标题:[求助] 有谁使用过 NTI 的puresound?
grass 发表于:2006-8-30 8:33:24
有哪位大虾用过,请介绍心得
Speaker Analyzer "PureSound"
New:
- Supports the accessories
 Input Switcher &  Output Switcher
PureSound is a comprehensive speaker test solution, comprising a unique and reliable defects analysis. The typical cycle time for a complete speaker test is less than three (3) seconds including the outstanding Rub&Buzz analysis with its 100% correlation to the human ear.
The test system is based on the high-speed audio analyzer RT-2M operated via the PC-based turnkey production software RT-SpeakerTM. The test system provides a comprehensive set of measurements for the total quality control of drivers, tweeters, woofers, headphones, speaker boxes and 100V speakers:
RT-SpeakerTM quickly and consistently measures all audible imperfections of your transducers or speakers, based on the PureSoundTM technology. PureSoundTM detects any audible manufacturing flaws of speakers or transducers, such as air-leaks, coils out of center, rubbing voice coils, loose particles, touching wires, etc.
Screenshot: View all test results
Simple and intuitive operation
The concise user interface simplifies the operation for every access level. The complete system setup and -configuration for a new transducer is completed in less than 30 minutes. Changes in the test properties are conducted a few seconds, maximizing the yield of your production lines.
RT-SpeakerTM software grants a very detailed view of all speaker parameters to the system specialist but is kept very simple in its operation at the same time. Complete test procedures may be load by a mouse click, thus minimizing the conversion time between batches.
Screenshot: PASSED
Customized tolerance definition
RT-SpeakerTM turnkey production software features custom specific test setups and tolerance band definitions. All conducted measurements are compared in real-time against user-defined relative or absolute QC tolerances resulting in reproducible PASSED/FAILED status of each device under test.
The smart “learn” mode simplifies tolerance definition by feeding the system with a representative set of “Golden Samples”. RT-SpeakerTM derives then its tolerance criteria automatically, following the predefined QC rules.
Screenshot: Frequency Response Test with one tolerance field
Screenshot: Frequency Response Relative
The unique tolerance management supports five different product quality clusters such as “excellent”, “decent”, “acceptable” and “reject”, allowing you to charge a premium for selected “excellent” products. This feature also supports the automated discrimination of manufacturing flaws at the same time.
Screenshot: Frequency Response Test with three tolerance fields
Integration into production lines
The system can be easily integrated into existing production lines or connected to host controllers. The extremely short test cycle time enables the system to especially cope with high volume production lines. The implemented, patented measurement algorithms have been optimized for factory noise immunization. Ambient factory noise is suppressed and thus not affecting the test results in optimized test configurations. This maximizes your production line yield and allows to conduct the same measurement in R&D environment as well as in the noisy production floor.
Frequency Response
A fast sweep signal with custom-defined resolution serves as the stimulus to simultaneously measure:
This highly accurate and repeatable set of measurements occupies the device under test for less than a second.
Distortion Test
Simultaneously or conducted as a more detailed separate test, the harmonic distortion behavior of the device my be assessed. The available distortion measurements comprise: THD+N, THD, k2, k3, k4 or k5 harmonics order analysis. Needless to say that all the measurements are optimized in speed to the physical limits, offering maximized utilization of the production lines.
grass 发表于:2006-8-30 8:33:53
Rub&Buzz Test with 100% correlation to the ear
Customers can enjoy fast and reliable Rub&Buzz test results even in noisy factory environments. The typical Rub&Buzz test time is less than one second (< 1.0 sec.).
The patented PureSoundTM technology is a revolutionary new approach for perceptual audio testing. The algorithms model the human ear as a transient analyzer, effectively measuring every audible manufacturing imperfection with an unmatched correlation to the acuity of “Golden Ears” – “you measure what you hear”.
PureSoundTM detects the even subtle manufacturing flaws of speakers or transducers enabling the automatic qualification of the nature of these defects.
Hundreds of systems around the globe are in day to day operation, benchmarking against the best human golden ears performance. PureSoundTM repeatedly provides consistent, objective test results with a 100% correlation to the human ear.
 Screenshot: Rub and Buzz Test PASSED
 Screenshot: Rub and Buzz Test, FAILED by rubbing voice coil
Other test systems using conventional FFT analysis or high order harmonic tracking filters typically fail to discriminate timely short appearing Rub&Buzz effects like loose particles as the energy content of the signal is not sufficient for a reliable detection. This insufficiency may result in shipping production badges to clients with audible defects, leading to warranty returns and unnecessary shipping costs.
 Screenshot: Rub and Buzz Test, FAILED by loose particles
Serial Number Handling
RT-SpeakerTM also supports bar code readers for manual and automatic serial number handling. Flexible barcode interpretation supports extraction of the speaker type and steering the automatic loading of the corresponding speaker test parameter. All measured speaker test results are logged to a data file including the bar code. This also permits detailed quality monitoring in the after-sales service and simplifies data comparisons of returned speakers, being extremely supportive for speaker manufacturers or rental companies.
Screenshot: Serial Number Handling
Thiele/Small Parameter
The production test software RT-SpeakerTM supports the individual assessment of Thiele/Small parameters R, Rs, R0, Qms, Qes, Qts, C, L and df without prolonging test time. The sensitive T/S parameter are an excellent monitoring base for the CPK / PPK module, effectively supervising the stability of your manufacturing line.
