标题:大家来看看这两个
wsf912 发表于:2006-10-16 19:37:40
样品  尺寸 复合盆直径155mm
 Name  Value  Unit  Comment
 Electrical Parameters
 Re  6.89  Ohm  electrical voice coil resistance at DC
 Le  1.100  mH  frequency independent part of voice coil inductance
 L2  1.469  mH  para-inductance of voice coil
 R2  5.59  Ohm  electrical resistance due to eddy current losses
 Cmes  252.20  µF  electrical capacitance representing moving mass
 Lces  64.74  mH  electrical inductance representing driver compliance
 Res  45.14  Ohm  resistance due to mechanical losses
 fs  39.4  Hz  driver resonance frequency
 Mechanical Parameters
 (using laser)
 Mms  16.381  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  15.54  g  mechanical mass of voice coil and diaphragm without air load
 Rms  1.439  kg/s  mechanical resistance of total-driver losses
 Cms  1.00  mm/N  mechanical compliance of driver suspension
 Kms  1.00  N/mm  mechanical stiffness of driver suspension
 Bl  8.06  N/A  force factor (Bl product)
 Lambda s  0.066     suspension creep factor
 Loss factors
 Qtp  0.37     total Q-factor considering all losses
 Qms  2.82     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.43     electrical Q-factor of driver in free air considering Re only
 Qts  0.37     total Q-factor considering Re and Rms only
 Vas  24.0958  l  equivalent air volume of suspension
 n0  0.329  %  reference efficiency (2 pi-radiation using Re)
 Lm  87.37  dB  characteristic sound pressure level
 rmse Z  3.76  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  2.30  %  root-mean-square fitting error of transfer function Hx (f)
 Series resistor  0.00  Ohm  resistance of series resistor
 Sd  130.70  cm  diaphragm area
我做的
 Re  7.16  Ohm  electrical voice coil resistance at DC
 Le  0.651  mH  frequency independent part of voice coil inductance
 L2  0.671  mH  para-inductance of voice coil
 R2  1.97  Ohm  electrical resistance due to eddy current losses
 Cmes  304.85  µF  electrical capacitance representing moving mass
 Lces  40.11  mH  electrical inductance representing driver compliance
 Res  65.56  Ohm  resistance due to mechanical losses
 fs  45.5  Hz  driver resonance frequency
 (using laser)
 Mms  13.855  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  12.774  g  mechanical mass of voice coil and diaphragm without air load
 Rms  0.693  kg/s  mechanical resistance of total-driver losses
 Cms  0.882  mm/N  mechanical compliance of driver suspension
 Kms  1.13  N/mm  mechanical stiffness of driver suspension
 Bl  6.74  N/A  force factor (Bl product)
 Lambda s  0.053     suspension creep factor
 Loss factors
 Qtp  0.564     total Q-factor considering all losses
 Qms  5.716     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.624     electrical Q-factor of driver in free air considering Re only
 Qts  0.562     total Q-factor considering Re and Rms only
 Vas  29.5954  l  equivalent air volume of suspension
 n0  0.430  %  reference efficiency (2 pi-radiation using Re)
 Lm  88.54  dB  characteristic sound pressure level (SPL at 1m for 1W @ Re)
 Lnom  89.02  dB  nominal sensitivity (SPL at 1m for 1W @ Zn)
 rmse Z  2.43  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  1.75  %  root-mean-square fitting error of transfer function Hx (f)
 Sd  153.94  cm  diaphragm area
HiFi扬声器,请大家比较一下,给点建议吧,多谢了。
87725232 发表于:2006-10-17 13:48:50
客人的Sd  130.70,你的是153.94
口径都比他的大  ,Fs 比他还高,Bl还比他低那么多?
而且你的质量比他轻,阻尼还比他的小,顺性又不如他
唯独就效率还行,BL比他小,Q值也就比他的大。这值保证的也还行
不觉得你的有多好
wsf912 发表于:2006-10-18 7:57:29
我刚入行不久,该如何改,给点建议吧,以让和我一样的新人能共同进步,多谢了(下次我把曲线什么贴上来大家看看)
spk888 发表于:2006-10-18 8:13:45
下面那个是你做的吧!?
继续努力!
wsf912 发表于:2006-10-18 17:43:41
这是我入行后的第二个产品(第一个也在进行当中),从消声室测试情况来看,f0=40Hz(样品),我的44Hz;灵敏度 84.2dB(样品),我的89.2dB,灵敏度这么高是好事还是坏事?
另外我有个问题请教一下:为什么HiFi扬声器要求Qts在0.3-0.7之间?是不是越低越好?Qts对低音的音质有什么影响?
希望哪位DX能帮忙解答一下?先谢了
hualong 发表于:2006-10-19 9:36:33
以后 去上课吧
wsf912 发表于:2006-11-5 13:01:45
 Re  6.94  Ohm  electrical voice coil resistance at DC
 Le  0.708  mH  frequency independent part of voice coil inductance
 L2  0.546  mH  para-inductance of voice coil
 R2  1.53  Ohm  electrical resistance due to eddy current losses
 Cmes  266.95  µF  electrical capacitance representing moving mass
 Lces  70.44  mH  electrical inductance representing driver compliance
 Res  91.38  Ohm  resistance due to mechanical losses
 fs  36.7  Hz  driver resonance frequency
 (using laser)
 Mms  11.256  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  10.371  g  mechanical mass of voice coil and diaphragm without air load
 Rms  0.461  kg/s  mechanical resistance of total-driver losses
 Cms  1.670  mm/N  mechanical compliance of driver suspension
 Kms  0.60  N/mm  mechanical stiffness of driver suspension
 Bl  6.49  N/A  force factor (Bl product)
 Lambda s  0.039     suspension creep factor
 Loss factors
 Qtp  0.398     total Q-factor considering all losses
 Qms  5.626     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.427     electrical Q-factor of driver in free air considering Re only
 Qts  0.397     total Q-factor considering Re and Rms only
 Vas  42.9442  l  equivalent air volume of suspension
 n0  0.478  %  reference efficiency (2 pi-radiation using Re)
 Lm  88.99  dB  characteristic sound pressure level (SPL at 1m for 1W @ Re)
 Lnom  89.61  dB  nominal sensitivity (SPL at 1m for 1W @ Zn)
 rmse Z  5.49  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  2.17  %  root-mean-square fitting error of transfer function Hx (f)
 Sd  134.78  cm  diaphragm area
第二次改进后的结果,给点意见吧?
gxz797 发表于:2006-11-6 15:37:36
这是用什么软件测的,参数很详细。
wsf912 发表于:2006-11-6 17:26:49
Klippel
卜凡 发表于:2006-11-7 12:08:27
比一班的軟件要多出好幾個參數喲,夠詳細的。
