共7 条记录, 每页显示 20 条, 页签: [1]
标题:[求助]求Audio Test Set注册器或破解
dabster 发表于:2007-6-7 9:42:38
软件介绍可看http://www.interflex.com/audiorta/
Use your Sound Card and the
"Audio Test Set"(tm) from
InterFlex Systems
Output FeaturesGenerate Sweep tones, Continuous tones,  sinewave, triangle, white & pink noise
Input FeaturesVectorscope, Time domain scope, Spectrum analysis
Analysis FeaturesTracking Generator sweeps output tone and measures input in full duplex
Measurement UsesMeasuring balance, frequency response, filter characteristics, microphone response, speaker output quality, finding noise floor in audio devices, and more
Educational ValueLearn about Audio devices, how to evaluate quality, dynamic range, distortion
Compare PricesIf you price a benchtop Audio Spectrum Analyzer with Tracking Generator you'd see they cost literally thousands of dollars.
With your full duplex sound card, and the Audio Test Set(tm) you can do almost all of the audio analysis you can with an expensive Audio Spectrum Analyzer
How to purchaseUse your Visa, MasterCard, Discover, or American Express card to place an order. Click Here to Order
You will be sent a User Name and Registration Key to open up the features you purchase.
Use the order form to get your copy of the Audio Test Set Real Time Audio Generator and Spectrum Analyzer, or to get a 30 day trial version
利用普通声卡即可做多项功能的测试
不知哪里能找到破解或注册版。
[此贴子已经被作者于2007-07-09 12:55:11编辑过]
dabster 发表于:2007-7-9 13:00:23
ebay上也有该款软件出售,可惜要米太多。
http://cgi.ebay.com/Realtime-Audio-Spectrum-Analyzer-Tracking-Gen_W0QQitemZ230149843095QQcmdZViewItem
abob 发表于:2007-7-19 19:23:55
0day上见过有个audio tester, 不过和这个不是一样的东东,
[此贴子已经被作者于2007-07-19 19:27:18编辑过]
dabster 发表于:2007-7-21 14:41:27
以下是引用abob在2007-07-19 19:23:55的发言:
不一样啊!
lingyi 发表于:2007-7-23 11:36:05
看不出这个软件有什么特别的地方,还不如用LoudSpeaker LAB更好。
dabster 发表于:2007-7-26 15:19:21
以下是引用lingyi在2007-07-23 11:36:05的发言:
用途不一样啊。不是用来设计音箱的。
lingyi 发表于:2007-7-30 12:38:43
以下是引用dabster在2007-07-26 15:19:21的发言:
用途不一样啊。。不是用来设计音箱的
LoudSpeaker LAB不是用来设计音箱的,也是测试的
