共48 条记录, 每页显示 20 条, 页签: [1] [2][3]
标题:[讨论]EIA-426-B与IEC60268-5的标准有何差异?
Acoustics 发表于:2006-4-17 15:03:21
两种频谱特性(或功率谱)有何不同?
ephemera 发表于:2006-4-21 21:12:15
水仙 发表于:2006-4-21 22:42:22
好东西,确实有很多朋友和同行想知道!
不知有否原文(英文或中文均可)?
ephemera 发表于:2006-4-22 19:57:21
ephemera 发表于:2006-4-22 19:59:16
ephemera 发表于:2006-4-22 20:03:18
水仙 发表于:2006-4-22 21:40:19
多谢提供!
WANGFUYU 发表于:2006-4-22 23:26:52
真是好东西,顶一下!值得大家好好消化
LGY 发表于:2006-4-23 22:38:54
看了后一个字.过隐.还有没有其它的标准,上来看一下.
grass 发表于:2006-4-24 9:58:13
多谢DX!
Ryuusan 发表于:2006-6-7 14:35:32
好东西,何处可以买到啊!
darry 发表于:2006-6-10 21:05:15
建议Admin将其转换成PDF放在资料室便于查看,谢谢
水仙 发表于:2006-6-20 10:28:14
感谢无私奉献!
其他GB在资料室有一部分.
ivan73 发表于:2006-7-8 15:14:41
感谢无私奉献!
图片点击可在新窗口打开查看图片点击可在新窗口打开查看
Acoustics 发表于:2006-7-14 16:43:56
多谢前辈无私奉献!
Acoustics 发表于:2006-7-17 12:51:39
Acoustics 发表于:2006-7-17 12:52:57
电声爱好者 发表于:2006-7-19 13:54:54
The AES2-1984 standard
This is a standard for loudspeaker components by the Audio Engineering Society. It is very commonly used, and, although meant for components, it is also often used for individual ways of an active system. It specifies a 6 dB crest factor pink noise signal, with a bandwidth of one decade. For example, a bass loudspeaker could use a 60-600 Hz band, whereas a high frequency unit could use 1500-15000 Hz. The illustration shows the spectrum of both AES signal spectrum examples. The duration of the test is 2 hours, after which the component should not show appreciable damage.
电声爱好者 发表于:2006-7-19 13:55:18
The IEC268-1 (1985) standard
This is a standard by the International Electrotechnical Commission. It specifies a 6 dB crest factor pink noise signal over which an IEC programme filtering has been applied. This programme spectrum tries to approximate the frequency content of real music, and shows reduced lows and highs. The illustration compares this spectrum to the AES ones.
Test duration is 100 hours, after which the speaker should not show appreciable damage.
电声爱好者 发表于:2006-7-19 13:55:46
he EIA RS-426-A (1980) standard
This is a standard by the (USA) Electronic Industries Association. The duration of the test is 8 hours, after which the speaker should not show appreciable damage. The signal is also 6 dB crest factor pink noise signal, but with programme filtering that is different to the IEC standard and is also shown on the previous illustration.
