共10 条记录, 每页显示 20 条, 页签: [1]
标题:手机受话器的可靠性试验
Acoustics 发表于:2006-9-19 9:44:47
General Requirements
Operating Temperature Range :
 -30℃ to +70℃ without loss of function.
Storage Temperature Range :
 -40℃ to +85℃ without loss of function.
General Raliability
Immediately after the test.the samples shall be stored under climatic conditions such as normally exist in ordinary rooms or laboratories.Unless otherwise noted.the recovery period shall be 4 hours at least. The intermediate and final date must meet the limits of parameter or curve described in the Spec. Each test require 12 Samples.
Temperature Shock:
-40°C/+85°C 30 cycles.30 minutes at each temperature .20 second maximum transition time
Static Humidity test:
Soak samples to +70°C with 95% relative humidity for 240 hours.
Operation Life:
+85 deg C for 96 hours .under rated power(5mW).Simulated Program Signal per IEC268-1.
Max. Power:
+25 deg C . under max power (10mW). Signal to be applied for a duration of 1 second on, 60 seconds off, repeated 60 times.Program Signal per IEC268-1.The transducer shall function correctly after this conditioning.
Rub and Buzz:
The input power shall be set at 5mW. Using an audio oscillator, sweep from 300 to 3400 Hz with the receiver in free air. There shall be no buzzes, rattles, nor spurious noises.
Random vibration test
Refer to IEC 68-2-27
Mechanical shock:
Refer to IEC 68-2-34
RESONANCE SWEEP TEST :
Sweep receivers from fo-free-50Hz to fo-free+50Hz at 25°C and at rated power 12 hours continuously. The swept tone shall pass from fo-free-50Hz to fo-free+50Hz in 6 seconds and repeated without interruption.
SALT SPRAY TEST
PER CNS4158-H2040 , The test time is 48 hours.
Acoustics 发表于:2006-9-19 9:47:13
看来要求不低,不知是否合理?
参照的标准是?
电声爱好者 发表于:2006-9-20 17:10:08
Operation Life:
要求确实比较高,很多普通材料在85度以上已经不能正常工作了.如PET的Tg为78度
电声爱好者 发表于:2006-9-20 17:11:07
普通ABS耐温也就80度
ybx1216 发表于:2006-9-20 17:26:33
mylar改用PEI和PEN,塑殼用PBT+GLASS15%就OK了,樓主的可靠性试验有點與AAC相似
zdsound 发表于:2006-9-22 16:19:10
ybx1216你是AAC的吗,他用的都是我浙大通信的测试仪器(电声测试仪)
品位一生 发表于:2006-11-3 23:11:33
楼主是AAC的吧,我看过AAC的规格书,和你的条件差不多的
zdsound:“ybx1216你是AAC的吗,他用的都是我浙大通信的测试仪器(电声测试仪)”
听说AAC已经不用国产的测试仪器了,只用LISTEN、NTI
zdsound 发表于:2006-11-4 10:25:04
AAC我们都上门服务N多次了  一次性安装了40套  测试MOTO双耳机
[此贴子已经被作者于2006-11-04 10:26:23编辑过]
flying 发表于:2006-11-11 9:34:37
呵,你们都是前辈,学习了
olive_shw 发表于:2007-7-14 17:37:41
各位DX,能不能多整点关于功率寿命试验的,譬如:EIA,俺很想知道啊!
