONEX (冷压蚕丝如何?)
3. 橡边鼓纸(胴体又硬又厚0.25G)
4.帽子:反新疆纸帽(带边深U帽)
5. 音圈:KAP:CCAW/4F,
6.中心胶:本来用环氧树脂的,没有,用868K代替。
听音体会,1.曲线看也挺平坦的,不过貌似没有铝锅底40喇叭的声音清晰度好。
              2.声场不够大,dB值也是78-79,难度鼓纸重(边0.25+胴体0.25)?
能否帮忙指点下!谢谢!!
numen 发表于:2014-12-10 13:40:37
以下是引用KING6688在2014-12-10 12:27:28的发言:
我的40部分材料:
4.帽子:反新疆纸帽(带边深U帽)
5. 音圈:KAP:CCAW/4F,
能否帮忙指点下!谢谢!!
首先看得出你的喇叭配置不错。
1、清晰度方面。
本来这种偏重低频的喇叭,中高频就是软肋。 重点的是比较整体的音效。
客人会觉得清晰度问题的话,那你就给他两层线的,成本还好些。
2、高频弱,你听起来响度会小。 这个看客户需求了。如果你低音发挥得好,相信会更引人注目。
低频的好坏,有时候被音箱给限制了。音箱没做好,到处漏气、空间太小、以及设计不搭配,诸多音箱本身问题,
音箱不好,不配用 这么好的喇叭,给一个普通的足够他用了。
上面的问题点,个人觉得:
1、双钕磁配置,磁性能够强大。
是不是需要考虑导磁问题了,如果导磁做好,我相信这样的配置,B值还会更好。 (华司和U铁)的厚度可否稍稍加厚一些。
KING6688 发表于:2014-12-10 15:45:32
多谢大师的详细指导!经过再次调整,做以下方案试制:
   1.对比发现,正如大师所言,N42磁铁确实过大,导致失真,确定使用N35等级后,音质均衡了不少,同时节约了成本;
     低音明显,中高音也不差的效果,类似BOSE音效;
   2.另一方案,使用橡胶边或PU边黑铝锅底一体鼓纸,这样做的结果希望中高音提升,弱化一点低音,类似于HP的音效;
   3.实践中,音圈打孔可能会影响辐射音箱被动盆效率?
后辈受教了!再次谢谢!图片点击可在新窗口打开查看
SPL100 发表于:2014-12-10 15:57:48
可以考虑从鼓纸重量上先入手,后考虑厚度,配方,叩解度。
