共5 条记录, 每页显示 20 条, 页签: [1]
标题:[求助] Chauvenet和Peirce标准
lliiying330 发表于:2011-9-20 21:37:15
请问 Chauvenet和Peirce标准是啥呢?我是新手 忘指教哦
水仙 发表于:2011-9-21 8:19:36
Chauvenet's criterion
In statistical theory, the Chauvenet's criterion (named for William Chauvenet[1]) is a means of assessing whether one piece of experimental data — an outlier — from a set of observations, is likely to be spurious.
To apply Chauvenet's criterion, first calculate the mean and standard deviation of the observed data. Based on how much the suspect datum differs from the mean, use the normal distribution function (or a table thereof) to determine the probability that a given data point will be at the value of the suspect data point. Multiply this probability by the number of data points taken. If the result is less than 0.5, the suspicious data point may be discarded, i.e., a reading may be rejected if the probability of obtaining the particular deviation from the mean is less than 1/(2n).
For instance, suppose a value is measured experimentally in several trials as 9, 10, 10, 10, 11, and 50. The mean is 16.7 and the standard deviation 16.34. 50 differs from 16.7 by 33.3, slightly more than two standard deviations. The probability of taking data more than two standard deviations from the mean is roughly 0.05. Six measurements were taken, so the statistic value (data size multiplied by the probability) is 0.05×6 = 0.3. Because 0.3 < 0.5, according to Chauvenet's criterion, the measured value of 50 should be discarded (leaving a new mean of 10, with standard deviation 0.7).
水仙 发表于:2011-9-21 8:32:18
Peirce's criterion
Another method for eliminating spurious data is called Peirce's criterion. It was developed a few years before Chauvenet's criterion was published, and it is a more rigorous approach to the rational deletion of outlier data. See S. Ross reference below.
 下载信息  [文件大小:   下载次数: ]
图片点击可在新窗口打开查看点击浏览该文件:piercescriterion.rar
水仙 发表于:2011-9-21 8:53:08
http://docs.lib.noaa.gov/rescue/cgs/001_pdf/CSC-0019.PDF#page=215
lliiying330 发表于:2011-9-23 11:24:26
图片点击可在新窗口打开查看 很感谢呢 嘿嘿
Processed in .03125 s, 3 queries.
