共21 条记录, 每页显示 10 条, 页签: [1] [2][3]
标题:来看看这个2寸低音单元
wsf912 发表于:2007-5-12 8:58:39
 来看看这个2寸低音单元,用于开口箱,各位高手给点意见吧.图片点击可在新窗口打开查看
 Name  Value  Unit  Comment
 Electrical Parameters
 Re  7.35  Ohm  electrical voice coil resistance at DC
 Le  0.297  mH  frequency independent part of voice coil inductance
 L2  0.135  mH  para-inductance of voice coil
 R2  1.00  Ohm  electrical resistance due to eddy current losses
 Cmes  104.65  µF  electrical capacitance representing moving mass
 Lces  25.17  mH  electrical inductance representing driver compliance
 Res  29.09  Ohm  resistance due to mechanical losses
 fs  98.1  Hz  driver resonance frequency
 Mechanical Parameters
 (using laser)
 Mms  2.142  g  mechanical mass of driver diaphragm assembly including air load and voice coil
 Mmd (Sd)  2.117  g  mechanical mass of voice coil and diaphragm without air load
 Rms  0.704  kg/s  mechanical resistance of total-driver losses
 Cms  1.230  mm/N  mechanical compliance of driver suspension
 Kms  0.81  N/mm  mechanical stiffness of driver suspension
 Bl  4.52  N/A  force factor (Bl product)
 Lambda s  0.136     suspension creep factor
 Loss factors
 Qtp  0.379     total Q-factor considering all losses
 Qms  1.875     mechanical Q-factor of driver in free air considering Rms only
 Qes  0.474     electrical Q-factor of driver in free air considering Re only
 Qts  0.378     total Q-factor considering Re and Rms only
 Vas  0.2750  l  equivalent air volume of suspension
 n0  0.053  %  reference efficiency (2 pi-radiation using Re)
 Lm  79.41  dB  characteristic sound pressure level (SPL at 1m for 1W @ Re)
 Lnom  79.78  dB  nominal sensitivity (SPL at 1m for 1W @ Zn)
 rmse Z  4.62  %  root-mean-square fitting error of driver impedance Z(f)
 rmse Hx  3.36  %  root-mean-square fitting error of transfer function Hx (f)
 Series resistor  0.00  Ohm  resistance of series resistor
 Sd  12.57  cm  diaphragm area
wsf912 发表于:2007-5-23 18:00:43
我的2寸低音做的这么辛苦,没人支持一下吗?
lihailan456 发表于:2007-5-23 20:29:30
不懂
spk888 发表于:2007-5-28 10:18:16
以下是引用wsf912在2007-05-12 08:58:39的发言:
 (using laser)
 Loss factors
有些参数很让人吃惊,低Q低FS 对小单元来说没什么实际的意义,要是贴上曲线,能更好的品味一下!图片点击可在新窗口打开查看
glaive 发表于:2007-5-28 11:04:04
内磁大音圈的做法.方向应该是这样的.找客人要个样品回来就容易解决了
glaive 发表于:2007-5-28 11:06:01
有点不对劲.灵敏度要求那么低
ldb202020 发表于:2007-5-28 19:01:54
2寸低音"FS98.1是太低了,灵敏度也低了!为什么这么设计???
wsf912 发表于:2007-5-28 19:13:47
 下载信息  [文件大小:   下载次数: ]
图片点击可在新窗口打开查看点击浏览该文件:
曲线
jma 发表于:2007-5-28 21:47:07
这2寸的喇叭也不怎么滴呀,,看实际的曲线FS好象没有98HZ哦,,
wsf912 发表于:2007-5-29 15:15:45
我有fs=80多的样品,也有100多的,曲线我随便传了一张,低fs是客户要求的.
Processed in .06250 s, 3 queries.
