共2 条记录, 每页显示 20 条, 页签: [1]
标题:求教---BK2012测试阻抗曲线的设定
sbvfhpn 发表于:2012-11-19 15:04:43
那位大虾能帮我看下下面测试阻抗曲线的BK程序那里有问题吗,计算出来的阻抗曲线是反向的。
或者有设定好的程序发个邮箱(XSQR@163.COM)也可以,小弟万分感谢!!!
B&K_2012
IMP CV
           :Graph:SOurce_A         Buffer
           :Graph:Save_Curve
           :Graph:SOurce_A         Off
           :Graph:SOurce_B         Buffer
            :Mode:Steady_State_R
  :Steady_State_R:Sweep                 Log_Iso
  :Steady_State_R:STArt_Frequency  20.000
  :Steady_State_R:STOp_Frequency   10.00k
  :Steady_State_R:Iso_Series            R80
  :Steady_State_R:Detector_Band      0.10
  :Steady_State_R:Detector_Delay      0.00
  :Steady_State_R:Detect_Max_Time  100m
           :INPut:Input_Channel             Direct
           :INPut:Direct                         Single_Ended
           :INPut:Direct_High_Pass         1
           :LEvel:Input_Autorange          ON
           :LEvel:Max_Input_Abs            100m
           :LEvel:Output_F1_Abs            1
           :Graph:Operation                   XY_Axes_Graph_A
           :Graph:X_Axis                       LOg
           :Graph:X_Range                    3.
           :Graph:Y_Range                    20.000
$:Please connect Dir.Input to IEA I SENSE then Proceed.
   :Auto_Sequence:Event            Proceed
   :Auto_Sequence:Await_Event
           :STArt
   :Auto_Sequence:Graph_Update
:Block_Arithmetic:Operation            Reciprocal_Value
:Block_Arithmetic:Result                 Buffer_And_M1
:Block_Arithmetic:Label                  "IMPEDANCE "
:Block_Arithmetic:Operand_A          M1
:Block_Arithmetic:Reciprocal_Val_A
:Block_Arithmetic:Operation            SUbtract
:Block_Arithmetic:Magn_K_Abs       1.000000
:Block_Arithmetic:Subtract_A_K
   :Screen_Format:Display_A_And_B
:CUrsor:Z B,0
:CUrsor:X 100
kekewf 发表于:2013-1-5 16:03:07
看到你的测试序列,感觉
反了一是你的操作顺序反了,二是你的程序反了,或者计算公式搞错了,
既然你懂测试序列,建议你看看BK2012所带的磁盘 VP7419
其中的MY_ASQ_1 和MY_ASQ_2