Screenshot: Thiele/Small Parameters
Multiple Measurements
The optional Input Switcher RT-IS and Output Switcher RT-OS support automated sequential measurements of e.g. assembled speaker sets with crossovers or testing of speaker parameters with two or more microphones placed at different locations, such as at the front & rear side of woofers.
Remote Monitoring
The integrated data socket server decouples the data storage from the physical location of the manufacturing lines. The data socket viewer supports remote monitoring of one or more production lines from any remote PC for quality assessment purposes. Communication is established via a simple TCP/IP link.
Screenshot: Remote Monitoring
Screenshot: Data socket setting
Statistical Process Control (SPC)
Statistical data are calculated on the fly while the production test is running. Detailed histogram, trend analysis and CPK/PPK values provide a clear assessment of the currently  manufactured quality.
Speaker parameter are sensitive to changing environmental factors like temperature and humidity. The PureSoundTM supports the detailed online correlation of test results with the actual temperature & humidity with the “Environmental Sensor” connected. This is a powerful tool for tracing the cause of failed speaker batches or initiating necessary calibrations or reference sampling to achieve accurate PASSED/FAILED test results.
Data Logging
All test results are automatically stored as ASCII files for later evaluation by using e.g. Microsoft Excel. The user may choose between single, batch, daily or weekly logging files with individually specified logging data.
Screenshot: Statistics Overview
Screenshot: Statistical Trend Analysis correlated with temperature
Screenshot: Statistical Histogram
Further Applications:
R&D Speaker Evaluation
PureSoundTM also supports R&D test requirements such as high resolution frequency response measurements with up to 500 points.
The PureSoundTM technology acquires important non-linearity finger-prints, enabling the comparison of every design stage of a speaker over its entire life. Such a continuous Rub&Buzz monitoring process supports the objective quantification of the impact of design changes to audible effects, minimizing design flaws.
The loudspeaker magazine VoiceCoil has tested PureSound, the speaker analyzer,  in detail. An objective test report about the leading speaker test system.  Download the test report here.
QC Sampling Inspection
“RT Compliance for Speakers” is a functional extension of the RT-Speaker software conducting detailed speaker parameter measurement, according to the international standard IEC 60268-5 for QC sampling inspection or product developments. RT-Compliance supports measurements of the complete Thiele/Small parameters using the added mass method.
rodger 发表于:2006-8-31 11:41:54
那次来人推荐过,不过后来没有采用.
以前听国外同事说牵涉到什么专利问题,而且也不是很便宜呀.
shaoyiwujin 发表于:2006-9-1 8:55:48
在用,
一般而已.
功能没有SOUND CHECK多,有SOUND CHECK就不用买了
Acoustics 发表于:2006-9-1 9:12:52
这一功能不错,其他测试系统还没看到有此功能.
DAAS 发表于:2006-9-2 19:38:41
以下是引用shaoyiwujin在2006-09-01 08:55:48的发言:
在用,
一般而已.
米人啊,兄弟,好羡慕...
zwdzhong 发表于:2006-9-3 16:24:35
还行,没有SOUNDCHECK好用,操作还可以,但是调试就不怎么样容易了.
grass 发表于:2006-9-4 8:42:19
在用,
一般而已.
Rub&Buzz Test with 100% correlation to the ear 这个功能在使用吗?准确率如何?什么样的异常音能发现,什么样的无法判定?
Completist 发表于:2006-9-4 17:49:46
We are in use .
白菜 发表于:2006-9-4 18:14:12
以下是引用zwdzhong在2006-09-03 16:24:35的发言:
soundcheck?好用吗?我用了一下,不怎么好用啊。
DX能不能上传一份你用soundcheck测的曲线上来看看啊。
立顿奶茶 发表于:2006-9-4 18:52:01
我们公司有多台NTI,基本操作都会。你想知道哪方面的呢?
立顿奶茶 发表于:2006-9-4 18:55:25
楼上的朋友们为什么说不好用呢?就从听纯音这一方面来说,就很严格的。
还有调试也不是太复杂啊(在我们公司)。soundcheck是很不错的。就是好多功能给限制了。
Completist 发表于:2006-9-5 12:31:14
NTI可以同时快速测试出SPL ,Impedance ,T/S parameters以及纯音,但是对于纯音测试结果来说,受外界影响很大.
grass 发表于:2006-9-7 10:25:06
以下是引用立顿奶茶在2006-09-04 18:52:01的发言:
我想知道用于纯音检听得话,可靠性如何?误判的几率有多大?
多谢!
齐迦社 发表于:2006-9-7 17:22:23
以下是引用Completist在2006-09-04 17:49:46的发言:
We are in use .
You're used by whom,buddy??
Completist 发表于:2006-9-7 18:28:32
以下是引用齐迦社在2006-09-07 17:22:23的发言:
We are in use .
me .
grass 发表于:2006-9-8 8:17:07
so please tell me how it works in buzz testing?
listen 发表于:2006-9-23 22:29:27
楼上是AAC的把!!那里好象有70多台!!!!
与SC比,各有各的优点
鱼缸 发表于:2006-9-28 13:14:12
我也想知道Rub&Buzz怎么测。或者是需要什么样的环境。扫频信号可以用来测准确的Rub&Buzz吗?表达方式是百分数表达的是什么?
ttl020520 发表于:2006-11-30 13:28:10
NTI相较于其他系统优势就在它的纯音测试,而且申请了好多专利
听过NTI的讲座,实际纯音测试效果不错,误判的几率也不大
可以客观的量化异常音的产生,在积累了一定的生产测试经验后,可以根据
量化的测试结果判断出异常音由哪个部件产生,控制产品不良率比较有效
