共13 条记录, 每页显示 20 条, 页签: [1]
标题:一些国家标准
Acoustics 发表于:2006-7-31 17:21:39
KSC 06026KSC60261985/12/14콘스피이커 통칙GENERAL RULES FOR CONE TYPE LOUDSPEAKERSコーンスピーカ通則この規格はダイナミックコーンスピーカの寸法、性能、表示などを決める時の基準について規定する。 JISC5530, IEC 60268-5, IEC 60014
 KSC 06027KSC60271985/12/14콘스피이커 시험 방법TESTING METHODS FOR CONE TYPE LOUDSPEAKERSコーンスピーカ試験方法この規格はダイナミックコーンスピーカの試験方法について規定する。 JISC5531, IEC 60268-5, IEC 60268-1
阿宝 发表于:2006-8-7 16:56:50
DX,能否把各个标准发上来给俺们看一下。
hyonsoo 发表于:2006-8-7 17:35:20
Acoustics XD你把他放在资料室吧。
darry 发表于:2006-8-20 22:18:13
KSC是什么标准?
水仙 发表于:2006-8-21 13:04:12
韩国的标准
zdsound 发表于:2006-9-4 16:13:52
找标准到:www.zdsound.com
水仙 发表于:2006-9-18 14:46:15
IEC 60268-5 AMD 2
Sound-system equipment - Part 5: Loudspeakers; Amendment 2
IEC 60268-7
Sound system equipment - Part 7: Headphones and earphones
IEC/TR3 60268-13
Sound system equipment - Part 13: Listening tests on loudspeakers
IEC 60268-14
Sound system equipment. Part 14 : Circular and elliptical loudspeakers; outer frame
diameters and mounting dimensions
IEC 60327
Precision method for pressure calibration of one-inch standard condenser microphones by the reciprocity technique
IEC 60581-5
High fidelity audio equipment and systems; Minimum performance requirements. Part 5 : Microphones
IEC 60581-7
High fidelity audio equipment and systems; Minimum performance requirements. Part 7 : Loudspeakers
IEC 60581-10
High fidelity audio equipment and systems; Minimum performance requirements. Part 10 : Headphones
CCITT G SUP 25 III.1
Guidelines for placements of microphones and loudspeakers in telephone conference rooms
ITU-T T.120
Data protocols for multimedia conferencing
EIAJ CP-2903-1992
Classification and measuring method for low magnetic leakage flux loudspeaker systems
EIAJ RC-8124-1995
Loudspeaker systems
EIAJ RC-8125-1999
Piezoelectric loudspeakers
EIAJ RC-8140-1998
EIAJ RC-8160-1988
Microphones
EIAJ RC-8162A-1996
Power supply feeding for microphones
EIAJ RC-8163-1996
Test methods of microphone or earphone cord
EIAJ RC-8180A-1994
Sounders and buzzers
EIAJ RCX-8101-1995
Electrodynamic loudspeakers
EIAJ RCX-8102-1996
Headphones for Hi-Fi listening
水仙 发表于:2006-9-18 14:49:08
楼上的有EIAJ RC-8124标准吗?
水仙 发表于:2006-9-18 14:52:43
JIS C 5502-1991
Microphones
JIS C 5504-1992
Horn type loudspeakers
JIS C 5512-1986
Hearing aids
JIS C 5515-1981
Standard condenser microphones
JIS C 5532-1994
Loudspeakers for sound system equipment
JIS C 6020-1995
General rules and testing methods for intercommunication equipments
grass 发表于:2006-9-18 16:46:33
请提供一些国家标准的电子文档,包括包装,印刷,表面处理,磁性材料等
水仙 发表于:2006-9-19 21:22:35
这些要去标准局查阅或购买!大一点的单位原来都有订的。
ybx1216 发表于:2006-9-20 17:31:23
水仙兄,不知哪裡可以購買到IEC和JIS標準,是否有地址和電話,謝謝!
jonyue 发表于:2009-1-15 19:26:08
是呀,我也顶下,有的话给我发一个,我的邮箱:jonyue@126.com
